Engine Stuttering After Idling A Few Seconds
Old May 10, 2014 | 03:04 PM
Mark Middleton's Avatar
Mark Middleton
Not sure if this is entirely the right place to post this, so I apologize beforehand.
A little after I start the car (around thirty seconds or so), the "service engine soon" light blinks a few times and the car starts shuddering. If I keep tapping the gas or hold it down a bit, it won't do it until I let up. I've changed the spark plugs, spark plug wires and the ignition coil. I even changed the valve cover gaskets and spark plug tube grommets, but I can't seem to figure out what the problem is. Has anyone had this problem? I'd really appreciate any advice.
Old May 11, 2014 | 08:58 AM
Mark Middleton
If more details are needed, I can provide them. I've gotten really frustrated with this. I can't seem to figure out was it is.
Also, I forgot to mention that it's a 2004 base model.
Old May 11, 2014 | 09:05 AM
ZippyNH's Avatar
ZippyNH
Pull a code...
Sounds like a misfire....
On a "cooper" it often means a valve issue from not using midgrade 90 octane as required.....
If the wires, plugs and coil are OK...
Time for a compresdion check then a leakdown to narrow it down...
But pull a code....maybe you will get lucky and it is a sensor causing it....
If it is a misfire....a mechanical fix (new valve) is thevlikly fix....
rob&JCW
Feb 13, 2023 07:03 PM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Lt. Dan
Aug 10, 2015 08:23 AM
