View Full Version : Stock Problems/Issues
- Boot light on
- Roof creases
- Clutch!
- This may be a stupid question, but...
- Alta vs MiniMania Pulley
- lost mileage on odometer
- Calibrating the Gas Gauge...
- Rotor Bolt Stuck!
- Part Change for the Crankshaft Vibration Damper
- Power Steering Woes
- Electric AC Relocation
- clutch cylinder
- Overheating at extended idle, fine while driving?
- 05 MCSa Exhaust not as 'loud' as manual car?
- UK JCW Air Box for MINI
- Stripped Air Box Screws
- 2005 Mcs Issues With Top
- Electronics Module shorted
- I loss power up to 3.500 rpm
- weird window problem
- Is my Power Steering out???
- Battery ? for 02 early 03 owners
- 0w40 safe?
- squealing belt, pulley on startup???
- Battery light - charging circuit problem?
- When do I get a check up for my new engine?
- Louisville mechanic
- mobil 1 5w-50
- Intermitent Idle
- Pulley - Better or worse mpg?
- worst smell ever
- Engine light on solid. No service until after long weekend. Am I okay?
- 2005 MCS Automatics
- Washer fluid not spraying
- Random Static Sound from Speakers
- Xenon Failure
- Collapsing Hose?
- Ultrik/K&N CAI...
- Wiring Questions for you Smart Guys
- How's your clutch wear??
- Replacing drivers seat under warranty?
- Rhino ramps and a lowered S??
- Changes to setup?
- Wheel bearing recalls???
- JCW Intake Installation Questions
- MCSa related issues
- dealer didn't check comp for errors during service?
- Brake bleeding question HELP
- Possible Transmission Problem--What does this mean???
- Mini Engine
- DSC/ABS functioning normally?
- How important is the splashguard???
- Which Aftermarket Supercharcharger Pulley Size?
- MCS Supercharger vs JCW Supercharger
- Battery died...again
- Oil filter socket idea
- MC, 1st gear, 3k+ RPM.... Nothing
- Whinning Sound
- Testing the Ignition
- growling?
- Magnussen-Moss Act Lawsuit
- cylinder head differences - s vs cooper
- Scoop foam deteriorating.
- Front-end Shake, Wobble and Thump
- Drop link stud size?
- intermittant DSC light, simultaneous power loss...
- Noise in engine compartment...
- Wanted: Correct PN#
- Wet seatbelt !!
- clutch gone after 1yr
- Reverse light out
- Another Unichip Question!
- Programming Features Myself
- blue radiator filter appearance
- Loud squeak at ignition and clutch engagement.
- Greatbears MINI Advice
- Cleaning off radiator...
- whats this sound (short vid)
- broken dipstick, in the hole
- Look what hit me in the foot while driving home tonight. Anyone know what it is?
- Help
- Power Steering dead? Need Skilled Advice.
- Gas recommended for MCS
- Error code P0420
- help electrical problems?
- oil question
- California Rear Fog Light Activated ?
- New Found Power
- MCS Software config, ARG!
- Leaky Antenna. Please Help!
- FYI: Service Engine Light Reset
- Sheared Strut Mounting Bolt
- MCS Chrono Pack Temp reading
- Service engine soon light code p2270
- power stering pump overheating
- Shaking above 60mph when pressing on the throttle
- Oil filter specific socket.
- Denso Iridium = Smoother Ride?
- DSC questions
- wipers go click!!!! anyone seen this?
- Can anyone list the fans and electric motors
- Mystery Sound
- Dead Door Lock
- replaced clutch fluid
- If you have money to burn!
- Oil change before next race?
- Short Shifter seems loose
- any ideas?
- The ultimate diagnostic for Minis...
- 1st Service @ 12K Miles
- Flat tire/DSC warning lights on & off ?!?!?!?
- flywheel/noise again! what to do
- CRAP! No Brake Lights!!!!
- Apexi Super Ground System
- 9mm or 15mm Catch Can?
- A Miss????
- Reset Procedure for ABS, DSC, Flat tire Indicator
- Throttle/Accelerator Sticking
- 'Hey Horn' install
- Low Tire Pressure
- Where is the cabin air filter?
- Oil change in NH?
- Supersprint exhaust
- Turbo Mini Cooper.
- Why wait, get it fixed NOW
- MCS problem, driving fine then just stalls...
- first time in the shop for my 05 MCS
- Pulley Risk?
- Tranny Trouble
- Battery Safety Terminal Self Destruct
- Improved Silver Door Pulls?
- Are owners w/ JCW kit equiped cars experiencing the same *common* issues...
- Engine Oil Leak
- How far does your brake pedal travel
- Engine Cut-out
- does auto still have power?
- Alta Intercooler Air Diverter Spritzer
- Mystery Ball Bearings
- A/C whine
- SES and ASC Lites on After High Altitude Motor
- Shark Injector
- What CAI for '05 MCSa
- one dead MINI...
- Alta intake hose question.
- yo yo idle and dealer reply
- Bad brake job?
- ac odour
- How to clean my alta intake's foam?
- Anyone with 05 vent issues?
- "Loose" Drivers window in '05 MCS
- High Idle
- CNG MINI Cooper's ???
- Starting MCS problem
- Fuse for console and trunk 12V outlets
- Scroth Harness Install
- P2097 code = ??
- Major MCS Problem...Help!
- Transmission/Clutch Problems
- Squeeeeeeeak
- Intermitant Air conditioning Problems
- Broken Door release
- Something rubbing me wrong
- New Brakelines and Bleeding Brakes
- bad speedo? anyone else?
- suspension squeak?
- Newb. question about driving lights
- Beep Beep
- weird clunking noise..
- Window help!
- Programming New Speedometer
- Sputtering
- What is wrong with my MINI?
- Timing belt or chain on the MCS engine?
- Can you put newer ECU's in older MINI's?
- Will I lose the "burble"?
- I need help! Alta pulley/belt question
- Who has the highest mileage in a MCS?
- Rev limiter removed
- squeaky clutch pedal
- My Car is grumpy
- Weird things during start up..
- Getrag 6 Speed Interchangeability
- I almost got in an accident
- Has anyone here done your clutch replacement?
- WTF??? mini makes weird noise
- Help! Intake hose clamp
- No Soot on 2005 MCS Exhaust Tips?
- ecu CAN
- Break in blues....
- Fan won't shut off
- Ecu removal
- warranty terminus
- Engine Whine/Moan
- Stupid ECU?
- ac control panel went out..I have the fix
- Water condensation on underside???
- Chewbacca in tranny?
- MCSa ecu V42 update
- Wierd
- E85 Gasoline
- BBK upgrade mania
- engine service soon light
- Is this part needed with Dinan Intake?
- exhaust heat shield bolts
- Mini Fault Code List
- Service Engine Soon Light
- How many are waiting for backordered M7 oil catch cans?
- 20hp for the cooper
- Battery was dead
- Electrical gremlins - help
- Mystery Dripping Fluid
- Mystery Part Images
- Feeler, replacement intercooler boots.
- Cleaning Bonnet Stripes
- Injector Clean at Inspection#1??
- AC whine
- boot door/hatchback problems
- Windows stick
- 100,000 Mile Club
- how long does the check gas cap light remain on?
- 5-30?/5-40?
- Any suggestions...?
- P1226 and Throttle body failure?
- HELP! Power steering going out
- Stuck Oil Filter & Drain Plug
- Oil Temp
- v42.1 flash and car won't start
- Flood inside my car!
- Flap not opening on JCW Intake?
- A/F mixture from STFT and O2SV
- Pinging Problem
- Are the modders saturated?
- Supercharger whistle or ...Something, After Download.
- Error Code p1688
- Bad belt squel after 15% install
- Broken Valve Spring
- From heaven to ... :(
- If you are thinking about getting a crank pulley..........
- Is this a Problem?
- Break-in limit of 90 mph????
- HELP!!! Hissing noise while driving.
- Code p1498
- Dinan Intake Questions
- Brake light mod/rear fog issue
- Odd Brake Light Problem
- Frontal Area and Drag Coefficient
- WTB Micro Filter
- Water Temp. Sending Unit Help Plz
- clunk in transmission
- LOUD dash buzz/rattle
