whats the deal with the LSD
Old Feb 20, 2005 | 05:06 PM
wkndracr's Avatar
wkndracr
I have an 05 mcs with the LSD. I always thought on a LSD equipped car, when you spin one wheel in one direction, (when the car is on a lift) the other wheel will spin in the same direction. This is true with the LSD on my 91 entra SE-R, and others i've seen on hondas. On my MCS the other wheel spins in the opposite direction of the wheel you're spinning, like on an open diff car. So what's the deal? Is this how its supposed to work, or did they forget to put it in my car? Who else out there has an LSD equipped car that they can test with?
Old Feb 20, 2005 | 05:25 PM
JeffS's Avatar
JeffS
On all of my LSD cars, the wheels spin in the opposite direction. The only exception to this was when I was using a clutch-pack style differential.
To the best of my knowledge, all gear-driven differentials (lsd or not) exhibit this behavior.
Old Feb 20, 2005 | 05:37 PM
RUKnight's Avatar
RUKnight
The LSD in the MINI is clutch based so the normal test that works with gear based differentials doesn't work. If you want to test it out do a hard slow speed left or right turn and punch it. My 05 will light up the inside tire doing this maneuver since it doesn't have a LSD in it
Mike
Old Feb 20, 2005 | 08:15 PM
wkndracr's Avatar
wkndracr
ok, thats good to know. I've tried testing it by punching it a little in 1st or second gear coming out of a tight turn and i still get some wheelspin, but i'm not sure how much wheelspin to expect with the LSD. My sentra doesnt make enough power to be able to spin coming out of a corner. I guess the real test will be at the first auto-x. My 03 would have a real hard time putting the power down, but i havent driven the 05 like i'm autocrossing, yet:smile: . Thanks for the responses, guys.
Old Feb 21, 2005 | 09:33 AM
Jdewey's Avatar
Jdewey
Lsd ?
I don't know where you live...
Put one wheel in the snow, and one wheel on the pavement. Accelerate hard. If the car moves out of the snow, you have some kind of improved dif. If it sits there and spins, you have an open diff.
You could also try wetting down the pavement if it does not snow where you are.
This is essentially the same as the hard left turn test listed above.
John
Old Feb 21, 2005 | 10:02 AM
D1JL's Avatar
D1JL
A clutch type locker should work the same on a lift. The clutch is designed to hold both axels together and only slip when cornering. This is the way the “Trac-Loc” works in my Mustang.
Dave
Old Apr 6, 2006 | 08:00 PM
GREY MATTER's Avatar
GREY MATTER
lsd will turn as described because there is no load on the diff. as soon as put power to it the diff will "lock". The "snow test" is a good Idea, I like it.
spec35
39
Jun 19, 2017 05:54 PM
vulkandino
Oct 31, 2015 08:29 PM
vetsvette
Oct 11, 2015 06:05 PM
bahman
Sep 30, 2015 01:59 PM
Sep 28, 2015 09:13 AM
