View Full Version : Stock Problems/Issues
- EML light episode
- Turning off car -- supercharger
- software cost?
- WHen should spark plugs be replaced
- Low Beams went out??
- The Single Best Performance Mod!!!!
- Looking for an exploded-view drawing of the MCS engine...
- PULLEY INSTALL:IMPORTANT INFO
- Codes
- Bucking or Trans Slipping on take off?
- Power steering fluid disappearing...no leaks seen, where is
- Engine vibrations, resonance, reduced gas mileage... ideas?
- CVT Problem
- Clock display goes dark or flickers
- Dealer installed 04 Cooper alarm system
- Throttle response on shift
- Did v36 disable your DRLs?
- Anyone using Redline tranny fluid?
- pinched hose problem
- Where are 36mm SHALLOW sockets?
- The Yo-Yo Chronicles
- Steering Wheel "Click" on 2004 MINI's
- Cobwebs in my headlight!
- Found the Rattles
- Soot and MPG worse with software v. 36?
- Bulb Size ?
- General warranty questions
- Brecht has german V36?
- Process For Aiming Front Fogs?
- v36 & 15% pulley
- Oil Filter Questionaire - Please Help
- Which Exhuast, Pulley, Spacers, Air Intake??? -----> Recomen
- Aiming headlights
- Unhappy Clutch Noise (Cold Weather?)
- What ver. of ECU software do I have?
- Tech question about alternator
- Dealer Service Techs are freakin brilliant.
- Service Engine Soon Light
- Cooper CVT idle speed
- Tornado Fuel Saver in the MINI
- 36°f beep warning?
- Oil Filter Nightmare/Question - Engine Almost Blew
- Mini stalls while driving
- To weld or not to weld?
- Coolant flush..how to?
- Help! An animal chewed up my plug wires!
- Good MINI Spec?
- Pulled timing on winter gas/bone stock
- Computer button controlling my winshield wipers?
- Ahhh... WTF?
- Poor Mini is sick again
- Changing brake lines.
- Bees in my car....
- Stumble: I have a request
- Whine at 2200 RPM, not 2100 or even 2300 but right on 2200
- Has anyone captured AFR readings from v36 ?
- ENGINE TREATMENTS
- Automatic Air Conditioner Conversion
- Fault Code Reader and Service Reset Tool
- JCW S, Valve noise at startup
- Stumble, but different??
- How can you find out the s/w release that is running in an M
- Sandy Shifter?--need help...
- Complete Coolant Loss
- Does anyone know is the new softward fixes the stalling prob
- Upgrade software to V.36 or not? That is the question
- dash lights are gone
- oil change interval
- Battery Light flicker??
- Auto AC question
- Turn signal flashes on hard cornering!
- Cold weather and Xenons
- Noises in 2nd gear
- Do the 2004 MC/MCS all come with v36?Are they "fixed" and st
- buzz from passenger door bezel while windows open
- Is the "regular" Mini more reliable/practical?>>
- How long does it take a dealership to flash the ECU to the n
- Oil Pressure guage
- PROBLEM WITH WARRANTY
- Potentially Dumb Question
- Voodoo steering--Pirellis or is something amiss?
- Rhythmic tick from passenger side rear
- STUMBLE IS GONE!!! v.36 software actually works!!
- VERY irregular idle, stalling - cold weather related?
- Too cold to shift!?!?!?
- Windshield trim Piece
- THANK YOU - FLOW MINI IN WINSTON SALEM, NC
- valve lifter noise
- erroneous computed MPG (and therefor range) figures
- YO-YO FIXED? READ THIS REVISED POST (P.P.S.)
- Automatic Climate Control
- Headlight removal
- Head Gasket replacement Anyone?
- CD 36 has shipped!
- Mini Buy-Back Question
- Outside Temp Gauge Blinks and Beeps
- Interior Heater/Auto AC/Heat
- Deltran 'Battery Tender' vs. BMW's Battery Tender
- My clutch rings!
- MCS exhaust on MC
- Clutch noise
- Power train concern? Or something Im not aware of?
- Hella horns
- PCV valve vent/general oil question
- Blinking Oil Pressure Light.
- reverse gear clicking
- Who has changed their fuel filter?
- Mini Service Bulletins and or Advisories
- Cut out exhaust sound? ACCOMPLISHED YAY!
- Engine oil accumulation in the intercooler
- CarChip Data Logger
- License plate holder - where to get?
- ECM ver.36
- It's hot in here.
- Signal Light 2003 MCS
- Trouble with 3-2 DownShift?
- Philips 'Vision Plus' H7 Bulbs
- B&M Short Shifter Install
- Dead Battery
- Revisiting an old topic
- Tapping sound above 3000 rpm, mild to heavy acceleration
- White Light Bulbs
- Spark plug torque spec?
- Burning clutch
- rev counter
- GPS malfunction
- TOWED, UGH!!!
- Road Runner Horn
- Method to fix stumble-maybe
- Cold + Brakes = Squeak?
- Anyone else have a mcs that takes 5+ quarts of oil?
- no ac and ps!
- Redline oil
- Trick to remove wheels?
- MCS- High-Beam Xenon Kits
- diming lights
- Electrical Problems /or just a ghost
- fuel question?
- CVT and new plugs.
- Badging
- Mixing 90/93 OCtane
- Sudden, Total, Temporary Failure to Start?
- Getting new sparkplugs...questions
- I'm a dipstick dipstick
- Changing Oil
- How often should spark plugs be replaced?
- Wheel Size and Performance
- Squealing Belt
- I am a NSCSC member
- 26,200 miles 2ed oil change
- HELP! Interior display/heat did not work
- Rack and Pinion REPLACEMENT
- Replacement air filter for an MCS ???
- Replacement windshield wipers...
- WHERES THE CHEAPEST PLACE TO BUY OIL FILTERS, ENGINE OIL?
- Strut Brace lowdown.
- Battery Relocation kit
- Whistle in '03 Cooper (base) when cold
- Horn hunting
- Slips out of second
- Madness Short Shifter
- Xenon adjustments....
- What is the best ECU chip or upgrade available.
- Aftermarket Exhaust?
- radio died...suggestions beyond checking the fuses?
- Clicking Noise from Steering Wheel Column
- Stumble - tired of waiting!!!!
- Software Version 36
- Oil Change question...hmmmm
- Screeching noise when shifting
- Rev Limiter?
- Radio Station Mystery
- Battery Charger
- Why can't we buy the JCW kit for the Cooper here in the U.S.
- newbie--where to start?
- 24 hour time displayed on clock
- Is the Mini Motor same as Dodge Neon?
- Is it possible to change your oil too often?
- New software installed - stumble gone!!
- Oil Change Caution...Ouch
- The RATTLE from H---!
- My car stalled, and it's a CVT!
- MINI maintenance indicator (or whatever it's called)
- Winter-time question
- Why the large pulley?
- SUPERCHARGER QUSTION
- Weird screechy sound
- More problems with my 02 MCS
- Oil Filter Socket
- HID headlight alignment off!
- New guys .... Question plx
- removal of the antenna
- Dealer says [there is no "stumble." There is only "hustle,"
- Help! Boot/trunk will NOT OPEN!!! AHHHH!!!!
- Loose hood scoop
- How fast can you make it?
- Trim fell off!
- how long does the bonnet stripes take to show wear ?
- Installed air horn, "service engine soon" light on -
- Driver and Passanger Window Squeak
- A/C Fan stopped working
- [Case Closed] Spark plug wiring order...HELP!
- Funky Electronics
- Mini Cooper MkI horn-push assembly
- Has NE1 changed horns in their mini?
- Lapis Blue Leather- Lumbar & Durability
- The mystery of the jumping speedo needle
- Emergency Brake Unlock
- 3/03 build - what software CD ?
- Engine Dead!
- Aftermarket Metal Skid Plates & Oil Changes ?
- front seat removal from sliders while still in car?
- Running wires thru firewall---where?
- Stuck on the road putting half a quart of 5w 50 Synthetic in
- I need uhhhh... a replacement fuse box cover...
- Passenger door lock acting funny
- Best place to tap/tee into for boost guage?
- Maximum oil pressure?
- :: stumble F-I-X-E-D !!
- Is there an Online Parts Manual?
- Rear hatch rattle fix??
- MCS Shop Manual PDF, Door panel removal
- newest software?
- Transmission Gone 21K Beware!
- Really weird sound after shutoff is freaking me out!
- TORX screwdrivers
- Stumble Threads Collected
- Wrong Gas
- Exhaust Manifold heat shield resolution?
- MINI ECU Software, dates and mods
- A RECALL MIGHT HAPPEN SOON!!!!!!!!!!!!
- B&M SHORT SHIFTER
- Sold MINI due to stumble problem which is a safety issue - y
- how do I reset my oil change reminder?
- Why is my car ticking?
- Help on removing a damaged bolt
- Tire Pressure warning indicator
- Speedometer, gauges clicking in parked car
- Brake pad wear
- Is it okay to change the oil without changing the filter?
- Fluid Levels_Growling noise.
- CD35 is out, will it fix stumble in COOPER S??
- Xenon light question
- Coolant tank leak on my MC...
- Mini Cooper S engine oil
- Loud click/tick upon descel or asceleration.
- AND ANOTHER STUMBLE FORUM...
- Oil change interval mystery....ooooooohhhhhhh
- Has anyone else developed a Cold Start issue?
- Irregular idle when AC on
