Reset Procedure for ABS, DSC, Flat tire Indicator
Old Aug 12, 2005 | 07:22 AM
Tder's Avatar
Tder
I believe i lost one of my sensors yesterday... Not sure if it came back, but the car seems to be running fine after a brief lapse of its head when this happened. If i understand correctly it sounds like a wheel sensor or some other sensor had a fault which caused the ABS, DSC, and Flat Tire indicators to illuminate (which they continue to do) and if the fault was temporary I should be able to reset this by turning the key on and off 3 times. I tried but the indicators are still on.
I wanted to check if there was any trick to the sequencing of the key turns or if it looks like a sensor is gone, but the ECU has chosen to ignore it or readjust since the car now runs fine.
No real big deal since its under warranty, but thought I would dig into a bit on my own before taking it to Mini of Peabody.
Thanks!
Old Aug 15, 2005 | 05:13 AM
mattcoon's Avatar
mattcoon
The ABS will reset itself when the failure is corrected. Since this car is sold in europe, it complies to ECE13, which means that a good test must run before the light can turn off. If you have a wheelspeed sensor fault, after that is repaired, you only need to drive and the fault will reset itself. I've never heard of this 3 ignition cycles business for ABS only on engine ECUs.
woodstudio
Mar 15, 2020 08:28 AM
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
romansmini
Aug 25, 2015 11:57 AM
kyungmanpark
Aug 23, 2015 07:26 PM
