PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67
  1. Boot window leaking in rain
  2. Fluid bubble?
  3. Can I get some service here?
  4. First scheduled mainenance due soon. any recommendations
  5. Where is my air filter?
  6. Radiator for MCS
  7. Drivetrain noise?!?
  8. Glove box door
  9. Fuel Injection Cleaner
  10. How to check for exhaust leak?
  11. Fuel Gauge, or speedometer?
  12. Any Ideas? A/C Leaking... somewhere
  13. Intercooler- airflow out of it?
  14. loud power steering pump(??)
  15. Anyone know what software version I have ?
  16. Help - transmission problem?
  17. the alta intake....
  18. 2004 Antenna and base one piece??
  19. Update - Drivers window DEAD!
  20. Spark Plug Gap
  21. Rant about problems with the mini
  22. Sweet smell... coolant ?
  23. GReddy Oil Catch Can
  24. Front windshield washer spray woe
  25. Fuel Line Disconnect
  26. Watched my MCS roll away on a flatbed today...
  27. Cooper S upper radiator hose I.D.
  28. Please help me ID Part Numbers for these
  29. Knocking noise?
  30. HowInTheHell do I change this?
  31. Fragile plastic under-bonnet components...
  32. 5 speed harmonic noise at highway speed normal?
  33. 20000 miles and transmission dies!
  34. Fuel and oil needed
  35. Whacky Fuel Gauge
  36. Aftermarket microfilter source?
  37. Clutch Issues and Mini USA Making me Pay $$$
  38. 45,000 mile Inspection II - $391
  39. What Scheduled maintenance am I missing?
  40. drive shaft removal
  41. Need help with short shifter installation!!!
  42. Flat tire monitor..How to test it? Speedo question.
  43. Yet Again: Engine Break-in
  44. Assistance needed: clicking from below (Borla?)
  45. smokin mini s
  46. compression ratio for Cooper 1.6
  47. Is this normal? My MCS exhibits a distinctive hesitation or
  48. v. 37 Software - Now that it's out, what's it suppose to do/
  49. Alta Intake whistle?
  50. Alta intake
  51. 1) Trip computer and 2) Harmon Kardon speed vol.
  52. Exhaust Cooper S
  53. little round "grills" in front bumper.....
  54. Peake scan/reset tool
  55. Dimming headlights
  56. Need your help, please
  57. Going down hills...what IS that?
  58. Is software v36 a owner request only upgrade?
  59. Torque Specs for Motor Mounts
  60. question about the warning lights?
  61. draining transmission fluid
  62. HELP needed. ABS light on after adjusting Koni rears
  63. PPG replacement Windscreen Club
  64. Squeaky Window
  65. What did you get with your 10K service?
  66. Perfect Oil Filter Socket
  67. 7 days in the shop, waiting for an "EDK"
  68. Torque specs for spark plugs
  69. Steering noise
  70. Please Help--My front end is thunking!
  71. lemon?
  72. Just recieved email from Mini! WOW
  73. overflowed liquid under the bonnet
  74. Click Click Click (CVT Mini)
  75. This may be a stupid question
  76. How to adjust camber on mini's
  77. Stumbles back
  78. installing a rather large horn under the hood
  79. TIS/EPC Computer Geek Question
  80. ????Air Filter hose clamp.....how does it re-clamp???
  81. Oil filter?
  82. strange sound any ideas? update
  83. Help: Window stopped working
  84. First Scheduled Maintenance - Who actually does it!
  85. Rotating crankshaft
  86. Strange Idle, No Stalling
  87. How is idle regulated by ECU?
  88. My rear end squeeks...
  89. Strange noise at high RPMS
  90. The TIS/ETC CDROMS don't seem all that useful to me.
  91. head removal without special tool?
  92. engine smell?
  93. Runs good, sounding bad: CooperBeagle needs help!
  94. Problem with the MC Gearbox?
  95. A/C is smelling pretty bad....
  96. Alcohol injectors/water injector Raceing fuel
  97. Kill switch
  98. Heatshield and PS hose clearance ?
  99. help me find something in the shop manual
  100. Head light washer malfunction and fix
  101. a Rotory MINI?
  102. HELP, need picture.... (project chrispy mini)
  103. PCV hose replaced = PCV valve replaced???
  104. What ar the little plastic boxes attached to my suspension..
  105. Man that's a loud humming sound...
  106. Lost Feature(s) after v36 programming, anyone?
  107. Convenience opening option stopped working
  108. Underpanel?
  109. Basic Tool Kit
  110. trip computer average speed wrong
  111. Remove interior trim around sunroof?
  112. Applaud Classic MINI Service Department in Mentor, Ohio
  113. Quick questions about Version 36
  114. mini madness stage3 245hp package?
  115. Anyone make a wiper blade wing?
  116. Do you put goop on your Exhaust when Installing?
  117. Noise after installing new brake pads?
  118. v36 fixed stumble
  119. Terrible Noise from Windshield - Dealer says it slipped down
  120. Show me your CR/W MC or MCS with Union Jack roof flag
  121. Annoying (and dangerous) Sunshade Problem
  122. Does my MCS have a blow off valve?
  123. Replaced (2) seals
  124. Which ignition is the best?
  125. 5 speed transmission oil
  126. Where to Find Redline Motor Oil?
  127. If the airconditioner is on the car won't take off!
  128. Remote oil filter/Pre-oiler installation?
  129. airbag indicator light went on
  130. Dyno Chart: 2003 MINI Cooper S, latest rev of software
  131. part # for new windshield!!!
  132. Question about after market exhaust sound
  133. blown belt
  134. Does the MCS have fuel injectors?
  135. Cooper engine fire restoration
  136. Help! I just blew out my no. 3 plug.
  137. Windshields
  138. The NEW AND IMPROVED windshield!
  139. SS+ Detection?
  140. I'm idling at 2300 rpms ?
  141. Sunroof Lube
  142. Idle engine to warm?
  143. Drivers side power window flaking out....
  144. Clock went "dead"
  145. Shop manual
  146. Looking for info on 'Team SES' membership with possible 'Tea
  147. Exhaust noise help
  148. Nasty Misfire that is bugging the hell out of me...... HELP!
  149. MCS Oil leak
  150. Help! Need Advice after Windshield Replacement
  151. ABS Disable Switch?
  152. Redoing the timing help request...
  153. Throttle Run-on
  154. Does engine braking use as much gas as idle?
  155. Air Filter
  156. Car overheating at 30*F
  157. Steering Wheel Shaking
  158. Suddenly VERY loud power steering motor
  159. Cleaning a K & N drop-in air filter
  160. Steering Feels Funny
  161. Service Bulletin 12023?
  162. 1 yr, 34150 miles
  163. v.36 List of Programmable Options???
  164. MINI Computer Menu Options WOW NEAT!
  165. well... something is wrong?
  166. Factory motor oil..is that a Castrol 5W30 synthetic?
  167. Got my Blackstone Oil Results!
  168. Mini Cooper Engine COST
  169. Nut size under the scoop
  170. Angry, taking action, cracked windshield
  171. Repairing, not Replacing a cracked windshield: any success?
  172. How do you remove the A-Pillar trim?
  173. Fog Lamp Light out, replace it myself or dealership?
  174. How to void the
  175. anyone know the website that has a manual for an s
  176. Check Engine/ EML Light
  177. Brake Bleeding
  178. headlamp hight adjutment
  179. 12Vdc
  180. Pipercross filter
  181. IMPORTANT: AIR CLEANER IN YOUR COOPER...
  182. Cannot exit & lock car w/it running?
  183. best intake in market
  184. Tapping around 3000-4000 but not that loud.
  185. Engine Noise / Resonance
  186. Observed oil pressures
  187. Stumble even after V36?
  188. Airbag light on AGAIN - Third Time
  189. Poor rear wiper winter performance
  190. Moss Mini Dipstick hard to use?
  191. Boot won't close
  192. gas mileage, i'm averaging 18.9-19.1 ALL the time, and have
  193. boot release won't
  194. John Cooper works kit
  195. oil filter
  196. service engine soonlight
  197. MCs Stalls on low Gas
  198. Is the MC 5spd clutch adjustable?
  199. Possible "long-term" problem!
  200. ding question
  201. Specific problem with 5-speed transmission?
  202. COLD WEATHER=BLOWN TRANNY...HOW MANY?
  203. Has anyone tried this PEAK Scan Tool R5-EMX
  204. Oil testing service?
  205. v36.1?????
  206. Idle surging after boost gauge install
  207. Steering fan cover
  208. Dead battery = failed emissions test?
  209. Silly Me - Silly Boot
  210. GPS ERROR NO disk found
  211. Hot start issue?
  212. Aftermarket vs. Mfg. Windshield
  213. Programmable Features and the ECU
  214. Bad Radiator Fan? Strange Noise
  215. OVERHEATED MINI??? Has it happened to you??
  216. NEED HELP!! Car won't start.
  217. Software Question...
  218. MINI EMERGENCY.....It over heated !!!!!!!!
  219. car starting problem
  220. Too many problems for me - I'm moving on...
  221. front light bulb help!!
  222. My Door Is Jammed
  223. I had "reboot" my Mini this morning ?!?!
  224. Seat controls jammed --- can I fix it?
  225. Cold weather stall for Cooper
  226. Power Steering
  227. Any Special Coolant??
  228. clanking noise during gear changes
  229. Static noise coming from speaker even when radio is turned o
  230. Help! Bad EWS Module
  231. Need help killing a Rodent !!!
  232. squeeks and rattles
  233. who has used this pully puller and do you like it?
  234. Moss Oil/Plug
  235. Transmission being replaced!
  236. HELP! Where's the PDC speaker?!
  237. Mini Cooper shop manuals - Printed or Digital Format ????
  238. V 36 Upgrade...Do I really need this????
  239. What type of power steering fluid does the Mini use?
  240. HELP! What size bolt to use the connect CAT to Resonator???
  241. Can't shift in cold
  242. transmission issue - (was) stuck in NY - final update.
  243. Another DSC question.
  244. Shifter buzz/ vibration under acceleration
  245. Cold Weather Symptoms
  246. Posessed Wipers and Issue With Brakes
  247. coolent change ?
  248. Electrical Gremlins
  249. * * * ATTN: MINI Division * * *
  250. EML light episode
