No power if bogged when leaving from a stop
Sometimes when I'm driving while not in Sport mode, I'll inadvertently bog the engine leaving a light or stop sign and then it has no power until it's been revved past 4 or 5 grand a couple of times. Is this a wastegate actuator issue or what?
OK, information is needed. What year, what model, S or justa and maybe a few other tidbits of information would certainly help. As an example, you can see by my sig what I'm driving. On hot days, sitting at an intersection a condition called heat soak develops which causes a momentary loss of power. Knowing what you are driving could either confirm that that is the problem or that the problem lies somewhere else.
Are the vac lines swollen or oily? Are they completely hooked up to the vac reservoir? I had a similar condition (not all the time though) and my vac lines were shot.
vodka
Dec 29, 2009 11:20 AM
Navigation & Audio Informational Warning at power-on... how to stop it?
unixgal
Aug 8, 2007 12:41 PM
jack07734
Mar 7, 2003 06:18 AM
