View Full Version : Stock Problems/Issues
- A question for those over 100k
- 2005 MCS with dead battery twice this winter, questions (long!)
- Mini s -no start. What is this piece hanging under the dash?
- Just installed some ik22's
- What in the....MINI's cheaping out!
- Thinking about a radiator hose kit.
- Strange ticking
- Anyone experienced with fixing a radiator fan that refuses to shut off?
- Loss of coolant
- Tick tick tick
- Brake light problem
- kingsborne wires 8mm vs 9mm?
- Burble tuning
- My first service. What to ask for?
- Advice sought on my first service (Is this the right forum?)
- Shimmy under Load
- Sand and Gravel in the IC
- 11,000 miles and brand new transmission
- Alignment Issue?
- 06 ps oem fan cover
- DIY repairs: boot latch replacement
- Transmission Fluid for 6 speed MCS
- Please translate: "Post Catalyst Fuel Trim System Low Limit"
- 9 month Break in Period??
- Cleaning the Intercooler Suggestions
- MCSa no M1 in SD
- newbie motor oil API question
- Replacement supercharger problems
- Service Engine Soon light - what does it mean?
- Oil Catch Can problem?
- JCW Plug choice
- Oil Filter: What's the trick?
- Power Steering question
- Motul of Redline??
- colder vs. more air
- Electrical Demonic Possession HELP!
- So, it is possible?
- Help! Car Won't Start after accident!
- Wiper arm removal
- dead blower... where is it?
- exhaust manifold / header temp
- WTB: 14mm X 1.5 Helicoil kit
- Coolant change
- Mcsa Hai
- MCS Strut issue
- Is there a difference with FSB's?
- Whats the scoop on cold plugs
- Alta CAI Too Noisy.... Is there a fix
- Dealer propblems
- My VGS install (with pics)
- just installed
- 3rd brake light red plastic cover broken at automatic Carwash
- Code P0171 System Too Lean (Bank one of two)
- no service history
- Mod. advice
- "Normal" spark plug replacement interval?
- intercooler bellows
- 05/05 exhaust on an 03?
- Window motor on drivers side
- TB install advice?
- oil change prices
- heavy vibration under load
- Warning light came on in car
- DSC activating for no reason
- Water and SES/EML lights?
- Oil seepage? / Head Gasket Area
- MPG confusion
- High Altitude performance
- Planing modifications? 2006 MCS
- JCW ECU, Flat Spot, 63mm Throttle body + lots of mods
- Xenon low beams to High?
- Auto Climate Control too hot
- Windshield wiper question
- Radio TurnSignal Nav SIRIUS Gremlins
- Second Service / Maintenance II
- OBDII Diag. Devices - Are they worth anything?
- Borla Race Exhaust
- Giac/mth/unichip
- How do I adjust non-Xenon headlights?
- Just ordered!!!!
- How far can I go...
- Boost vs Exhaust
- Oil Change + new Tip... maybe kind long
- lost power
- Stand Alone ECU
- Power losses when shift up 3rd to 4th
- LC20 oil antioxidant and FP60 fuel system cleaner...
- Rattle in my dash Board
- Strut braces
- drl's
- Ticking fuse, what the heck?
- Nology Wire Picts
- repair manual
- I joined the '05 cracked windshield club.
- Can you have the MCS rotors turned, rather than replace?
- 4500 RPM & MCS 2006 Shuts Down?
- Service Centers
- Oil Q
- A quick injector question
- replacing battery on COOPER (not S)
- SES light won't go away
- "Autos for Dummies"
- After market valve cover
- No Start-after accident
- Is the dealer responsible if...
- Garage-door-opener woes
- Gear shift vibration:
- My A/C Compressor Seems to Not Shut Off
- 06 MCS car hits a flat spot
- Stalling on the Freeway
- Castrol OUT, MOBIL 1 IN....
- SC pulley
- stupid.
- Installed Wolo "Big Rig Long Horn" air horn
- Code 1125 help
- Help: EML, SES, OBDII Code P1688
- exhaust help
- Injectors Question
- ANOTHER SES Question
- Interesting news from USAA...
- Oil Catch Can - Why?
- DIY Programming?
- What am I doing wrong? - intercooler reinstall
- Relocation of Alta Oil Catch Can...advise needed....
- rear windshield wiper
- smokey
- Need advice where to buy the low profile ECU cover?
- Blown Spark Plug!!
- What is this?
- Oil Temp and Water Temp Question
- Milky Oil - WTF?
- homelink system
- Is this normal? Backlighting for temp/fan/air direction
- factory boost
- :::REDLINE OIL:::Where to buy
- cheapest price for tensioner tool
- BtB Newbie Wonders How to Confirm SC and/or BPV Operating?
- Tach signal tap point for RPM window switch
- noise reported to be throw-out barring, how long until...
- Wipers stopping permantly- Rainsensor?
- Oil Question
- Clutch issues
- Front Bumper
- DSC Light stays on after spirited driving
- OBD Code reader question
- Custom exhaust
- psi/hp
- alarm stalk
- lifting points
- Is there an aftermarket CVT trans filter available?
- Thread of tow hook?
- Anyone using DigiMoto software?
- How to replace power steering fluid by myself?
- clutch
- bypass valve question.
- Where is the auto tranny dip stick?
- JCW badges and drive belt R&R
- bypass valve pictures
- Plug Wires
- Delivery Procedures...
- Bigger brakes & tires = less HP.
- splitting the ps fan circuit
- Supersprint's turbo manifold question
- Sticky door latch problem
- Car Temp Dropping
- Thinking about bringing my car in...
- Cant get to the dead battery
- Gas Pedal Stop Response In the middle of the Traffic
- Cold Start Squeal at 2500 RPM
- Radio static after engine removal/reinstall
- I Hate Mini......
- Stupid Power Steering Question
- Can throttle response be improved?
- Coil pack question....
- Xenon headlight problems - Help!
- My Brand New 06' MCSa acceleration problem
- My windows have a mind of their own
- Help, my 06 MCS doesn't always want to start
- UK Xenon Lights differnt from US??
- Front Bumper Damge
- Outside air tem sensor location
- Oil pressure?
- First Oil Change in my 2006 MCS
- Dynamometer Testing Question
- P1498
- '05 MCSa Alta 15% pulley and CAI ???
- Do you understand A/F? (I thought I did but now not sure)
- Tranny Fluid Change
- HELP! ABS Crisis
- 2005 MC Steering Fluid Low!
- Power Steering Pump Failure- 2003 S
- Minis And Cold Weather
- Old vs New OEM crank puley
- P0172 Code (System Too Rich (Bank 1))
- What size fittings on the Venom nitrous kit?
- Aftermarket Coolant Resevoirs - Canton forge etc ?
- stereo plays possum
- rear brake cylinder
- jerkiness/jolt when gas pedal is first engaged
- Coolant loss - what is typical?
- SC whine and Alta CAI
- Rear Window Washer Not Working
- Adjusting Xenon headlights
- Key signal getting weaker... dead battery?
- Rough idle and now SES and DSC light :-(
- Clutch "singing" when engaging 1st gear
- Radiator (not coolant tank) leak
- External Temp Sensor Problem?
- Squeaks when shifting into 1st, 3rd and 5th Gear
- My mini shocks me when I get out
- Smoked clutch?
- Torque setting for wheel nuts
- Normal Fuel Pressure MCS
- Blown Head Gasket Help
- CVT Lurches
- New Kelleners exhaust for Mini
- Help! Strange noise at highway speeds
- Ticking like a stopwatch
- Now the passenger side door lock is broken!
- Who would NOT buy a MINI again?
- MINI Start up noice and oil leck
- Wife's Christmas Present to Me!!
- Jcw Replacement Air Filter Element
- Yo Yo and your dealer
- So I'm out of coolent..............
- Exhaust
- Coolant leak
- Question about Graphic Under the Hood.
- Att.LOUISIANA
- Rattle at 3000 RPM
- Help: Need A Body Shop
- Phantom of the Blower
- How long should a clutch last?
- Stupid question, what is this?
- Left foot braking?
- Who manufactures the MCSa transmission?
- Keeping your CVT trans alive...
- Clicking noise on takeoff/brake
- Help with Phantom of the blower
- TWIN CHARGED downpipe torque settings??
- Kelleners ECU problems?
- Clutch squeal
- Help engine misfire at WOT in cold weather!
- lubricant that comes with kingsborne wires
- Loss of low end power, suggestions please
- Injen Intake
- Cam shaft replacement options
- K&N Typhoon vs other cold air filters
- Limp Home Mode NOT SAFE!
