View Full Version : Stock Problems/Issues
- Rough Idle discovery! Possible problem located...
- How to determine if you have YoYo, Stumble or Hesitation
- Hit a puddle
- polished engine bay??? anyone???
- Honda Element cracked windshield lawsuit
- 2003 no A/C at idle
- Reading plugs
- where is power steering fuse?
- Coolant reservoir...
- Yet Another Oil Change Question
- MCS Intercooler Plastic Cover
- Need floor jack for Mini
- Gearing
- Fuel Cap and SES...
- Defroster
- Why is 36mm socket a big deal to find?
- air bag light???
- PCV valve OK, breather hose OK...now what?
- Clutch question
- I know, Not Another Windshield Question...
- HELP! Oil Pressure Gauge help
- How to choose a compressor
- Broken 3rd brake light
- Routing of S power cable
- Eric @ Helix is waaaaaay cool
- CEL for misfire on cylinder 4?
- Did you have to fill up your loaner car?
- Help! Engine light, "EP" message
- Stalling problem - BMW tech tells me its "bad gas"
- Whats wrong with my cooper?
- Anyone using NGK Copper Plugs?
- Oil filter canister
- Ignition coil
- Is the mini's battery 12V?
- Power Steering Survey
- Leaking...need input.
- Idle got choppy at a stoplight
- MM Steel Coolant Tank
- Help- Dealer won't give me V38
- Going to NC (and Dragon), so...
- Pondering the temp gauge...
- strut tower braces.....+ or -
- Foglamp Cover Rattle
- Car stalling when slowing down / going around corners
- How to aim / adjust Xenon headlights
- Oil Filter
- Burning Rubber Smell under high revs
- Knocking while decelerating
- Brake Fluid
- plastic parts
- blow off valve
- Mobil 1 Racing?
- Cabin filter replacement
- supercharger oil?????
- Help with Torque Wrench
- Purge Solenoid valve?
- Skid plates
- Water in Battery Box !?!?!
- I need help, and you can help
- Shifter vibration/buzz
- head gasket install
- Yes... Another Brown Coolant Thread...
- MINI won't start
- MINI as one's only car
- Rubbing Noise in Front End
- update to current V 38
- oil leak in a MCS w/ works package
- Are there any windshield wiper refills that fit?
- question on pulley install
- My car, the Queen of the Shop!!!
- Project Crispy Mini Update: Cylinder head
- Tips on maintaining a Cooper...
- When to change the blower belt?
- 89 Octane ???
- Need Advice on Rough Idle
- Pulling to the left...
- OBD-II - any way to view the codes in the display?
- MINI CAN bus data detective.
- OH NO!!! A Cracked Windshield!
- V. 38 For What Ails Ya
- 02 MCS overheating and fuse F5 ???
- Help! Threads in rear A-arm damaged!
- AC question...
- Electrical Sys went crazy. Urgent help needed!
- Silly dipstick question
- Anyone else pull the shift knob off during "spirited" driving?
- my power stearing dissapered!!!
- Notchy Clutch...
- Found small cone shaped plastic under the engine
- MCS Engine noise when revs fall
- Noisy clicking after parking
- want to learn!
- Suprise!!
- Coolant reservoir
- BOOST GUAGE (missing links)
- A/C failure/window malfuntion
- Loose wheel arch problem...any input?
- Strange idle- missing???
- MC transmission - issue with getting into reverse.
- Crispy Mini Update
- Engine Coolant
- Help! Why did fan go on when car is off?
- Need information related to Xenons
- Tire pressure monitoring system malfunction / false alarm
- airbag light on
- February or March?
- Cranks, no start
- boot window replacement cost.
- The siezed fan strikes again
- Passenger side won't unlock
- dsc and tire monitor lights are constantly on?? Vacuum leak or the steering sensor??
- Near Stall
- CVT shifter becoming difficult to move
- ECU Should I????
- "ba-da-dump, ba-da-dump, ba-da-dump" idle
- Remote starter anyone?
- Airy questions
- Damn! tapping sound when my clutch is not engaged....help
- oh oh...there's fluid at the bottom of transmission
- Seat belt problem...Dangerous!!!
- First A/C use
- rear subframe problems
- LSD vs. ASC & DSC
- horn's gone south....again!
- Mod canister filter to fit?
- Which washer reservoir does what?
- Washer Jet No-Working
- What is the stumble?
- Replacement windshield with rain sensing wipers
- Clutch and gas pedal feel connected
- Best OBDII Scanner Palm Software?
- This may be a new one...
- Removing oil filter w/o draining oil??
- Buzzing sound from under my MINI!
- Oil change to ramp or not?
- Dead (REALLY dead) battery after 18 months
- rear pad/rotor change help
- Are Wheel Balance Weights Same as BMW?
- Software Reset question
- Dumb question about nature of engines...
- dealer
- Revving at 3.5K sounds like revving at 6K...?
- knocking noise after driving...
- SEL Fault Codes
- Tap water v.s. soft water?
- When to REALLY check fluids?
- Check Engine/Fast Idle/Cleaned Intercooler
- My back breaks went first?? 26k motored
- power steering whine
- Whirling Noise in Back When Accelerating
- Squeaky Windows Fixed!!!
- audible click/pop when braking?
- loud whine/weeze sound from engine area
- Clutch Hose Replacement
- Service Engine Light... o2 sensor?
- Remote key didn't work ... temporarily
- Help with rear brake/handbrake sound...
- Caution if you have a Pro Mini Upper Strut Bar.
- Dangerous Situation
- Herky Jerky Idle, or did I do something wrong?
- Door lock switch problem???
- MINI won't be used for two months. What should I do?
- Coolant flush
- unlock toggle-no work
- Rich vs Lean
- Limited Slip = limited traction?
- Extreme sputter, service engine soon light is on
- drivetrain whine
- Coming Soon! ... it's about time ...
- Clock above rearview mirror
- fuel shut-off switch
- Two post automotive lifts, 9,000 lb. capacity on sell for $2
- Clunky 2nd gear
- How do they reset those codes???
- Has the AC noise been solved?
- First service at 2 year interval
- Anyone have an intercooler cover just laying around?
- EML, SES, TIRE PRESSURE, and Stability Light happen all at o
- Is my car possessed? Brake, ABS and DSC disable lights are l
- Auxilary Audio Plug
- Mushy Brakes
- anyone know the pitch of the oil drain plug?
- Windshield crack - which aftermarket is better?
- chipped ring on steering wheel, anyone?
- MINI at Dealer-any free upgrades to suggest?
- Loose Windshield Trim
- Does anyone know someone who might know...
- Does your fuel pump constantly cycle?
- Do you suppose some have the yo yo but dont' know it
- Anyone heard of this?
- PPG glass does not exist!?
- Lug Nuts
- Problem with Pilo HO Ignition coil
- Two dealer service questions
- Is it normal for the DSC lite to turn on when car rolled for
- Problem with painted wheel arches?
- MCS gearbox problems and affected by humidity/water???
- 90,000
- bumped from behind; car won't start!?
- knock sensor going bad?
- Abrupt power steering failure
- NE1 know where the fuel filter is on the MCS? How easy to ch
- Who makes an aftermarket coolant tank??
- Tranny noises on downshift/decel ?
- anyone else beyond 36K before 2nd inspection due?
- K&N typhoon intake kit
- To Boost or not to boose (Octane)
- Thanks for the eml info
- New Winshield Issues
- High Pitched Buzz at high speed
- Oil Light
- How to check the PCV hose?
- Air Filter Replacement Question (MCS)
- TIS service manual for 2002-2003 Mini Cooper S
- New Mini..whirring sound
- Power steering = dead
- Watch out for wiper mechanism during Unichip installation!
- Winshield troubles ?
- The "New" windshield....R.I.P. (#6)
- break in tips
- Zero Gravity
- Sqeaking sunroof.
- How do the plastic fenders attach to the body panels?
- help...strange chiming noise?
- Growling A/C Compressor
- "hatch-open" light is possessed!!!
- Which fuse runs the horns?
- MCS CAI Idea....who wants to make it work??
- HELP!! my mini has a smoking habbit
- Can someone please tell me what size trox bit for the brake
- start up difficulty
- Promini intake
- Did Alta change design of the intake?
- Alternative to the TIS cd
- 6-speed gearbox fluid
- Computer program
- real big stumble
- Peek a BOO! (MY MINI PICS smaller pictures now =p)
- Stalling at first start even with v37?
- need some serious help with Short Shifter install...
- Transmission getting very stiff!
- Warning: eBay Auction For TIS manual
- A Leak, and a Buzz?
- My clutch pedal cover keeps falling off!
- aero kit advice?
- Service Engine Light Oh Know
- hot air?
- Terminology explanation
- Bouncing baby MCS
- MINI Header?
