Rusty coolant!
Old Jul 18, 2007 | 07:46 PM
LordOfTheFlies's Avatar
LordOfTheFlies
Rusty coolant!
Did a coolant flush for a friend's 03 MCS with 34K on the clock.
Had never previously been touched.
I was absolutely SHOCKED at what I found.
What could have caused this? The drainage was not sludgy at all, very clear, but just completely rusted out. I wonder if the original coolant mix was off (too much or too little water??)
New coolant is all nice and blue!!!
Click on the pics to enlarge.....
Initial drainage
AFTER 10 FLUSHES!!!!!!
Upper radiator connector
Whatever you do, do NOT disconnect the two 8mm bolts that hold the plastic hose on the radiator to drain the system. I thought it would be easier than shoving a clamp to disconnect the hose (on jackstands) but I was wrong. Much easier also if you take off the bumper cover.
So the plastic piece on the hose connector broke at the hole, which in turn caused me to keep on turning the bolt to screw it in, which in turn forced the nut right throuh the plastic. This, of course, required the purchase of a new radiatior ($350).
The good news is it only took about 30 minutes to put the new radiatior in. I couldn't believe that it's only held in by two plastic clips!!!
Here are some pics of that install.
Old radiator out
New Radiator in
Also the radiator fan is only held in by two clips and two support brackets. Came off in 2 seconds and snapped right into place on the new one. The clips are about 1/4 of the way up on either side....
Oh and to top it off the car had a REALLY dirty air filter! Yuck!
Old Jul 20, 2007 | 09:13 AM
LordOfTheFlies
Anybody else have this rusted brown coolant? I've heard of milky brown coolant which I had in my 04 MCS...but not like this!
Old Jul 20, 2007 | 11:31 AM
Yo'sDad's Avatar
Yo'sDad
When the rust and corrosion inhibitors in the coolant are consumed, then the rust begins. Apparently this happened... just one more example of these long term service intervals not living up to the claims. At two years, I'm going for the green stuff.
You can get coolant test strips at good auto parts stores and check the acidity or corrosion protection of your coolant.
YD
Old Jul 20, 2007 | 04:16 PM
aDeLoreanGuy's Avatar
aDeLoreanGuy
MINI requires it to be changed every 3 years, which isn't long term. My last Ford required changing the coolant at 6 years (was done at 5 and was still in great shape). The owner of this MINI waited about 1 year longer then recommended.
Old Jul 21, 2007 | 10:53 AM
LordOfTheFlies
Yo's dad - I'll be sure to pick up a couple of those strips.
ADelOreanGuy, I think the recommended service interval is FOUR years for coolant according to MINI....which is when my friend decided to change hers.
I'll be sure to change it every 2 in my cars.....
Old Jul 24, 2007 | 04:18 PM
pehata610's Avatar
pehata610
I was told the recommended service is to change it every four years. I will now make sure when I flush my brakes, I flush my radiator so I never have this problem again.
Old Jul 24, 2007 | 04:29 PM
DSRH's Avatar
DSRH
Nice Post
thanks for the info...
Old Jul 25, 2007 | 08:39 AM
aDeLoreanGuy
According to the 2003 owners manual, it's every 3 years. Attached is a screen capture of the PDF on page 97.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
