Need help with short shifter installation!!!
I'm having a hard time disengaging the shifter cable from the ball-and-socket joint of the shifter. Is there a trick? I tried pivoting it while pulling, but without success. Which direction should I pivot the joint, toward driver side or passenger side?
Any suggestion is greatly appreciated!
Yeah dave, I had the same problem, don't worry about it, you just have to yank the crap out of it with the bottom joint with the ball directly over the joint. You might try using a small screwdriver or socket extension as a pull bar just past the connection point on the ball. Hope this helps just use some elbow grease my friend........
Nope, you could try greasing up the ball and joint with some lube or something depending on how crusty and old those joints are but I installed the PROMINI shortshifter and no broblemo, sure I bent those links but your not going to break them, you might even take them out of those to metal clips coming into the gearlinkbox up towards the front of the car. Try that and if that doesn't work you need to go down to a local petshop and look for an 800lb gorilla. That should clear things up.
If you happen top be local;to the SO cal rea Steve at Steves auto clinic has it down to a science. He has developed a special tool and they pop off the first time . Give him a call 818 891 6109 .He has helped out several bungled home attempts already. Its not a really difficult install but the small plastic retainer breaks easily and for what a shop should charge you its not worth the risk in my opinion.
>>Dan, Thank you so much for the huge "detailed" picture! :smile:
>>The 04 does look different. I'll take some photos while I'm down there under the car.
I went through the same problem. Here's how I did it. Grab the socket with pliers and 'spin' the socket on the ball as if you're trying to get it to spin 360 degrees. It should pop itself out once you go far enough. Prying it off is a bad idea.
Paul
Paul
Thank you for the advice, Paul! I'll try the spinning technique. :smile:
>>So Pilo's picture posts were a definitive help right? I like that in a supplier.....I'm gonna buy something from him.......... :smile:
Because th 04's design is a little different, I had to use a different point of insertion and position. Pivoting and rotating is the key to disengage the ball from the socket. :smile:
squawSkiBum
10-02-2015 09:21 AM
