Clutch pedal motion not smooth
Hey guys. I am about to take the Mini in for several small things and I am going to mention this issue but I wanted to get your guys take on it before I get some BS from the dealer
Anyway, when releasing the clutch pedal (that is, engaging the clutch) it doesn't always operate smoothly. It almost seems to get stuck on the way up sometimes. This doesn't happen all the time but it has caused me to burn the clutch once or twice and stall the car once. It's really annoying at this point. Any ideas?
PS. I can also feel the unsmooth motion when pressing the pedal down but it doesn't really have an affect on driveability. This is a hydrolic clutch, right? lol
Thanks,
Kirk
Thanks,
Kirk
Mine had an unsmooth motion for a while before my pressure plate failed. Also, if it is not coming back up, it could very well be your hydraulic slave cylinder. They go out all the time on the 05's.
Search for squeaky clutch pedal. You will find a lot. I had this problem and it was the release bearing rubbing caused by a bent clutch fork. If it is not the slave cylinder, it may be that. If the fork is bent, it will push on the release bearing at an angle causing it to bind up.
Read this!
i know this thread is 10 years old but i figured its better to revive a (really) old thread than to start a new one.
OP did you ever find a resolution to this? im having the same exact issue and am hearing differing opinions ranging from clutch to bearing to slave cylinder.
patsum
26
May 29, 2021 06:29 PM
thadscottmoore
Sep 25, 2015 10:07 AM
Sep 22, 2015 02:05 PM
Sep 16, 2015 06:22 AM
wildwestrider
Sep 4, 2015 06:25 AM
