PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67
  1. Xenon Light Washer Removed (weight provided)
  2. clutch pedal fell off
  3. Bird Chirp in the right rear.....
  4. taping into vaccum line for boost guage
  5. 05 MCS Slowness
  6. Where can I find Warranty info?
  7. Recurrent Low Coolant and sludge
  8. Help.....crank shaft sensor code.....help
  9. Got a 2005 model with an SES or EML light on?
  10. Intercooler
  11. dead battery typical?
  12. Crank alignment sensor
  13. Ticking noise?
  14. MCS and MC engines
  15. DSC Question
  16. Has Anyone Else Lost 5th & 6th Gear ?
  17. Real Life Warranty Facts
  18. JCW Air Filter Kit for 2005 MCS
  19. Mini doesn't have VANOS does it?
  20. Oil for a 2005 MCS
  21. How often should I ....
  22. Oil Temperature Gauge Malfunction
  23. mini cooper software
  24. Car crapped out at wrong time
  25. V39 problems?
  26. Strange noise upon takeoff
  27. Concerned over belt wear w/15% pulley CTXT
  28. Mini part numbers.
  29. Ac
  30. Aux Gauges Oil temp bouncing around
  31. My Supercharger Went Out
  32. Nitty Gritty details wanted about MINI...
  33. High octane burn cleaner?
  34. Mixing Washer Fluids?
  35. MCS Exhaust Dimensions
  36. Factory Xenon Question
  37. A/C MPG question
  38. JCW Cooper 'S' Strut installation
  39. Milltek headers and O2 sensors
  40. can an 05' getrag transmission fit in a pre 05?
  41. BC1 broken, door locking and remote problems
  42. Window inoperative in high heat
  43. High Pitched Whine
  44. Factory "ram air" tube
  45. Who has had oil pan gasket changed?
  46. Bogging down
  47. Weird susp noise?
  48. Where can I read all about the Mini's 1.6?
  49. Gas gauge not working (occsionally)
  50. Brown on intercooler?
  51. Going in for service... any suggestions?
  52. SC Belt sizes, parts #s
  53. Detonation/Pinging
  54. squeaky clutch, squeaky windows, squeaky everything...
  55. Boot hatch rattle
  56. High-pitched crikety whirring noise
  57. Parking Brake went SNAP!
  58. Supercharger Belt Squeel on new MCS?
  59. ETK Question
  60. UNIchip Tuner in South or Central Texas???
  61. Oil Catch Can alternative
  62. Putting '05 Xenon's on my '03 with Xenon.
  63. Blowing the Belt. New video, ..ugggg!
  64. I think my supercharger is toast
  65. what does belt slippage feel like?
  66. Help...Need Advice re: strut mounts
  67. Overheating - Dealer says new engine.
  68. Oil filters, Anyone???
  69. Help - I can't get my wheels off!
  70. Humidity Impact on 04 MC
  71. Changing tranny fluid on a CVT.
  72. AC Problem
  73. Dealer programming. What options?
  74. First month of ownership--very frustrated!
  75. Anybody have their windshield molding fly off?
  76. Suspension/steering column issue
  77. Engine Code Definition NEEDED
  78. Popped out of gear
  79. Jacking up the MINI
  80. High beam replacement on car w/ Xenons
  81. Battery terminals, WHERE in MCS?
  82. Manually unlocking the boot?
  83. Cockpit Chrono Pack
  84. Crank Pulley and/or Reduced Diameter Supercharger Pulley?
  85. Input Bearing Failing?
  86. Recharging AC
  87. Please Help!!!
  88. Stripped Bolt Head on Oil Drain Plug
  89. Gaps, tools and wires
  90. Windshield trim blown off.
  91. First gear backfire and SES
  92. Changing supercharger belt
  93. Down goes Camel
  94. A/C lag is horrible! Can an ECU update fix it?
  95. Help! MCS Steptronic EML, Service Engine
  96. "Gassy" smell coming from the AC vent...
  97. Engine Diagnostics
  98. '05 MCS Overheating
  99. Oil drip on garage floor!
  100. eRam
  101. Passenger Seat Bottom Broken
  102. Full ignition upgrade, any suggestion?
  103. In the shop at 1290 miles
  104. how many cracked upper strut mounts?
  105. 'MY05 5sp Getrag Noises
  106. intermittant oil pressure light
  107. Strange Noise When A.C. is on - HELP!
  108. Need help with Pipercross induction kit
  109. Special hose clamp locking tool?
  110. Warranty clutch replacement at only 18,000 miles!
  111. Got a jack today- question about raising my MINI....
  112. m7 pulley installed...
  113. Autotap OBDII software
  114. Battery Service?
  115. Engine shakes, stalls, misses - what's happening to the car?
  116. Brake lights remain on after parking???
  117. Anyone gotten their AGS by mail yet??
  118. Autometer/ProMini Boost gauge accuracy
  119. Car "thinks" driver's door is always open!
  120. Anyone know how to change the horn in an MCS?
  121. What Makes a MINI Click? Broken Selector Shaft?
  122. azzurri
  123. "How To" Change Oil--Directions Please
  124. torque wrench, which one
  125. JCW Intake / Injector Split Cost
  126. Coolant Level
  127. Is your car stalling upon starting?
  128. Is something wrong with my clutch?
  129. Radiator Fluid Overflow
  130. Intercooler Diverter
  131. Which intake?
  132. Trouble Reseting Service Interval
  133. Autozone cone filter - More harm than good?
  134. lean looking plugs
  135. Is MFSW leather?
  136. Is the shifter suppose to wiggle?
  137. Spark Plug Blown Out Of Engine
  138. Rubbing Sound when turning at parking lot speeds
  139. want a beep with low fuel warning light
  140. code #p1689
  141. V41. upgrade?
  142. Tritec out for 2006?
  143. Compression Ratio?
  144. Do I have a problem?
  145. Helix MINIsports 19% pulley & Install Review
  146. Cooolant Level
  147. Factory alarm active/passive modes?
  148. Harder to start
  149. wanting a beep when locking car
  150. Does the full JCW upgrade include an upgraded pulley?
  151. Timing pull questions
  152. overflow tank leak...not the seam and not the cap...
  153. Bentley Service Manual Question
  154. The Tire Tread Incident
  155. Starting to get annoyed, unfixable problem
  156. Funky Noises on a 05 MC
  157. Supercharger bypass valve.
  158. oil change/general mainentance
  159. Engine knocking
  160. Failed clutch slave cylinder
  161. Weird intake
  162. Screw your IC cover on tight!
  163. Replacing headlight and turn signal covers?
  164. Airbag Warning Light
  165. Remote Key Programming
  166. Air Conditioning vs. Full Throttle
  167. "check engine" icon light.... (SES)
  168. No you are not seeing things!!
  169. PS fan grill on 05'?
  170. Headlamp Lens Question
  171. Installing ProMINI gauge cluster
  172. Any one has the 05' PS fan picture?
  173. Rough Idle, the MINI take
  174. Air Filter Volume
  175. Reflections on the First Oil change
  176. Hard Time To Start Engine?
  177. Opinions on replacing the air filter.
  178. Haynes repair manual coming...!
  179. front end vibration
  180. Unichip Worth It?
  181. Why not drop in a new engine?
  182. Getrag 6 in a Cooper?
  183. Deluxe Pulley Puller
  184. V41 Software and Cold start
  185. DIY instructions to replace A/C Condenser?
  186. 05 Supercharger in 03 MCS??
  187. Stumble at start-up
  188. Throw-out bearing
  189. Optional mounting position for engine ground wire?
  190. Bucking/Stuttering MC
  191. strange noise when idling
  192. Feels like it's going to stall
  193. Definition of driveability?
  194. DEFI Oil Pressure Gauge Question
  195. alignment q
  196. Great Tires & Rims
  197. Dinan Engine Software
  198. Rubbing sound coming from the front end
  199. Break in Period???
  200. How far on your '02 or '03 clutch?
  201. Few ECU Questions...
  202. Stupid Question: Where is the Battery?
  203. Cracked rear control arm :(
  204. Uh oh, found a clamp on my driveway
  205. Intercooler cover...needed?
  206. Bad smell after cold start
  207. Interior rattles since new
  208. Reset oil counter
  209. Chirp from under the intercooler at idle
  210. Wheel Bearing Defect
  211. Leaking oil
  212. Ignition upgrade.....?
  213. Injector question
  214. Help me out with this dang driver side strut assembly.
  215. Engine/Wheel power ratio
  216. What Code Scanner?
  217. Oil Dipstick Wasn't In Tight!!!
  218. Clicking noise during excelleration
  219. Weird Smell
  220. Car Went Dead
  221. Something Wrong??
  222. Brake lights "on" when no one in car??
  223. Oil Pressure Gauge Sender
  224. Hydraulic Power Steering fluid change???
  225. Oil Drain Plug
  226. HELP: need instruction for AC evaporator replacement
  227. 1st oil change
  228. Passenger Airbag Light on 05
  229. Service yet?
  230. what size supercharger pully is on the mcs?
  231. Ugg airbag light!
  232. Antifreeze
  233. Turning noise
  234. Battery Cable
  235. How to get to my boost return valve?
  236. Anybody know how to rewire the PS Fan...
  237. First stumble @11K??
  238. Splashing brake fluid
  239. hard to open door from inside
  240. Letter to MINI USA and Dealer . . .
  241. Autolift Question?
  242. Gas Mileage
  243. Octane oops
  244. "Service Engine Soon" light at 1200 miles?!
  245. Broken Muffler Hanger on 2002 MCS
  246. Low Speed Turning Drive-train Noise
  247. Dumb Question: Power Steering Fan
  248. Car won't start!!!
  249. help on deciding mod
  250. what should i do about first oil change?
