Help! Valve cover bolts
Old Jul 5, 2018 | 03:43 PM
Pramuk's Avatar
Pramuk
I got new valve cover and try to replace it. But I accidentally snapped 2 of bolts broken half but other bolts are fine. How can I take 2 bolts out ?
Can I still start up and drive my vehicle to the shop?
Old Jul 5, 2018 | 03:56 PM
DneprDave's Avatar
DneprDave
If there is any of the bolt sticking up above the head, you could grab them with a Vice Grip plier and twist them out. Otherwise, you will need to get a set of screw extractors and follow the instructions that come with them to remove the broken off bolts, this will require some drilling.
Old Jul 5, 2018 | 03:58 PM
Pramuk's Avatar
Pramuk
There is nothing sticking up above the head. Just half of bolf stuck. I think I need to dril those out. This case can I still drive to the shop around 20miles?
Old Jul 5, 2018 | 04:09 PM
Pramuk's Avatar
Pramuk
Here are photos
Old Jul 5, 2018 | 04:40 PM
sawicki's Avatar
sawicki
You have 1 good option and 1 bad one. Option one is buy an EZout kit and grill the center of the broken bolt and us the extractor tool. Always try the smallest size possible so you dont damage the head or You could drill out the bolt and retap but then your going to run into other issues. Dont drive the car as is or you will warp the new cover.
Old Jul 5, 2018 | 04:53 PM
Pramuk's Avatar
Pramuk
I have EZout kit and extractor tool but I worry about whem I drill some metal pieces will drop down to cylinder head... will cause new problems?
Old Jul 5, 2018 | 05:15 PM
sawicki's Avatar
sawicki
Once you drill the hole in the bolt just vacuum out the chips.
Old Jul 5, 2018 | 07:49 PM
downshift1's Avatar
downshift1
Pull the valve cover back off and take a dremel and cut a slot in the top (cover all open engine components!!) and unscrew them with a small flat head screwdriver. if you attempt to drill them out 9 out of ten you'll be crooked and do more damage than good.
Old Apr 8, 2024 | 12:05 PM
slofut's Avatar
slofut
I would get the cover off and use vice grips and heat
Gabe3
Feb 25, 2019 01:24 PM
PhoR53
May 4, 2017 08:37 PM
coachvminis
Feb 9, 2017 07:37 AM
fireofficer001
Sep 1, 2015 09:49 AM
fritzo
Apr 20, 2015 03:40 PM
