PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Clutch Issue
  2. lil problem.....
  3. adjusting how much the windows dip
  4. My 2005 MCS conv wont start...HELP..i am freezing
  5. Dash Pad - Squeaks
  6. Please HELP: need a diagnosis possible bad clutch
  7. Loud THUD / Animal living in my MCS?
  8. Liquid on the ground
  9. Dropping rear subframe for realignment?
  10. Exhaust doesn't sound right after replacement
  11. One of those decades.. Tranny died. Thoughts?
  12. Multiple Problems PLEASE help
  13. HELP..how to change 05 daytime running light?
  14. weird clutch issue...
  15. 03 MCS Driver Seat "pop"!
  16. Cold weather overheatting
  17. Dash lights?
  18. Where to buy waterpump o-rings?
  19. overheating - not exactly the same as the other posts
  20. Key Fob Decal Question
  21. drives door will not open
  22. Where to get Window Parts?
  23. Power Steering Question
  24. Rubber Guard under Front bumper??
  25. MCSa Transmission Failure
  26. Cooling Fan and Temperature Spike?
  27. Urgent rear view mirror and locking help!!!!
  28. "tinking" noise from front passenger side. Axle? Wheel bearing?
  29. Noise from rear wheel
  30. just got 2002 cooper with 90k
  31. Cannot unlock doors with key fob or switch
  32. Blown Clutch Question
  33. FYI Frozen Gas Cap warning
  34. Uneven brake wear?
  35. What $3400 in damage looks like
  36. Mini windows whistle
  37. Stuck in gear
  38. Finding Vac / Boost leak
  39. Power Steering Dip
  40. Front bumper & underpanel questions
  41. valve chatter
  42. Blown Clutch!
  43. 03 Midlands trans died. Car for sale?
  44. Heater/AC fan motor replacement??
  45. mini cooper s with intermitten loss of electric
  46. clutch problem
  47. Car has gone haywire
  48. Steering Problems, please help!
  49. MCS R53, 6 speed manaul transmission problem. need advice.
  50. Darnit.. Running Oil-less.
  51. Aux Input Fails after 10-15 minutes 05 MCS
  52. need help with horn. there are 2 horns on the mini
  53. passenger door wont open
  54. HELP!!!!!!!!!!
  55. DSC Light stays on after going fast until restart
  56. The Bonnet and Boot badges are missing their black.
  57. Coolant all down the front of my block....
  58. clunky sound when twisting wheel side to side
  59. Differential Diagnosis: Thermostat vs Fan vs Other
  60. 5-speed Sparkle, Grinding type noise
  61. coolant leak
  62. Door Lock Pin Issue?
  63. R53 MCS Cold start rattle.
  64. OEM cup holder blows!!
  65. Help!! brake problem what next
  66. New Sidewalk Owner with questions
  67. OEM Lumbar Support is failing
  68. No idea, but problems, got codes!
  69. Starting Issue!
  70. Clutch, transmission or differential problem?
  71. glue fitting on vapor canister
  72. Where to buy tensioner dampener?
  73. Check gas Cap Light
  74. 2006 MCSC Leaking Oil Pan Gasket
  75. Car won't start.
  76. 2005 MC - Leather or Vinyl?
  77. Another BPV thread
  78. Acceptable oil consumption, again.
  79. 03/02 Front engine mount question!!
  80. Front Axle Issue - 02 MC
  81. Driver's Side Door Not Closing?
  82. 0-60 Problem
  83. 2004 Mini Non-S Noise
  84. Heated seats - blown fuse
  85. Headlamp Washer wont close!!!
  86. Rewiring under the seat?!
  87. Correct serpentine belt length for Cooper S? Found different sizes!!
  88. Questions regarding BC1 replacement.
  89. Anyone running Rotella in their MCS?
  90. R53...How do I change the Xenon bulb???
  91. Airbag sensor recall on 1st gen Mini?
  92. power steering gone, while driving?
  93. The penultimate straw...
  94. Auto Shop Could not Change Oil Filter
  95. Physically removing battery from '06
  96. Code P2096 2006 Mini Cooper
  97. Rear Wiper Spray Clogged
  98. disconnected OBD?????
  99. Trying to track down a noise
  100. 76k miles bad catalytic converter under warranty?
  101. 2005 MC (non-S) Belt Variations? (Kinda long...sorry)
  102. Gas door flew off
  103. rattle. with video.
  104. Help with Automatic Headlights; always on!
  105. check engine light
  106. Oil light on at idle
  107. Need a part number: 06 Hot Orange Pass. seat bottom
  108. arm rest not "latching"
  109. Supercharger Oil
  110. What do your oil filters cost?
  111. Battery/ Parasitic drain question
  112. Engine Miss at 70MPH
  113. can we switch speedometers between 05 and 03?
  114. O2 Sensor
  115. PLZ HELP...Air Bag light is ON!!!!
  116. HELP =[ multiple questions ugh
  117. red line, limp mode, then SES
  118. Noticeable play in the steering/suspension
  119. Dash Airbag light on.. need new entire seat bottom?
  120. Bleeder/cylinder/flush problem
  121. DRL High beams last longer than low beams
  122. Reed Valve Error P1477 (replaced pump already!)
  123. Lights Behind Temperature Controls
  124. Sub freezing starts
  125. strange sound
  126. My spark plugs at 53k miles
  127. Fog light not working
  128. Advice on accident damage repairs
  129. Signal and high beam problem
  130. Chugging/Sluggish Accel
  131. 02 MCS Tach problem
  132. Oil leak
  133. ABS and Tires Lights Simultaneously
  134. new engine at 80K?
  135. help with broken cooper s
  136. 03 MCS motor mount, strut towers
  137. Suspension issues 03 MCS
  138. Mysterious Whining Sound When Cold Outside on Startup
  139. shifting issues
  140. Temperature controls?
  141. Problems with minis
  142. Supercharger Seized up
  143. Cold weather, car won't start. Battery or something else?
  144. 2005 MCSa EML problem
  145. What color is OEM power steering fluid?
  146. SES light on and gauge reads 'NO CODES FOUND'
  147. Stripped oil pan drain on my 2004 R53.
  148. After years,DSC igintion retard causing carbon buildup on #4,throwing P0304 code
  149. 2005 mini has continuing oil pan leak
  150. Problem with CVT
  151. Problem free Midlands?
  152. Radiator Impersonating Pack a Day Smoker
  153. Help me diagnose a strange noise!
  154. Why do Mini's get air pockets in the coolant system from time to time?
  155. 30,000 mile service $550??? Seems high
  156. Passenger Airbag Sensor
  157. Divers seat height adjuster stuck.
  158. car not wanting to go into gear
  159. handful of codes, advice!
  160. Cold weather manual tranny problems?
  161. bad belt tensioner??
  162. Key problems in Northern California
  163. Auto Climate Control dead as well as MFSW audio buttons, Speedo and Dash lights out
  164. thermostat problems HELP!
  165. Occasional exhaust problem
  166. Rust Spots on Driver's Side Mirror?
  167. Backup Sensors not working
  168. planning to get leds
  169. My dealer just quoted me almost 2k to replace pump + sprcharger
  170. What is the part# for BPV ?
  171. Door Problems
  172. No clock after jump start?
  173. 2004 Antenna base snapped
  174. 2005 R50 Mini Cooper - hard to shift
  175. vibration while braking, vibration while Accelerating
  176. 2004 MC (non-S) Is My CVT Shot?
  177. Can't get it started
  178. computer show outside temperature very high than power steering stop working
  179. Driver side lights, not getting power?
  180. Outside Air Temperature Sensor Location?
  181. Rear end rattle driving me mad!
  182. Can somebody tell me where this oil is coming from
  183. Having an engine problem with my Mini! Help please!
  184. 2004 MC (non-S) Multiple Issues (EP Code, Car Running Without Key in Ignition, etc)
  185. Wheel repair in So Cal?
  186. Help! Headlights won't auto-level and can't figure out why!
  187. Car Leaning, tire rubbing
  188. Mystery part identification help
  189. Noise from drivetrain
  190. Digital display is off post-battery change
  191. Overheating Problem & A Solution
  192. Pre-Purchase Question RE Supercharger Life
  193. Hope that this NEVER happens to you!!!
  194. Interior lights cutting out ramdonly.
  195. starting problem
  196. Tensioner tool fabrication
  197. please help with airbags alert
  198. problems with my lights
  199. Cracked rear hatch handle? Anyone?
  200. coolant leaked?
  201. Plugs - 15% Pulley/CAI
  202. Power interruption when shifting to reverse gear
  203. What a wonderful mess!
  204. Just bought used Mini Cooper S (R53) - Not Very hAPPY
  205. Belt Replacement 2005 MCS part 2: Which Belt?
  206. bypass valve help
  207. HELP Dealer messed up clutch install
  208. Rear Wiper Intermittently Working
  209. Heater Issues
  210. tranny issues
  211. temp gauge issues?
  212. Disc(rotor) Retaining Screw
  213. CVT Transmission won't upshift
  214. new engine already!?!?
  215. Stuck on manual shifting?
  216. Window winter problem?
  217. Can you please recommend me a good mechanic in NJ for a Clutch Job for a Mini S 2005
  218. Can you please recommend me a good mechanic in NJ for a Clutch Job for a Mini S 2005
  219. Headlight module out
  220. Fuel Pump issues I think??
  221. Peeling Steering Wheel Vinyl - How to fix now that Minspeed is closed?
  222. Door lock question
  223. Small bump / thud when accelerator is applie
  224. Another major engine failure.......
  225. need help car won't start
  226. weird door lock question
  227. Power Steering Replacement Instructions
  228. Belt Replacement 2005 MCS
  229. tire noise; wheel bearing?
  230. Problem with the air filter box
  231. I have a serious problem.
  232. 2003 MCS Steering Tilt Mechanism
  233. P0303 misfire cylinder #3 Frustrations, plz help!
  234. Whistling sound with Recirc off
  235. Tranny DOA on Thanksgiving Day....
  236. Steering play
  237. Big, cold snow storm
  238. Clunking/Knocking noise from front end when cold
  239. SC status: Stoked!!!
  240. low oil level 4k mi' after oil change
  241. Cigarette lighter fuse
  242. VERY BAD! Differential bearing 02 MC! HELP?
  243. Light blue oil pool on the floor under engine.
  244. Knocking from Engine Bay behind Glovebox
  245. Engine support bracket snapped!!
  246. car wont start
  247. Transmission linkage issue?
  248. smoke out of hood scoop
  249. Starter not disengaging, easy to replace?
  250. Tiptronic CVT Gearbox Fault mode
