View Full Version : Stock Problems/Issues
- 2003 mini cooper s
- a/c problem
- Timing chain guide / tensioner
- What Year Supercharger?
- Not Again..... :( - Cannot find what's wrong
- Engine Swap
- 03 S with the ASC Light stuck on
- Firm brake pedal but no brakes, high tick over
- Driver Door not "closing"
- clock problem
- Radiator Support Question
- My clutch
- ABS DSC TPMS Lights all on, but my brakes work fine
- Strange occasional thud or clonk
- '05 Xenon headlight self adjust broken
- Window - stopped functioning
- Protective plastic film peeling off door step.
- Weird power steering - a/c behavior
- Rattle above 50 mph
- My tail lights don't work on top
- FYI - Beware KYB strut mounts
- battery runs down - alternator vs. ????
- OEM Horn
- Cant remove oil pan drain plug???!!!
- 2nd Gear dead spot?
- Cheap power steering pump fix
- P0705 Transmission Range Sensor
- Breaking Mini Cooper S Starters. Please help!
- Engine Noise Rattle when Hot but goes away with A/C ON?
- AirBags
- diesel sound (r53)
- Low Speed Fan
- PS fan.....
- rear passenger endlink broke in half
- Definitive answer - Why AC and low fan stopped at the same time
- Mobil 1 Oil - Yet another Oil thread
- Hanging Idle IAC Mod?
- Wicked Exhaust Vibration
- P0411
- Help! Supercharger?
- Torn Air Box Duct
- Rear Oil Seal Failure, now Clutch requires replacement
- Replacing radiator fan
- Battery dead on 05 mini s..
- Strange things are happening,LOL
- Does a diagnostic tool locate short in electrical system?
- Wet Floorboard in 2008 MCS Cabrio
- Passenger side no longer unlocking?
- P2097 Post Catalyst Fuel Trim to Rich Bank 1
- Oil Pressure Light Problem. Please Help!
- Ejected Plug
- Oil Leak - Right Side Under Silver Cylinder
- Show Me Your Money
- 2002 Mini Cooper S "Power Saver" mode?
- License plate light
- How much would AC repair cost me?
- Car huffs and puffs at start up.
- ?Best place for OEM parts?
- charging system issue
- This came out when my dad was removing the oil pan!
- Serpentine belt replacement help needed
- Help - problem after t-stat change!
- HELP!! R53 cyclinder #2 misfire,out of ideas
- Headlight Leveling problem. NON XENON!
- Squeky Belt
- Replacing Key Fob Cover - 02-04 Models...
- Getrag 5spd service/fluid flush
- Window not going down?!
- Universal o2 sensor wiring?
- 1125 code only on highway.....new Thottle body needed possibly?
- What's that and why's there a hole?
- Clutch help
- Long Crank
- lock button on my key fob caved in
- Broken Sunroof
- Airbag/Crash sensor locations on front?
- R53 Graphic Vibration Description, HELP!
- 2004 Mini automatic transmission shifting
- my mini needs help!
- I got the service engine light
- Thoughts on BG ATF flush for the 6-speed auto
- ASC will not turn off (after firmware update!)
- Random blue tube???
- Wheel speed sensor removal? Stuck on tight!
- need an auxillary fan and supercharger valve for my 06 mini
- AC Coolant Volumne for R53?
- Are our cars only meant to go 50K miles???
- R53 overhaul, what else should I replace?
- ABS, Traction, Low PSI Lights Simultaneously Coming On/Going Off
- noise on start-up
- Am I in trouble or is this normal?
- 2003 R53 OEM Xenon Problems
- 2005 MCSa Shifting Issues
- window question
- SES, EML, and Tire Pressure light
- Rear wheel bearing replacement.
- A/C on makes it feel like less power?
- Loud rattle around engine bay
- Wet Feet
- after market exhaust
- Service Engine Light - Just got a new Power Steering Pump installed...connection
- Oil change problem.
- The ubiquitous rattle...
- Cracked Engine Mountings
- mini cooper s R53 thailand need help
- New to site 03 MCS Owner need help with PS
- HELP! broken dipstick - aargh!
- squeaky door hinges
- Recall in place for leaking Power Steering Hoses
- $1 reward: Engine Noise- shop called it "idler pulley" but I think NOT
- 2003 CVT transmission problems
- Creaking steering column fixed!
- Help!!
- 2002 automatic jumping into drive
- Whining noise when engine is hot
- 06 R53 Car wobbles on concrete-surface freeway.
- Random Starting Problem
- Do I need a new steering rack?
- Hello NAM; Have a slightly different PS problem
- supercharger
- MINI badge replacement
- replaced worn upper engine mount and upper stabilizer mount - ride improved
- Another engine tapping question
- Help! What is this weird noise??
- Two issues - clutch squeak and rattle - related?
- Question about exhaust on 2005 MC
- Leaking coolant hoses
- Need air conditioning compressor, not gold plated
- '06 Airbag Light reset
- window trim help
- Help>>> MSC Belt broke....
- Lift-Gate has Bubbly Rust along the Grip Strip
- Driver side window motor removal?
- Replaced OEM lower engine mount - ride improved
- Vibration only under acceleration
- Ticking from speakers
- Manual 06 Cooper Randomly Stalls
- 05 MCS AUTO TRANNY QUESTIONS
- Stock 05 MCSa Bad Gas Mileage?
- 3rd clyinder issues
- PS Pump Failure Cause
- 2005 s with tranny probs auto
- My 02 MINI is running hot.
- Power Steering Pump Fuse Loaction
- Help with A/C problem
- Steering problem- not the pump!
- Is these fuse blown?
- Rear Hatch and Central Locking
- Location of crank sensor?
- Why does clutch only make noise when it's cold and damp?
- My radiator fan is stuck on!
- Removing the Starter in a 2004 Mini
- Where is the steering position sensor located?
- '03 MCS FOB: Locks will not Unlock
- Whistling noise coming from under bonnet, YOUR EAR WILL CRINGE PLEASE HELP!
- possible purchase of 2002 Mini with blown engine
- Clicking noise when turning
- Transmission question
- New struts and springs?
- LEAKY SUNROOF REPAIR WITH PICS
- serpentine belt (R50)
- Seat Tilts Fwd OK but doesn't SLIDE anymore
- dead keys
- Groaning noise from Vents
- Couple of codes and symptoms (56k not fun)
- Excessive Stress Cracks
- Handbrake Trim
- Sunroof Supports
- Help! I need to know the size of this bolt.
- strange electrical gremlin, car doesn't start. ideas?
- Rain Sensors
- Service engine Light
- Toggle Switch Panel Not Working
- Hatchback problem
- Please Help me and my lack of car knowledge
- cheapest power steering cooling fan with shroud
- Ok, so whats gonna go next???
- Steering wheel won't lock, key won't go in
- Oh no, my first problem.
- R53 acting like an R50
- 05 "S" - Water in the battery compartment
- 05 "S" - Total power loss while driving - HELP
- i HAVE A PROBLEM
- help with on and off rough idle
- Where is my reverse??!!
- found what was causing code p1238
- water sill
- On Board Computer (OBC) Problem
- AC Compressor Oil and R134 capacity
- Rotational Noise at 50mph
- Gen. 1 is a little rickety?
- Is it possible for a steering rack to "break"?
- Third oxygen sensor install?
- Creaking Front Windows
- Manifold Air Pressure MAP senssor
- inertia switch/impact switch ???
- Loud noise
- Extreme Disappointment and a Transmission Problem-2003 Manual
- Labor Times
- Everything quits at 160K miles
- Is my car supposed to hum?
- Is this ticking noise the harmonic balancer?
- hmmm.... well that's definitly not right...
- Clutch Starter Switch?
- Roof/Rain gutters rusting problem
- Stinky A/C
- AC Blower Fan bad?
- HELP! MINI won't start!
- NEED HELP: Any ideas here?
- Mystery Part Help
- Hello and a couple vexing questions
- Rear Caliper Bushings
- cam timing chain replacment
- Oil pressure relief valve
- Unknown Clicking Noise Near Engine
- Hard steering-NOT THE PUMP! Help
- Half Shaft removal (drivers)
- AC Issues on my 2004 MC
- Sticky shifter in humid weather?
- Removing stuck lower engine mount bolt
- How do I take off the rear tail lamp assembly
- Strange Headlight Issue
- 06 catalytic converter
- Warning light question...???
- 05 Mini coupe differential Noise, Should I Wait?
- Passanger seat broken
- Seat Airbag Sensor Warranty? ?
- Sunroof sticking.
- Will 2002 SEAT TRACK work in 2004?
- DTC's P1109 & P0172 Any Ideas?
- Possible boost leak...need advice
- Slow coolant leak
- noise at high rpm's
- Car won't start....
- Aftermarket AC clutch?
- I want to start by saying thanks.....
- LIMP MODE
- Headlights
- When cold...
- Safelite Glass and rain sensor
- '03 issue anyone?
- Ready for spark plug change
- Right Rear Caliper Rebuild or Replace?
- I have a situation.
- Noob Question(s)
- Airbag light on Occasionally
- Fuel door hinge replacement?
- Help! Tach/display problem 1000 miles from home.
- Just Picked up an 03 S...Couple minor issues
- Another Oil Thread!
