PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67
  1. pls dispeal this rummer, help
  2. Help with DSC
  3. Radiator Core Support on backorder
  4. Dead battery
  5. Help PLEASE! Strange smell coming from engine!
  6. SES light after installing pulley
  7. 05 MCS Dipstick
  8. Map/BARO Sensor Errors
  9. air sensor gone bad
  10. Oil Question-Extended Life
  11. Popped a CV
  12. Are S & Cooper throttle bodies the same?
  13. B & M SHIFTER INSTALL 04 HELP
  14. Annoying vibration after installing Milltek Cat Back Exhaust
  15. Anyone tried a G-Box Performance Module?
  16. rev limit reduced
  17. Oil Temperature ??
  18. Trouble Code P0335
  19. Oil Change
  20. Anyone do their own Coolant flush???
  21. Service Engine Soon Light
  22. M7 180 degrees Thermostat
  23. Headlight washers
  24. HP defined? A little help please
  25. MC vs. MCS software issues?
  26. Pulley Party Anyone.....
  27. Oil Filter Wrench
  28. Cooper S won't get up steep hill!
  29. noise when I shift, normal?
  30. OBD II Scanner Actron CP9125 - any good?
  31. Spark Plug gap???
  32. Can existing keys be re-programmed to be used in another MINI?
  33. Choppy idle & results of emission recall
  34. Spark plug how to
  35. Sorry if this is a duplicate post
  36. Exhaust temp
  37. Engine stalling...service light?
  38. Dead battery or something else?? Help.
  39. Brake Fluid Change
  40. 60,000 mile service ???
  41. Easy HPs
  42. '05 MC/MCS gearing change???
  43. Airbag Warning Light Problems
  44. DSC failure
  45. changing oil after winter storage
  46. Cat Failure!
  47. uh oh somethings wrong!
  48. Do not use this Oil Filter.
  49. Smoking?
  50. rattling sound from front when in idle
  51. Door and boot locks in wet weather
  52. Ben Fer Performance Carbon Fiber Intake
  53. Hot Stick Shift
  54. Windshield Crack...
  55. Is there suppose to be a gap between the plastic fender trim and bumper?
  56. 2001 MCS In Eurotuner Magazine (hp talk)
  57. Coolant Splatter
  58. Is 10w40 a good long term choice ?
  59. Help! Lights flashing randomly while key is out!
  60. ABS Problems??
  61. Preping the MINI for cold weather use
  62. tacho timer display
  63. Oil Temp Gauge Not Working
  64. Where is PPG glass in the bay area???
  65. Need airbag diagnostic tool
  66. Power steering fan/radiator fan problem
  67. Driver's Side Door won't lock
  68. 2005 MCS - throttle responds (lack of)
  69. Ticking noise at idle
  70. wiper motor
  71. Seat Tilt Problem on '04 (I've done my research)
  72. Pulley removal tool
  73. Got 240 miles on 05' MSC, and I get about 17.5mpg. Is that too low?
  74. What is this between the two Coolant Hoses?
  75. Car won't start- trouble code PO335
  76. Do you own your ECU?
  77. im hearing a rattle/static but can't isolate or reproduce
  78. HVAC Control help!
  79. Speedometer Calibration
  80. Codes for DRL, auto-lock, etc...
  81. My MINI is broke :(
  82. Coolant Leak!
  83. maintenance indicator reset for 2005 Mini
  84. 19% Pulley But With 5500' Of Altitude......
  85. Alta Drop In Air Filter
  86. Noises Coming From Motor - HELP
  87. Hard to start car.
  88. When do u get ur first oil change?
  89. Best Synthetic Oil - New product
  90. Power loss, oh no . . .
  91. 05' headlights
  92. distinguishing S from non-S cylinder head
  93. PPG windshield people please read
  94. Bonnet Stuck
  95. OBD2 scan tool on Mac OS X?
  96. Manual on CD
  97. Educate me about air flow into our cars...
  98. Compressed Air
  99. Oil Cath Can Install Guide?
  100. Oil consumption during break in?
  101. Loud knock after turning the car off
  102. Installed some new goodies today
  103. Radiators
  104. 2005 Windshield Cracks, Raise your hands!
  105. Your Last Service
  106. Inexpensive OBD II scan software
  107. Mainline MINI mod tolerance?
  108. MINI Cat OBDII?
  109. Painting arches
  110. Just Flashed my car with Cooperworks Software
  111. Check Engine Light question
  112. I'm an idiot, I can't even change oil!
  113. Service Campaign?
  114. Airbag light, OBD tool, Pocketlogger...
  115. What to do next?
  116. Promini Air Intake for Cooper - Has Anybody Installed It?
  117. If you had $500 to spend on your car......
  118. Painting The Engine Covers...
  119. Rumble from left front side
  120. What's the current (March '05) software version?
  121. New ECU? codes necessary?
  122. Engine code scan & reset
  123. Water on the inside of the windshield
  124. Remote key not working
  125. Deep subject
  126. Blown Spark Plug
  127. Boost Guage
  128. Error code 1237 help?
  129. MFSW options for an '02
  130. 25K Service: What to expect?
  131. Switching Transmissions...
  132. oil pan screw stripped
  133. rear wiper fluid refill
  134. Lifts for MINI??
  135. K&N
  136. Slight loss of power at 2500-3000 rpm?
  137. Rear Main Seal leak?
  138. HELP Mini Stalls on Sharp Turns....
  139. There are no Excellent Writeups for brake jobs!!!
  140. Busted power steering fan?
  141. front brake grinding noise
  142. 3rd airbag light!
  143. Busted my steering rack
  144. LightWeight CrankPulley anyone?
  145. DSC, active vs disabled?
  146. Winshield chip repair
  147. Denso Iridium Spark Plugs- where 2 buy East Coast?
  148. Door Lock Regulator
  149. Disconnecting the battery
  150. Windows are down....
  151. Oil Catch Can
  152. possible axle problem? clicking in front tires
  153. Factory LSD in snow...
  154. whats the deal with the LSD
  155. MCS hit, parts found on ground HELP to identify...
  156. MINI Driveway approach angle?
  157. speedo indicator light questions
  158. Washer nozzle leakage?
  159. Cooling Fan Won't Stop
  160. Throttle response
  161. New software to fix the latest?
  162. Can upgrading fuel octane cause some knocking as well?
  163. Yo-Yo Problem
  164. Noise and MINI's solution
  165. Exhaust Question???
  166. "Neutral Switching" Question
  167. Rattle from plastic, bottom of rear side window?
  168. Bentley manual for 05 Cooper
  169. Caution Light and Tire Light ON!
  170. cruise rpm
  171. Cold Range Spark Plugs?
  172. 2005 Windshields
  173. Manuel transmission or automatic
  174. Poor Man's JCW intake?
  175. How can I know the model of my mini
  176. I have another case of Gremlins
  177. Blowoff Valves?
  178. Vibration betw 2k-3k
  179. 05 MCS Dash Rattle That's Really Loud
  180. Oetiker clamp tool?
  181. "Smart" Software?
  182. 89 Octane for long 8k miles trip?
  183. fuel guage probs
  184. AC light flashing when fan is on
  185. What Kind of Coolant
  186. Service question: Can a BMW dealer service a MINI?
  187. Shift Cable Part Number
  188. Error Code: 5E19
  189. Fault Code P1498
  190. mods for increased fuel efficiency?
  191. belt slipping in extreme cold weather ????
  192. Driving Light bulbs
  193. ECU reset question
  194. Clutch Ajustment?
  195. Outside Temp display blinking!!!
  196. Now up to V.40?
  197. Need new tranny....possible upgrade?
  198. Burnt Smell?
  199. transmission noise
  200. DSC Retrofit????
  201. Fixing a Broken Wheel (D&R MINI Warantee)
  202. Anyone experiencing SES with v.38?
  203. Changing Belt on MCS with 15% pulley
  204. Anyone replace a front turn signal lens?
  205. Ghost of Lucas
  206. Doors!
  207. Would a dealer still install a JCW kit if you bought the kit from a different dealer?
  208. cold weather complaints
  209. removing air filter for cleaning
  210. High pitched squeal in super-cold weather!
  211. modded Mini & service delima
  212. DME Programming RECALL for Emissions Tank Leak?
  213. Pulleys and Things related...a continuation
  214. Mini Cooper Sport Exhaust
  215. MCS Paddle Shifters??
  216. Aero Grills and driving lights
  217. High pitched noise @ 70+ mph
  218. Restarting ECU/Main Computer how?
  219. coolant leak again
  220. Impact Air Wrench
  221. DSC light at 6,000 RPM?
  222. Airbag light again - past warrenty
  223. Front strut socket
  224. help! frozen gearbox!
  225. Oil Light After engine down more than a quart...?
  226. High-mileage CVTs
  227. Pop Pop Pop...?
  228. Intermittent heavy steering...??
  229. front window panel/column cracked???....help please
  230. Why do MINIs emit so much "smoke"?
  231. How can someone determine the version of software on a MCS or MC?
  232. Bonnet heat sheld
  233. need help with boost meter
  234. 28 mile old smoking engine
  235. Steering Clunk - Normal?
  236. MTH vs Unichip
  237. Blown tranny seal update
  238. So after all the software upgrades... Who's car is still stalling?
  239. Starting the MINI
  240. ??? Version ECU Programming
  241. New software fom BMW
  242. windshield crack
  243. DSC light comes on with hard accelleration
  244. mini problems?
  245. Tranny seal blown
  246. Heater smell
  247. Two steering wheel issues
  248. Oil/Fuel additives
  249. HELP Unichip
  250. Gremlins in the water
