LIMP MODE
Old Jun 1, 2010 | 01:14 PM
R53's Avatar
R53
LIMP MODE
What is limp mode? And does the MCS go into LIMP MODE when the tank's reserve light is illuminated?
Old Jun 1, 2010 | 02:08 PM
ZippyNH's Avatar
ZippyNH
Limp mode is when the motor determines there is a mechanical issue...and the engine determines it can run with reduced power....
If the Low gas light is lit...and you happen to get a limp mode, it is unlikely related...unless you are nearly out of gas....and that is what the light is telling you...very bad for the car...fuel pump, filter...you may be sucking up...and the fluctuations in fuel flow/pressure is giving the computer fits....it just a guess...but you should not really plan on running you car till that light is on (it is the "YOU ARE ALMOST OUT OF GAS IDIOT LIGHT")...the pump is gonna get hot...and you are sucking all sorts of crap stuck in the bottom of your fuel tank up....not good....
But to the best of my knowledge, it does not automatically go into limp mode....
wildwestrider
11
Jan 29, 2016 05:06 PM
potterstein
Oct 2, 2015 09:30 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
