P0301 Cylinder 1 misfire
New member here. Not sure if I am posting to the right place.
I have a 2011 mini cooper 1.6L base model. I am getting P0301 Cylinder 1 misfire. Swapped spark plug, coil, fuel injector. The code stays with Cylinder 1.
Reading other posts on the site that suggest to clean the carbon build up. Opened the intake manifold. It looked like the fuel injector is actually outside the valve in this model. The intake valve is clean. Did a bit cleaning anyway. Bottom line: problem stays with cylinder 1.
What I did notice is: I can hear popping sound when I run with all 4 cylinders. The sound like a Harley's motor cycle. Not as loud and only occasionally. If I unplug the spark plug wire to cylinder 1, the engine runs normal on 3 cylinders. I haven't done the compression test, as I don't have the equipment. I hope the symptoms here can give some clue. Any advice from the experts here?
Thanks much
Thanks much
BlackIce
08-26-2016 12:09 PM
2003minicooper
05-03-2012 03:57 PM
