Fuel Injection Cleaner
Old Apr 21, 2004 | 04:25 PM
jdemaria's Avatar
jdemaria
What's everyones favorite fuel infection cleaner they find works best with the mini?
Old Apr 21, 2004 | 04:39 PM
Ryephile's Avatar
Ryephile
How many miles do you have? You should need a fuel system cleaner until upwards of the 100k mark.
In any case, I ran Redline in my ole' 3-series; and it helped noticably (at 120k miles)
Old Apr 21, 2004 | 07:24 PM
pocketrocketowner's Avatar
pocketrocketowner
Your old 3 series probably had a very bad case of intake valve deposits due to you a) being cheap and buying it bad gas and b) owning the most sensible engine for intake valve deposit formation since the Austin A series engine. So sensible that the industry test for these additives is based on a 3 series.
Injector clean ups are TRULY a waste of time and money IF you use Premium fuel from a reputable brand. Top of the line grades carry a VERY healthy dose of additive to keep injectors clean, intake valves clean and most importantly (Shell, Chevron, Texaco and BP ONLY) prevent the crap from accumulating on top of your pistons which eventually translates into MORE compression ratio which means more octane which means, eventually pingin and then a piston meltdown.......not pretty.....
Old Apr 21, 2004 | 07:45 PM
05JCWS's Avatar
05JCWS
I agree with PocketRocket. No one on this board should even be thinking about fuel injector cleaner. Why? Because no one on here has 100K miles, or at least it is a safe bet that no one has that many. If you do purchase a reputable gasoline such as BP Ultimate, it includes detergents to keep the engine clean.
Old Apr 22, 2004 | 11:52 AM
apexer's Avatar
apexer
I have been using Redline at every fill up in all my cars for over 5 years. Just add enough for 10 gal. regardless of actual gal. purchased. From what I have read, even the bigger brands add a miminual amount of detergent.... just enough to advertise its in there. Why wait for the build-up?
Old Apr 22, 2004 | 08:13 PM
pocketrocketowner
Regular gas has actually the minimum of the cheapest additive for sure, though the branded guys will go for some differentiation, mostly they just meet the law. Premiums are in a whole different ball park. If what you are putting in from Red Line is not specifically designed to clean up CCD's.....whoever bought your car will eventually melt a piston......but hey, peace....whatever floats your boat is fine with me......
Old Apr 30, 2004 | 08:50 PM
zgokart's Avatar
zgokart
_______________
Have to agree with you, pocket.
Old Nov 9, 2009 | 11:58 AM
modbroad's Avatar
modbroad
Is fuel injection maintenance needed at 15k?
Went in for maintenance per the computer (I'm at ~17k miles, they said it is not called "Inspection I" anymore). My dealer, South Bay Mini, is recommending a fuel injection cleaner at 15k miles which costs $275.
In the past they recommended I get the tires rotated and aligned there. Fellow NAM people balked at the price when I posted in the forums and told me to go elsewhere.
Thoughts? Newbie here, please let me know.
Old Nov 9, 2009 | 12:39 PM
kazlot's Avatar
kazlot
If it's not running badly, and at 17,000 it should run fine, I would say to add some Fuel Injector Cleaner
to your gas tank every 6 months and wait another 83,000 miles before the $275.00 cleaning.
I do an oil change, tire rotation and add a bottle of fuel injector cleaner every 6 months.
Right or wrong it's what I do, and have done, on all my cars.
Hope this helps...
Old Nov 9, 2009 | 01:49 PM
ZippyNH's Avatar
ZippyNH
Some gen2 cars do have a build-up issues in the intake....but if the car is running fine, it sounds like the dealer I'd trying to clean out you wallet!!
Old Nov 9, 2009 | 03:17 PM
NightFlyR's Avatar
NightFlyR
+ 1 They are cleaning you out
Old Nov 9, 2009 | 05:07 PM
Boxcars's Avatar
Boxcars
oil change every 6 months,
bottle of techron and run only top tier gas,
runs great!!
boxcars
Old Nov 9, 2009 | 06:59 PM
searocko's Avatar
searocko
If you can afford the downtime, why not send in your injectors for flow testing and cleaning. Less than $100 and they'll be just like new.
http://www.witchhunter.com/
Much better than a bottle of injector cleaner and I doubt the dealer will be as thorough as this.
It's not worth it if you don't have access to another vehicle or the desire to remove your injectors to send them in. But this would be the most cost effective and thorough way to go.
Old Nov 10, 2009 | 09:50 AM
ZippyNH's Avatar
ZippyNH
runs great!!
boxcars
+1
Also Seafoam is pretty good stuff too....and BMW/MINI fuel cleaner, sold at the parts counter is Techron. BMW/MINI likes it so much, they resell it!!
Old Nov 10, 2009 | 03:36 PM
Bigshot's Avatar
Bigshot
As this is a 1st gen thread and you have a 2nd gen car, not all of the answers will be relevant. But there is a long thread regarding the carbon buildup on the intake valves caused by the direct injection engine. I believe this is what the dealer is talking about. Not a bad idea, but can be done cheaper with the seafoam.
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
gnhovis
Sep 28, 2015 04:07 AM
