Do you need to use gasket sealer with a valve cover gasket?
re: 2013 Mini Cooper N16
I want to remove the valve cover to inspect the timing chains guides. I have a new gasket on he way however I can see some sealer seeped out on the corners of the valve cover gasket opposite the timing chain. The dealer replaced the gasket in January for the previous owner.
Where should the sealant be applied and what type should I use?
Thanks!
Thanks!
Yes, just the two corners. Full procedure shown here and check the last pic for the location of the sealant. Very easy procedure. I bought new bolts in case one snapped so if you break one let me know. Mine were all good. Go slow and use a torque wrench to finish.
https://www.pelicanparts.com/techart...eplacement.htm
Gabe3
02-25-2019 01:24 PM
RexNTX
05-10-2017 06:05 AM
k_h_d
02-28-2009 07:03 AM
