View Full Version : Stock Problems/Issues
- 03 MCS transmission problem
- MCS feels like it is "missing" at about 70MPH
- Passenger Window Wont Open
- sudden sound at 11,000 miles...
- Door Lock Knob Motor
- Another power steering problem....with a surprise twist!!
- My CVT is making a whining sound...
- SRS / Airbag Light ?
- Spoiler as dust preventer on 07 MC?
- Squeaky gear stick
- How to troubleshoot an S.E.S. light?
- Question for those who had CVT failures
- Warranty question??
- ABS,DSC,and flat tire on(help)
- Tool known to reset airbag light
- Water in Battery Box
- My MINI is shocking me... literally
- Lower Control Arm Bushings - Advice on replacing, please
- P2299 brake/accelerator position incompatible?
- Sun roof lube
- Where is the sat nav cd player?
- Bent rim--problem?
- Air con performance issues
- Radiator Fan Perma-On
- Hard to open door prob
- OBX Header owners, do you feel vibration & unwanted sound?
- Where the heck is the clock???
- windshield cracked :(
- (Disregard) Can a home mechanic replace a clutch?
- TPMS and DSC lights on all the time...ABS sensor voltage?
- no spark?
- Weird electrical issue- frustrating
- CV Joints
- Squeaking noise at speed
- Engine/Radiator fan
- P0172 system too rich (stock injectors)
- Rust on exterior of door
- Lurching in first gear?
- Car wont start, shop says its the starter
- Laundry list of problems with my 02 R50...
- ENGINE MISFIRE
- 04 Cooper S horn issues
- Grinding noise in reverse
- Hey! Where is my coolant fluid?
- MOSA Report Card
- Has any one seen this code?
- TSB's Out of Warranty
- Unable to shift gears on auto?
- Engine won't try to turn over
- Bad Clutch?
- A clicking noise is heard when trying to start
- EML, Engine and DCS light Came On Today, Please Help!
- Door sills are lifting up...
- Key Remote Reset
- Air Filter Box Loose *non S*
- Yellowing Trunk Hatch?
- 2002 MC - noise diagnosis help please
- A/C UNIT GONE BERSERK
- Xenon bulbs going out
- Service Engine Soon Light
- Transmission problem for 2003 MINI
- Windshield rubber gasket coming out
- Mod Friendly Dealers in South Orange County
- Crank pulley is shot. Causes?
- A/C Question
- 2007 Cigarette Lighter Fuse
- First JCW oil change. Same oil as MCS?
- May be buying TONIGHT: need advice!
- MCS Radiator Fan Won't Shut Off
- Suspension Noise when turning
- Why did my flat tire light come on?? O.o
- Missing part in engine bay?
- 16,334 mile Oil Analysis results
- Battery or Starter issue
- shift problem?
- Anyone know the Coolant Cap part number?
- How to lubricate the steering bushings/joints/etc
- Motor Mount
- Rust on the ... whats-it-called ?!
- How to bleed brakes?
- Very Annoying light
- Car Won't Start and Ligts Flash
- supercharger blew up!!!! 170,000miles
- Another Rust Issue
- Rusty coolant!
- Non-Fog Light Hole filler knocked out.
- for those who've changed out their slave cylinders
- INFO: Relatively new 6yr/100,000mi Full Maintenance Warranty extension from Mini USA
- power steering pump won't shut off - ever!
- At what milage did you need your brakes and rotors replaced?
- Extended maintenance contract?!?!?!
- SES light and performance problems.
- Engine clicking noise under acceleration '03 MCS
- Why No Aftermarket Motor Mount?
- Heat - The anti power additive
- head lights
- Brake Dust + White Rims = Major Problem
- OOOH OOOH MY First!
- Cooling fan stays on long after the car is off...
- BANG! Goes the battery. What should I do?
- need words of wisdom asap
- Windshield fogging up on the outside
- Check Engine Light & DSC Light
- SES, O2 Sensors, P2097
- Major Electrical Issue ---- HELP
- 05 Automatic Transmission "EP" Issues
- Odd rattles and leaky motor mounts :(
- squeeky brakes arggg!
- Engine Stumbling on Full Throttle
- intermittent no start
- Right headlight flashes when i start the car
- Wiring Harness replacement??
- Paint rubbed off in Bonnet/Engine Bay!!!
- Looking for salvage yard with MCS AC unit
- Cruise Control Inop - Ideas?
- Engine quit while driving
- '04 MC Issues
- Motormount again!!
- Speakers Dead- Horn, Too ????
- License plate??
- computer lock up prevents start
- High pitched whistle when engine turned off?
- 60k Service?
- Transmission Issues
- It fell off, it fell off, it FELL THE "F" OFF!!!!
- Harsh metal noise?
- Cat failure w/ Milltek catback exhaust
- Electrical Outage?
- Replacement Body Parts
- Help Please, Tapping Noise
- Stock Paint problem
- Can I get a definitive answer?
- Optima Red Top 34R Good Deal-$147 including shipping
- Gas gauge problem
- DIY - Oil Change
- Wing mirror vibrates at speed (85+ MPH)
- Mini came alive on its own today
- Window trim peeling off
- Service Engine Light
- Grunting MCS rear end
- hard to shift to 5th gear
- 02 MC transmission problems??
- Mini Cooper shooting out Tranny fluid, dealer states part is not available in the US
- To the Dealer or Not to the Dealer???
- Anti-Stop Brakes
- Used Power Steering Pump - same for both models?
- Floor it and no speed
- Mushroomed Shock Towers
- PS Fuse #39 Keeps popping. WHY?
- Clutch pedal motion not smooth
- Fuel sender bad, which one?
- The cure to cold start sputtering found?!
- Cruise control over redlines engine!!
- mufflers loose...
- Mushrooming Proposal
- opinion on cracked windshield
- Help....Need vacuum clip!!
- Slave Cylinder Out?
- May be posted before but need help
- Consistent 2005 Stock Issues?
- Replacement battery options for MC
- If this has been covered, sorry
- Fluid inside car??
- A few problems with my New To Me 04' MCS
- What a DAY!
- Jerky...High RPMs...What???
- Driver's seat height not working right... help!
- Power Steering Fluid color?
- Hot front seats!!!
- Update: Inexpensive PS pump/fan fix
- Do not giggle at this. Do your downtubes wiggle?
- Removing accelerator pedal?
- Noise in 1st gear or reverse, burnt smell
- Coolant change
- loose bits
- A/C vibration
- ALternator...hard to remove?
- Alarm chirp when locking/unlocking
- Need help with a starting problem...
- Banana'd Lower Control Arms
- Clutch Fork
- Where and how do I hang a license plate holder on this car?
- O2 sensor...how long should it last?
- oil change issues, need some wisdom...
- Clutch switch going? Hard starting.
- Help! Power Steering problem?
- Dead Motor Mount?
- A/C Problem !!
- Leak! HELP! ASAP RAIN MOVING IN FOR THE KILL!
- suspension vibration at 50mph and higher
- jerking when idle?
- Phantom trunk lid unlocking
- Snapped off Dipstick
- Suspension Knock. *Help*
- power steering fan seized up?!?
- Fuel injector Harness ples
- Possible inexpensive PS fan replacement
- Tire Pressue AND DSC Lights on
- Metallic Rattle
- Very difficult 1st & 2nd gears.. anyone else?
- any one knows where this cable goes to?
- No power to EITHER 12v outlet!
- Just lost my brakes
- Locating A/C Resevoir! Where is it? Pics?
- Help needed ASAP!! Driver's seat won't go back to upright!
- Strange Spark Plug issue
- Can I use a stock 15" wheel & tire as a spare on a MINI with 16"?
- Mushroom - Strut tower issue
- HELP, did I mess up oil change counter?
- AC gone bad! Thoughts...comments...??
- Door panel
- $938 for 100,000 mi service
- Growling noise at 3000 RPM = new Getrag 6spd...
- check engine light...
- Bluefin problems
- OBD BMW Code 05
- Persistant problems and more new parts!
- '03 MCS OEM Crank Pulley on '05 MCS?
- SES Light...P0036 code
- How to adjust front bumper?
- Car vibrates w/ AC on??
- fan groaning
- Tire light??
- 03 MCS with 42k miles still under warranty?
- What is the correct power steering fluid to use?
- Replaced water pump o-rings, still leaking antifreeze
- EML SES LIGHT HELP!
- Noisy Air Box
- Does this part belong to a MINI?
- Hot Air
- thinking about changing spark plugs.... recommendations
- Click/Tick sound upon acceleration
- CVT Fluid Change
- Rims, etc. (and my shrinking bank account)
- Power steering fan engine cooling fan help
- Paint Job Question and Pics
- Replace clutch at 12,500 miles??
- Air Bag light stays on
- a mouse noise???
- Broken Dipstick on MCS JCW
- Starter killed by dead clutch? Is the dealer lying to me?
- Rattle in my cabrio!
- New Guy Has Questions . . .
- !st Gen Airbag problems...
- Sunroof problem - loud cracking sound
- Motor mount leaking
- Seven Months, Three Breakdowns
- Fog Lamps not working
- HID headlight help
- Garage Lift?
