Does your fuel pump constantly cycle?
Old May 20, 2004 | 08:26 AM
momini's Avatar
momini
Just got back from the dealer for my 2nd inspection and had software 37.1 loaded. Something new is happening now and I'd like to know if its normal. The fuel pump turns on for about 2 seconds ever 10-15 seconds. This happens with the key in the on position (cycles start after the initial fuel pump priming) and when the car is running. So those with 37.1 - is this normal? the dealer says that they THINK it is but are not sure. Thanks - Tom
Old May 21, 2004 | 04:01 AM
momini's Avatar
momini
edit - 20 views and no replies.
Maybe I should be more specific. Would a fellow MCS motorer with v.37 please do the following.
1) turn your key to the on position
2) let the fuel pump and all the other accessories power up then sit there for 30 seconds and listen.
Do you hear the fuel pump turning on & off? every 10-15 seconds mine turns on for 1-2 seconds and this continues for as long as I sit there. Also happens when the car is running.
Old May 21, 2004 | 05:06 AM
MGear's Avatar
MGear
I had my first scheduled maintenance about two weeks ago during which time they also programmed the ECU with the latest software. Although the work order does not mention what number the software upgrade it was it does state the upgrade was with the 'latest version available'. I had this done to help improve the famed 'hesitation', which in fact it totally eliminated it so I was very pleased. However, I just went into the garage to check on the fuel pump question you had and I do not experience the same noise you mentioned.
Old May 21, 2004 | 05:31 AM
momini's Avatar
momini
Great - thanks for the help MGear. Good to hear your hesitation problem is solved.
This fuel pump cycling just can't be right - another trip to the dealer
Old May 24, 2004 | 02:02 PM
AlanB's Avatar
AlanB
Use the trick I learned on my 1960 Morris 850. Get out of the car, take off your shoe, find the pump (I do not know where it hides on my MCS), and wack it a good one! This usually works!
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
Casrio
Apr 20, 2021 01:52 AM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
mimaal
Sep 4, 2015 09:09 AM
