PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Do I have a bad clutch or transmission?
  2. CV Boot Torn
  3. How to close air filter cover?
  4. Weird random issues with my MCS
  5. Check Engine Light - Exhaust?
  6. Weird noise
  7. brake job! HELP
  8. Alternator might be dead.
  9. Armrest replacement
  10. Code P1689 and low power
  11. Hard to start and CEL code -P0302
  12. hello,new (used) to minis
  13. Forum noob requesting input/help
  14. Where to buy a connecting rod?
  15. HELP, 2nd cracked and melted ignition coil
  16. HID Headlamp Assy Replacement
  17. Headliner (?) cloth loose
  18. Popping Out of Gear
  19. Xenon Fail
  20. Should I replace spark plugs? Whaddya think?
  21. Stubborn Bulb!
  22. Side trims falling off
  23. Non-catastrophic tensioner failure.
  24. Need some Rad Fan replacement direction
  25. Fuel gauge broken
  26. Tapping after Seafoam
  27. Belt Replacement HELP!!!
  28. 2005 Cooper S
  29. I lost a piece of my bumper...
  30. Power window parts?
  31. Shifter Cable Broke.....I Think. Please advise
  32. 5 speed Gearbox
  33. Wheel size, MPG, and computers
  34. Lesson Learned..the hard way
  35. Cooper S fuel mileage concerns
  36. Wheel bounce around corners
  37. Fan, STDs and brakes - shade tree notes
  38. Need help, timing issue.
  39. Airbag Light!!!!
  40. Need advice on engine swap asap!
  41. R53 Belt Tensioner Question
  42. Clicking from axle/driveshaft on drivers side
  43. New squeek today triggers limp home mode
  44. door lock + automatic unlock (2 pulls on handle)
  45. 2005 MCS Auto Transmission Surge or Yo-Yo
  46. The 2003 to 2006 Mini Cooper "S" is a Neat Car BUT!!
  47. clicking sound from the front
  48. Oxygen O2 Sensor prob. that won't go away.
  49. Serpentine Belt issue
  50. Looking for help with a window problem in Norther VA
  51. Headlights always on when driving
  52. Wiper Fluid Leaking...
  53. 2003 cooling fan problem
  54. Air Conditioning Recharge DIY?
  55. My AC blows heat every once in awhile.
  56. Did my engine mount just died?
  57. Horn Relay
  58. sluggish acceleration R53 - help
  59. Stage 1 Fan?
  60. Bad Crank Pulley? I Need a Second Opinion
  61. Missing rear rotor/hub retaining bolts, & holes don't line up.
  62. AC blows hot and compressor is not turning
  63. Engine Damper/Dealer Quote/DIY?
  64. SES Light, Inspection, and 75,000 Miles
  65. Glove Copartment
  66. 2006 MCS JCW shuts off while driving..
  67. sc removal
  68. 1st gear....extremely sluggish uphill low end RPM's
  69. Drivetrain vibration in rain
  70. Koni FSD / strut mount
  71. Coolant temperature pegged-out at max
  72. Rear Wiper
  73. Help my 05 Mini is still overheating
  74. Broken Window Switch??? :(
  75. code p1125 and p0638 no start
  76. 2005 Cooper - Horn stopped working
  77. HELP!!!mcs wierd noise from unde hood
  78. Bad fuel sensor...
  79. Battery cable squib resistance
  80. EML and Check engine light 06 MCS
  81. Help, trying to figure out what is going on
  82. $40 for a spark plug??
  83. Installing New Starter
  84. Coolant problem
  85. Please Help! I keep blowing fuse w/iphone?
  86. PCV Valve questions
  87. replacement filter
  88. Help with MCS overheating at idle
  89. Clutch issue
  90. Windsheild washer has stopped spraying.
  91. bad cat or exhaust leak?
  92. What have you paid for these repairs?
  93. tire failure light flashing!?!?!
  94. rear tag light-what size are our bulbs?
  95. Heavy steering
  96. Subframe removal, in conjuction with control arm Bushings
  97. Power Steering Fan question
  98. Blower Motor Woes
  99. Glove Box Lock Cylinder removal?
  100. Intake Air Temperature (IAT) high or normal / Post Your IAT's
  101. Two problems in my engine bay. Help?
  102. Rad Fan part information
  103. Standard oil for r53
  104. ??? Powerflex front control arm bushings ??
  105. Unable to start after fuel filter change
  106. New owner with a question.
  107. Exhaust system explanation requested
  108. 2003 cvt
  109. Cooling system issue
  110. Strange Squeaking from front end
  111. Hissing Vacuum Line
  112. Help!!
  113. idle wub-wub-wub 02 mcs
  114. Morning hesitation
  115. Dunlop DSST weather cracking dry rot
  116. '04 MCS tail light problems
  117. Do I have mushrooming? (Pics)
  118. List of Changes to Computer at Dealer
  119. R53 Starter Motor replacement proceedure
  120. Help! stumpped fixing my fan and a/c
  121. 03 MCS Manual Transmission? Noise
  122. SuperCharger bad
  123. Battery Troubles - 1K miles
  124. Boot Trouble
  125. Regarding these NGK Spark Plugs
  126. buy a code reader? or trust the dealer?
  127. What air filter suit for R50, 2006 Mini Cooper AT?
  128. Keyless Actuator FCZ Windows Convenience fail
  129. R53 2006 Tcs, Abs And Tire Pressure Lights On
  130. Chassis and engine question R53 MCS
  131. Broken fog light lens
  132. replace water pump???
  133. 2003 Mini Cooper S, Catalytic Converter failed in California
  134. Alternator help, if you please.
  135. ambiance lighting?
  136. Won't Start ! Battery is Good, Any help ?!?!
  137. Need help diagnosing overheating
  138. Metal Shavings and Chirping
  139. New 03 MCS owner in Arizona
  140. Cooling fan troubles
  141. On dash...What is this? Pic
  142. Would like to confirm my harmonic balancer is dead
  143. Water leak onto my left foot
  144. Water in Battery Box
  145. Car Slow to Start, lights on dash
  146. Valve Cover Gasket replacement question
  147. Odd Gremlin...
  148. A/C Broke (again)
  149. what fuse is this?
  150. Installed new belt still squealing. Help please.
  151. Why me? Valve cover nut disintigration
  152. TMAP/MAP sensors
  153. new power steering pump fan not working!
  154. License Plate platic light cover
  155. Master Keys - Are we really at Mini's mercy?
  156. Supercharger blown
  157. TMAP/MAP sensor location
  158. Engine Codes/CEL driveability issues
  159. Catastrophic Engine Failure at 72,000 miles
  160. HELP - I'm New to Mini - P0172 code
  161. help?
  162. God awful noise HELP!!!
  163. hesitation when it comes to acceleration
  164. just bought my 1st Mini! I have q's and concerns;(, hoping for advice
  165. 2002 MINI Cooper - Need Battery Part Help
  166. Engine Block
  167. Car won't start
  168. Red sticker behing air box
  169. how to clean throttle body
  170. Oil Change Problem and Questions
  171. Help! Crazy electrical problem
  172. P0500 and P1613
  173. Oil leak
  174. White smoke from exhuast?
  175. ?no a/c, no p/s fan, no lo speed cooling fan.
  176. oil pressure 2006 S
  177. Water pump replacement?
  178. Need to vent
  179. Annoying rattle
  180. New o2 sensors and still throwing a code.
  181. Couple questions to fix some minor things
  182. Supercharger rattles
  183. H/K stereo concern
  184. odd ac issues
  185. Streering Rack Removal
  186. "Mushrooming of shock towers" /NHTSA
  187. A/C decided hot air is better, any help?
  188. Leak in Convertible
  189. A/C cool not cold
  190. MCS erratic Idle and rough acceleration
  191. Tweeter Replacement
  192. Please Help!!!
  193. Weird KLUNK sound
  194. AC Question: Adding Freon to my Cooper.
  195. HPFP Failure Article
  196. Checking fuses and something's missing HELP!!!
  197. Reverse sensors on Convertable
  198. Noise at speeds over 60mph.
  199. Spongy brakes after replacing pads / rotors
  200. Drivers side rear brake pads rattling/clanking noise
  201. power lock failure
  202. Radiator fan hi/low and power steering fan questions
  203. 2003 MINI S Charge port Question help!
  204. Anyone of a clear picture of the wiring harness/thermostat area?
  205. No Power from idle-2,000 rpm
  206. Rhythmic belt squeal/squeak?
  207. Did I ruin my engine?
  208. clutch master & slave cylinder replaced, now....
  209. Squeaky header driving me nuts!
  210. Where does it go?
  211. Injector - O-ring = %$#@! Morning (help)
  212. Fan noise only when AC is on
  213. Driver Window stopped working out of nowhere...
  214. Fixed R53 AC
  215. 100K Maintenance
  216. Alignment necessary after replacing transmission?
  217. Dead seatbelt
  218. The dreaded clutch "whine" sound....ARGH!
  219. Mini Overheating / No A/C / E-Fan Not turning on
  220. Coolant flush and serpentine belt replacement
  221. Not sure if this is a problem or not.
  222. need some help here!
  223. Video: Can you identify this noise? Bad supercharger?
  224. Video: Can you identify this noise? Bad supercharger?
  225. CVT Issue and code
  226. Need belt, please help me find the correct one.
  227. Cannot get Above 3000rpm...Vibrates Bad
  228. fluid-filled engine mount - question
  229. Stripped air intake torx screws
  230. Tool for oil filter change?
  231. DIY Oxygen Sensor Replacement?
  232. Fluid colors
  233. Installed a detroit tuned bypass valve now i Have really bad yo yo??
  234. HELP! My Mini is Broken!!
  235. Coolant Flush Difficulty?
  236. a/c issue and no low speed fan
  237. Need some advice on how to remove a striped hex nut
  238. 2004 Mini Cooper Won't Take a Jump
  239. How new a motor will fit?
  240. Alignment Mishap
  241. Intermittent air conditioning
  242. 2006 Mini Cooper S auto stalling
  243. Dead Battery or Dead Alternator?
  244. HELP! Service Engine Soon light/ Clear Fluid Leak
  245. Did Sea Foam, got SES light, scanned = engine misfire
  246. clutch sticking during really hot days
  247. Air conditioner hissing
  248. Did i receive a bad air filter?
  249. 2003 mini cooper s
  250. a/c problem
