White smoke after ~10 minutes of idling
Old Jul 6, 2018 | 06:43 PM
mcguir6799's Avatar
mcguir6799
My buddy has a 2009 JCW that will billow white smoke after idling for ~10+ minutes. Once it blows the smoke it goes away quickly until you idle again for a prolonged amount of time. It doesn't smell like coolant is the peculiar thing, and I am not sure how to explain what it smells like, but it a foul smell.
There's no coolant in the oil, he is going to do a leak down before long, figured I would check here for other ideas as well.
Thanks.
Old Jul 6, 2018 | 06:49 PM
AZdsrt's Avatar
AZdsrt
A couple of thoughts. First, head gasket. Leak down test a good idea, at least a compression test. Other thought is perhaps water in the fuel?
Old Jul 6, 2018 | 06:54 PM
mcguir6799's Avatar
mcguir6799
It has done it for a few weeks now and the car runs fine, so I don't believe water in the fuel or else it would run horribly I'd assume. I don't suspect the head gasket as there isn't any coolant in the oil and it doesn't smoke constantly.
I personally suspect the turbo may be the issue.
Old Jul 6, 2018 | 07:07 PM
Scooter24's Avatar
Scooter24
I'm having the same issue. I'm guessing it's going to be valve seals, could be turbo though. I'm going to try and diagnose my problem this weekend.
Old Jul 6, 2018 | 08:19 PM
BeardedForever's Avatar
BeardedForever
Most likely valve seals or guides.
Old Jul 9, 2018 | 03:15 PM
PepperwhiteS07's Avatar
PepperwhiteS07
Same thing happens to mine but only when A/C is on. Let me know what fixes it.
Old Jul 10, 2018 | 08:44 AM
Tjsb03's Avatar
Tjsb03
Same here
i had this issue also and added a catch can and it no longer does it. I think just the poor PCV design causes it to burn more sitting. Catch cans are an easy install and fairly cheap
Old Jul 13, 2018 | 01:27 PM
Direwulff's Avatar
Direwulff
Possibly valve seals---they were causing the smoke from my exhaust when accelerating away from a stop light. Switched to Mobil 1 high mileage motor oil and used half a bottle of Barr's Stop Leak mixed in the oil, no more smoke.
Old Jul 13, 2018 | 02:11 PM
Richieb0y28's Avatar
Richieb0y28
I had this too right before my thermostat housing was replaced. Afterward, everything was fine. It's been 2 years, everything seems ok. (knock on wood)
Old Aug 23, 2018 | 06:32 AM
Cowman369's Avatar
Cowman369
Was this issue resolved, my 2011 countryman s is doing the same thing, after idle for about 10 minutes white smoke, awful smell (not sweet), then after accelerating it goes away until I sit at idle for about 10 minutes again
Old Aug 23, 2018 | 06:36 AM
Richieb0y28
Mine is still running well, no smoke 2 years after replacing the T-housing.
Old Aug 23, 2018 | 09:57 AM
Dannorth's Avatar
Dannorth
Is the car using coolant? Any sign of exhaust gasses in the cooling system?
Old Aug 23, 2018 | 10:08 AM
Cowman369's Avatar
Cowman369
Just brought it to the dealer, they said it smells a little sweet, so they are going to figure out where the coolant it entering from. But I dont think it's a bad leak, cause it's not smoking all the time. Coolant looked and smelled fine to me, but I'm not a mechanic. Oil was changed the other week and it looked normal, and didnt have a funky smell either.
car is still under extended warenty so I'll keep posted on what the issue was.
Old Aug 23, 2018 | 10:12 AM
Dannorth's Avatar
Dannorth
Another good way to check is to pull the spark plugs and inspect. If you're getting coolant into a cylinder, it will tend to steam-clean it; the porcelain inside the plug will be bright white and the electrode will be super clean.
Old Aug 23, 2018 | 10:19 AM
Cowman369's Avatar
Cowman369
Very good information, thank you.
Whyismyhaironfire
Apr 15, 2018 07:37 AM
wsalopek
Sep 6, 2017 07:29 PM
Kcblackwell07
Feb 28, 2017 07:41 AM
Mark Middleton
May 11, 2014 09:05 AM
MInI___Gz
Electrical
27
May 24, 2009 08:10 AM
