P0172 sputtering
Old Jun 21, 2018 | 11:27 AM
asysavanh's Avatar
asysavanh
P0172 sputtering
So I have a sputtering issue around 1.5k. It comes and goes.
2012 n18 MCS R56
just recently went two steps colder on plugs.
replaced my MAF sensor because it started idling weird. Everything seemed to be back to normal after replacing the MAF but then I got a p0172 code. Just wondering if anyone else has had this issue. The only problem I see is maybe the injectors?
Old Jun 21, 2018 | 11:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Why did you go colder on the plugs?
P0172 is for "Bank 1 System Too Rich". What is the condition of your air filter? How many miles on your engine? What is the condition of the O2 sensor? Did you install the MAF sensor backwards? It is possible you received a bad MAF sensor...
Old Jun 21, 2018 | 11:53 AM
asysavanh's Avatar
asysavanh
Air filter is clean. It is oiled. Im switching to a dry filter here. The next step is to trade in the new MAF I got and see if that does anything.
i went a step colder for safety reasons. I have full bolt ons with the JB+
O2 sensor is probably shot because I have a catless downpipe.
i have about 85k on the motor
im pretty sure it’s installed correctly lol. It’s kind of a no brainer install
Old Jun 21, 2018 | 11:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Just trying to get the whole story
A JB+ should only need 1-step colder plugs, maybe, not 2-step colder.
If your air filter was recently re-oiled, could be a source of fouling on the MAF.
P0172 rich condition usually means the MAF is reporting the wrong air flow.
Old Jun 21, 2018 | 03:20 PM
asysavanh's Avatar
asysavanh
That’s fine lol. I’m always vague 🤦🏽*♂️
It was oiled recently. I’m going to try these little fixes and see if anything happens. I’m was trying to see if there was anything I’m missing. Thank you!
Old Jun 21, 2018 | 03:28 PM
isamin's Avatar
isamin
The system is TOO rich as the colder plugs are not burning gasoline fast enough.
Put the old plugs back in to see if you can clear codes.
If this works go ONLY one step colder and see how it goes.
ISAMIN
Old Jun 23, 2018 | 09:17 AM
asysavanh's Avatar
asysavanh
After reading around how plugs work, I don’t agree too well with what your saying. I was running the car for a few months with the colder plugs as well without any issues. No stutters or hesistation. I got it colder plugs to prevent pre det.
Anyways issues are solved, my two of my spark plugs were fouled out.
i forgot to mentioned I used a can of CRC intake valve cleaner 🤦🏽*♂️
CooperS33
Feb 2, 2013 09:43 PM
funR53
Aug 6, 2010 08:35 AM
SHRTSTAK
Jul 30, 2010 10:54 AM
TonyB
Apr 20, 2007 08:44 AM
magic mini
Dec 9, 2005 07:36 AM
