Engine Miss at 70MPH
Old Jan 13, 2010 | 07:31 PM
reddrockets's Avatar
reddrockets
MY COOPER IS A 03 jcw and at about 70 MPH my engine feels like it has a miss once in a while. what can it be
Thanks REDDROCKET
Old Jan 14, 2010 | 10:28 AM
lou's Avatar
lou
Have you checked the spark plugs? I would start there.
Old Jan 14, 2010 | 12:20 PM
Martin Brenneke's Avatar
Martin Brenneke
Check plugs,wires and coil. Try some seafoam in gas or techron in gas this may help with the miss.
Old Jan 14, 2010 | 03:56 PM
reddrockets
thanks i was thinking about getting the msd coil with good wires and plugs , have you herd any good with the msd coil......... Thanks G
Old Jan 14, 2010 | 03:58 PM
reddrockets
thanks i do use the good gas chev or shell have you herd any good on the msd coil i am thinking about msd good wires and plugs......... Thanks G
Old Jan 15, 2010 | 03:11 PM
Martin Brenneke
I have the screaming deamon coil on my 05 JCW with 8mm magnacor wires. they seem to work well. People say the stock coil is very good and don't need to get aftermarket one. Also have been hearing that Brisk plugs make a big change in performance of engine. RMW has them for sale.
Old Jan 15, 2010 | 04:44 PM
reddrockets
Thanks ill check out does the demon make a differnce....
Old Jan 15, 2010 | 05:26 PM
ZippyNH's Avatar
ZippyNH
An 03 with orgional wires might be due....the coil unless defective should not make a differance. IMO, do the wires....any quality set will do, plugs are due on a JCW at each service....so they might be the culprit, but a miss should cause a check eng light....safe to say you are useing 91 octane or better too right.
Old Jan 15, 2010 | 06:39 PM
reddrockets
thanks for the info i changed the plugs sh -- plugs i got where 14 bucks each but its ok the car runs goood ..... i do use 91 octane. im going to order msd wires tonight ....... again Thanks G
Old Jan 15, 2010 | 06:51 PM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
My regular 2002 Cooper was missing/hesitating a little at 70+ (60K miles, original plugs, wires, etc). I pulled the plug wires at the coil and two of them were slightly corroded.
Cleaned them up and it has been much better..
Old Jan 15, 2010 | 07:40 PM
Dr Obnxs's Avatar
Dr Obnxs
Speed doesn't matter
rpm and load is what matters. Anyway, I had screamin deamon and it made little or no difference. MSD looks better but I'd put it in the same category...
An occational miss will throw code P0300 (random misfire). It will be pending at first, and if it happens often enough, it will set the check engine light.
Start at plugs, then wires... A bad coil normally shows up at higher engine loads, but then again, anything is possible.
Matt
Old Feb 3, 2010 | 04:41 PM
reddrockets
i still have this miss after changing the wires and plugs and no engine light could it be fuel pump
devicemanager
Jun 17, 2016 06:18 PM
SunnySideUp
R57 :: Cabrio Talk (2009+)
Aug 26, 2015 01:16 PM
vanhick
Aug 19, 2015 09:03 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
minipopkart
Aug 13, 2015 05:22 AM
