Injectors for N14
Old May 31, 2018 | 11:34 AM
danraabe's Avatar
danraabe
Injectors for N14
Can current injectors be rebuilt? Flow tested? If not where can I purchase new ones in a matched set?
Old Jun 4, 2018 | 10:19 AM
cornjuice's Avatar
cornjuice
one does not simply purchase new injectors for a DI engine.. they would be custom and $$$$
**it would be cheaper to purchase a WMI system instead and spray based on duty cycle of the injectors.
Old Jun 4, 2018 | 02:18 PM
danraabe's Avatar
danraabe
Injectors
Not sure What you were talking about. Pelican has new Bosch injectors for $72 each I discovered. Now my question is do they injectors come with the Teflon and the rubber seals installed.
Old Jun 10, 2018 | 08:23 PM
cornjuice's Avatar
cornjuice
ohh you want new OEM.. sorry I assumed you meant upgraded/higher flow. Carry on.
Old Jun 11, 2018 | 06:59 AM
danraabe's Avatar
danraabe
Injectors N14
Are there higher flow injectors available somewhere. According to the techs at mini, these are it.
Old Jun 15, 2018 | 10:15 AM
We have the bosch injectors here, they come like you see.
https://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Fuel/
Old Jun 15, 2018 | 10:19 AM
danraabe's Avatar
danraabe
N14 Injectors
The come with all the o-rings and teflon ring installed? Does the teflon need to be "prepped" before installation?
Old Jun 15, 2018 | 10:23 AM
DneprDave's Avatar
DneprDave
What do you mean by "Prepped"?
Here you go:
https://www.newtis.info/tisv2/a/en/r...nes/1VnYoNfXkM
Old Jun 15, 2018 | 11:17 AM
danraabe's Avatar
danraabe
N14 Injectors
Do they have to be shaped with a special tool to make sure they seal in the head? Or do you just install them right out of the box?
Old Jun 15, 2018 | 11:22 AM
You are supposed to use the tool, it makes sure you dont hurt the seal. Its like doing seals on the automatic transmissions, you dont want them to leak. And you might tear that seal.
Tool is here and right now on sale.
https://www.ecstuning.com/b-schwaben-parts/schwaben-bmw-mini-fuel-injector-o-ring-tool-set/023883sch01a/
Old Jun 16, 2018 | 11:52 AM
oldbrokenwind's Avatar
oldbrokenwind
Even when using the correct tool, injector installation to the head should be done one-at-a-time, then the rail installed. It's an extremely tight fit, and trying to line up all four at once is damn near impossible.
Systemlord
May 3, 2019 04:43 PM
csllover
Oct 14, 2017 05:44 PM
BLiNKFAST
Aug 21, 2016 06:10 AM
odieman23
Aug 18, 2016 04:57 AM
NC Doug
Oct 20, 2014 10:03 AM
