Mini s problems
Old May 14, 2018 | 12:20 PM
Justin T.'s Avatar
Justin T.
Mini s problems
Guy's I'm new here and I need some help. My daughters 2010 mini s had a check engine light. I used my obdii connector to clear the light while the car was running and it killed the car instantly. Now it will only start for two seconds and shuts off, but it will restart. I have it in the shop and they are saying that it's throwing a code saying software is not recognized, any ideas what is causing this? Thanks, Justin
Old May 14, 2018 | 01:07 PM
MiniToBe's Avatar
MiniToBe
welcome aboard!...can you ask them what the specific codes are? what is the mileage? was the HPFP ever replaced (ask them to spray quick start to see if it fires right up)? where you located?
Old May 14, 2018 | 04:16 PM
sawicki's Avatar
sawicki
Curious if you trying to clean the code with the car running wiped the ecm some how.
Old May 14, 2018 | 05:44 PM
Justin T.'s Avatar
Justin T.
That's what I'm thinking guys. You can spray gas into the intake and it will run. The car has 70,000 miles on it and the timing chain issues have been taken care of last year. It hasn't given any problems until I cleared the codes. I had a new key programmed and it still doesn't work. It will crank and run fine for two seconds and like you turned the key off. I'm located in Texas just outside of Houston.
Old May 14, 2018 | 10:35 PM
sawicki's Avatar
sawicki
Sounds like a bad HPFP. What were the codes before you tried to clear them? If you try and start it several times in a row will it run? Im no expert but have dealt with 2 bad HPFP. The first one would start the car fine but caused the car to go into limp mode and the second bad pump would give me fits trying to start it when the engine had sat for a few hours.
Old May 15, 2018 | 01:30 AM
Justin T.'s Avatar
Justin T.
No it will crank every tme, but it will only stay running for two seconds and shut off. None of this started until I cleared the codes. It had several misfire codes and a powertrain code, but I didn't save the codes. It was running fine until the moment that I cleared them.
Old May 15, 2018 | 05:49 AM
Minidogger's Avatar
Minidogger
Can the dealer reload software on the ECU?
Old May 15, 2018 | 06:07 AM
Justin T.'s Avatar
Justin T.
It's at a reputable independent shop right now, but they are saying that if their programming guy can't do anything with it, then they will send it to a dealer.
Old May 15, 2018 | 06:24 AM
MiniToBe's Avatar
MiniToBe
I did it a number of times...clear codes only not programs
Old May 15, 2018 | 06:32 AM
Justin T.'s Avatar
Justin T.
Yeah I didn't think that clearing the codes should have caused any of this.
Old May 15, 2018 | 03:07 PM
sawicki's Avatar
sawicki
If the codes were P0300.P0301,P0302,P0303 P0304 Which are misfire codes im going to put my money on the HPFP. And luckily for you the price has dropped by 60% for on within the past few days
Old May 15, 2018 | 03:23 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Just for the heck of it, try a dollar bill test.
Old May 15, 2018 | 03:37 PM
DneprDave's Avatar
DneprDave
I know what a dollar bill test is for stove doors. (You close the stove door on a dollar bill and if you can pull it out , you need a new door gasket.)
But I don't know how it applies to a MINI.
Old May 15, 2018 | 03:50 PM
Whine not Walnuts
You can check for a burnt valve.
Old May 15, 2018 | 06:43 PM
Justin T.'s Avatar
Justin T.
Brother no offense , but the car was running fine until I cleared the codes and when you crank it up it runs fine for the couple of seconds that it does run. Clearing codes doesn't burn valves. If I spray gas into the intake it runs fine with no miss.
Old May 15, 2018 | 09:56 PM
sawicki's Avatar
sawicki
I have a feeling you clearing the code and the car dying is nothing more then a coincidence. If you were pulling misfire codes chances are the HPFP is shot and that is causing the no start.
Old May 16, 2018 | 01:31 AM
Justin T.'s Avatar
Justin T.
Thank you sawicki
Old May 17, 2018 | 04:38 PM
Justin T.'s Avatar
Justin T.
Thanks everyone for all the help. Problem solved it was a bad MAF.
Old May 17, 2018 | 06:53 PM
Justin T.'s Avatar
Justin T.
sawicki, thanks for everything.
Old May 18, 2018 | 03:03 PM
sawicki's Avatar
sawicki
Glad you got it worked out and it was nothing major.
Amytheallen
R55 :: Clubman Talk (2008+)
Aug 18, 2012 08:52 PM
Autoxser1975
Jun 12, 2011 02:27 AM
joecooool
Jun 20, 2004 09:11 PM
