Power Steering Dip
Power Steering Dip
Hi guys, every time I turn the wheel at a stop to make a turn, my idle drops almost half way to 0 on the RPM gauge. I did my manual transmission oil change with Redline MTL and that is when it started to happen. I don't know if that has to do with the power steering dropping really low rpm. And my car shakes really bad when the rpm drops when I turn.
Please help.
Please help.
Power steering is electrical...
that said, it's drawing a lot more current when turning and the alternator is creating more drag.
Since it started when you changed tranny fluid, look to see if you knocked any electrical connector loose. I don't think different tranny fluid would cause this effect.
Matt
Matt
I've checked everything and looks good. But I also accidentally put in the autozone power steering fluid which I should check first to get the right one. So do I need to flush out the autozone power steering fluid and put in Pentosin CH11 fluid? Plus my SES light is on. How do I clear that?
Thanks for your help.
Manny_cooper
Sep 10, 2015 11:09 AM
Aug 25, 2015 09:33 AM
minipopkart
Aug 13, 2015 05:22 AM
