valve chatter
Old Feb 3, 2010 | 10:58 AM
mikenacarato's Avatar
mikenacarato
valve chatter
my 2004 MCS has 75k on it. the valves seem a little chattery and im wondering if its time for a valve adjustment. any idea/comments?
thanks!
-mike
Old Feb 3, 2010 | 11:32 AM
ZippyNH's Avatar
ZippyNH
Have you checked you oil level lately? Not trying to be a smart azz, but I hope you have recently.
Old Feb 3, 2010 | 11:34 AM
mikenacarato
i changed it last weekend with royal purple 5w30 and a purolator filter, i checked the level today and its still fine. ive only had the car for 2 weeks so this could be normal for all i know.
Old Feb 3, 2010 | 11:46 AM
ZippyNH's Avatar
ZippyNH
Good oil......not so fond of the filter.
Next time I'd strongly recommended the OEM, Mann/Mahle, or even the NAPA.
It just makes me wonder....if it was not doing the before the oil change? MINI's do make some valve noise...usually when not enough oil is getting to the top end. I'd check the level ASAP to ensure that the gasket did not leak, letting the oil out. Do you have the Gauge package? is the oil preasure ok?
Old Feb 3, 2010 | 11:50 AM
mikenacarato
i dont have the chrono package. idk if the car was doing it before or not, i just noticed it when i had the radio off today. my next oil change will be in 2k miles and ill get an oem filter this time.
Old Feb 3, 2010 | 03:19 PM
herbie hind's Avatar
herbie hind
nothing wrong with posting a vid. or if you like just pull the cover and check the followers for breaks in the plastic . this is not unheard of . post a vid though to determine if maybe normal . it is a four and they can be noisy . plus the flywheel is very noisy so have some one push in the clutch while you listen and see if it sounds pissa then .
Old Feb 3, 2010 | 04:56 PM
mikenacarato
when i push the clutch in a little bith of the chatter goes away. ill try and get a vid when i can though.
Old Feb 3, 2010 | 05:23 PM
ZippyNH's Avatar
ZippyNH
I think I have the same sound....it is the dual mass flywheel most likely...there are a few vids around of the sounds...eventually it may get bad, and sounds like "chewbacka". But in the meantime, if it does not slip....I would not worry about it!! Still post a vid....and if you have help, with the clutch out, and in!!
Old Feb 3, 2010 | 05:25 PM
mikenacarato
well the clutch definately doesnt slip, but ill try and get a vid or two up for ya.
Doc Pain
Mar 10, 2021 04:50 AM
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Emnotek
Sep 29, 2015 07:37 AM
