Oil leak
Old Apr 23, 2018 | 08:34 AM
rbowman's Avatar
rbowman
Oil leak
Initial post: 2009 S, oil leak getting onto the exhaust and coming in through the vents. Running fine. I will attempt to repair this after I get another mode of transport.
Old Apr 23, 2018 | 02:40 PM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
Welcome to the forum
Old Apr 23, 2018 | 03:06 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Gen2 Stock Problems/Issues area.
And, yes welcome to NAM.
Old Apr 24, 2018 | 06:29 PM
kurtsunn's Avatar
kurtsunn
Having similar issues with a 2009 Non S - tried replacing the O-ring on the vacuum pump. Too early to know if it made a difference. I'd be curious what your findings are.
Old May 1, 2018 | 12:09 PM
Struns's Avatar
Struns
Same here..just pulled off the downpipe both oil line ( feed and drain) are dry. Vacuum pump was just done with a new one don't see any leaking at cam cover.
Where else do these things leak??
Guess I'll just put new oil lines on anyway (09 with 77K) wash it down just put the DP on and run it a bit to see what's going on :(
Old May 3, 2018 | 07:40 PM
Struns's Avatar
Struns
Old May 3, 2018 | 07:57 PM
kurtsunn's Avatar
kurtsunn
Originally Posted by Struns
Your wallet. LOL.
Check out diagnosis here: https://www.pelicanparts.com/techart..._Diagnosis.htm
(sorry, not too sure what the policy is about posting external links)
Old May 3, 2018 | 08:34 PM
scottm2k's Avatar
scottm2k
Valve Cover or Oil Cooler are some likely culprits.
Old May 4, 2018 | 06:40 AM
John Thompson's Avatar
John Thompson
Just replaced oil filter housing gasket R56 2011 Base, to perform place in service mode, remove heat shields and unbolt cat converter plus exhaust manifold. Oil filter housing bolts are located behind exhaust manifold. Good luck still checking for any futher leakage of oil.
Old May 4, 2018 | 06:47 PM
Struns's Avatar
Struns
Oil filter housing gaskets ordered. Should have them Monday. Detroit oil line and return tube have arrived, After washing and sitting for 3 days bell housing is wet. If it needs a rear main seal, that is just going to have to wait till I need a clutch.
Old May 6, 2018 | 05:21 PM
Struns's Avatar
Struns
WTF..I cleaned the whole thing up ready to install. So I'm looking in all the holes to see it's clean. In the hole( second from the bottom) I see something blueish. Flashlight and a probe and all this crap came out. Its like sand the large pieces you can crumble up. Looks like the hole was clogged. BTW there was more stuff than what is in the picture.Any ideas what the hell this is???
Old May 6, 2018 | 09:21 PM
LostbutFound's Avatar
LostbutFound
Timing chain guide?
Old May 7, 2018 | 03:22 AM
Shiner's Avatar
Shiner
A Gen 2 with kidney stones? I’m stumped.
Old May 7, 2018 | 05:16 AM
Minidogger's Avatar
Minidogger
Excess gasket sealer?
Old May 7, 2018 | 05:32 PM
scottm2k's Avatar
scottm2k
Pretty much this.
I had some significant "sediment" buildup in the coolant side of the oil cooler along with part of a OEM water pump impeller (I wondered where that went) which restricted flow through the heat exchanger. I got the major chips out with a scribe and back flushed the rest until it was 100% clear.
If and when I have another oil or coolant leak there I think I am going with an aftermarket oil cooler mounted in front of the condenser.
Old May 7, 2018 | 07:40 PM
Struns's Avatar
Struns
Originally Posted by scottm2k
Pretty much this.
I had some significant "sediment" buildup in the coolant side of the oil cooler.
I flushed the cooler for a half hour( back flush ..front flush) and that crap just kept coming out
Wrex21
May 7, 2018 05:16 PM
