2 days in and issues!!!!!!
Old Sep 2, 2011 | 07:29 PM
JaysR56's Avatar
JaysR56
ok i just got my car its an 07 mcs and the outside bulb fail light came on but i dont see any bulbs out ?? also a light that has an engine block in yellow with half filled in in black showed up and it feels like the turbo is not working any body had this come on? any help would be great thanks
Old Sep 2, 2011 | 09:13 PM
BigFox's Avatar
BigFox
Do you have pics of the Engine light? The turbo gets bypassed if the vehicle sees a problem with then engine. The light bulb out light, could be a license plate light bulb, it gets looked over alot. Also, when you start the car, try to be aware of what you are doing when the light comes on.... like pressing the brake, or switching the lights on, or putting it in reverse.....
Old Sep 2, 2011 | 10:56 PM
JaysR56's Avatar
JaysR56
thanks for the info ill check the license light for sure as far as what im doing its a stick so i have the clutch in when i start it even when not in gear. also my engine seems to very loud. lots of clicking im sorry for not doing my research if this is a common question
Old Sep 7, 2011 | 09:15 PM
BigFox's Avatar
BigFox
check your oil level, and check your timing chain tensioner, it could have backed out. Also, look at your vacuum pump, at the drivers side end of your exhaust camshaft, if the finish is looking like its peeling or flaking, then you will need a vacuum pump, the will make lots of noise.
Old Sep 8, 2011 | 08:56 AM
Mini2na's Avatar
Mini2na
The N14 engine in the R56 is just plain noisy. Check the oil level for sure. The tensioner issue is pretty loud, alarming so, but goes away after 2-3 minutes of warm up. You'd know if this was happening.
If you find no bulbs out, you may want to go around and check to see if someone has put "aftermarket" bulbs in. LEDs often lead to the warnings and I have heard of "extreme white" bulbs giving the same.
Old Sep 8, 2011 | 09:47 AM
ThatMiNiGuy's Avatar
ThatMiNiGuy
Where are you located? If you are in the Tri-state area I could check it out.
09R56
Nov 16, 2022 10:49 AM
KrisMiss
Jan 3, 2016 02:02 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
tippin
Aug 5, 2015 08:43 AM
