Cooling low fan... Old problem, slightly different
Old May 31, 2018 | 04:36 PM
Tim Ashcraft's Avatar
Tim Ashcraft
Hey guys, new to forum but not to British cars.... So, I bought this 14 Clubman last summer with a blown head gasket, spent the winter tearing it down and replacing gasket, head bolts and thermostat. Put back together, runs great.
great. Now I find the low speed fan doesn't work. High speed yes. I'm seeing a lot of posts about the resistor needing replacement on early models, is this the case with this model? Appreciate any input. I see mine only has 2 leads to fan as early models have 3... High, low and ground.
Last edited by Tim Ashcraft; May 31, 2018 at 05:16 PM. Reason: Want to add more data
Old Jun 1, 2018 | 07:32 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Not all Minis have a high and low speed on the fans. Open the under hood fuse box. The high speed and low speed fan relays are right next to each other. If you only have one relay either someone removed the relay or more than likely yours doesnt have the option.
Old Jun 1, 2018 | 07:50 PM
Tim Ashcraft
Tigger
fuse box shows 2 relays on underside of fuse box cover, 1 and 11 (as in 2, I think). The low speed relay was missing, I bought and installed ( there is equal voltage present on each relay base when both removed).
I'm trying to get definitive proof before removing fan assy looking for resistor...
Also, mine only has 2 leads to fan as others have 3 ( high, low, ground).
-=gRaY rAvEn=-
Jul 30, 2014 07:59 AM
Alexander Major
Jun 12, 2014 07:11 AM
steve1ddd
May 15, 2014 10:21 PM
amberback
May 9, 2014 04:14 AM
panaphobic
Jan 19, 2014 04:08 PM
