Can throttle response be improved?
I've done some searching, no joy.
Has there been an effort to improve the throttle response of the mini's fly-by-wire throttle? It would be nice to have the snap that a carbureted engine's accelerator pump gives.
Some joy has been had by various methods. First, obviously, would be to alter the software. I've gotten the impression that most of the flashes quicken throttle response. Uprated coil pack/wires/plugs seem to help. Larger throttle bodies tend to quicken the response, as well.
These are at least the easy ways that I can suggest.
My throttle responce has been greatly improved over stock. When I first got my Mini I really hated the lag in responce as it was my first "throtle by wire car".. The list below all contributed to this outcome. Of course there are several other companies making similar items to some of these listed below which will give you improvments as well. I just point out what areas I have worked on to get what you are looking for.
M7 14.5 lb flywheel
M7 1 lb crank shaft pulley
M7 16% supercharger pulley
M7 64/62 mm throttle body
M7 AGS intake
MTH soft ware
Randy
M7 Tuning
M7 14.5 lb flywheel
M7 AGS intake
MTH soft ware
Randy
M7 Tuning
Originally Posted by maxmini
<snip>
M7 14.5 lb flywheel
M7 AGS intake
MTH software
M7 14.5 lb flywheel
M7 AGS intake
MTH software
Edit: nevermind - lotsa threads on the subject.
Software. Is this an aspect of engine operation that is directly addressed by the modified software? Perhaps that is a question best asked of the software houses.
On other area that may affect it is how early boost comes in, how quickly the BPV closes. I currently use a restriction orifice to control yo-yo. This slows the BPV down to about 250 msec for full opening to full closure but even that is just on the edge of the yo-yo point. I didn't notice it being any laggier than stock.
Can users of VGS comment on whether it improves throttle response?
In my car, it did. Give it a shot.
MTH soft ware
Originally Posted by LombardStreet
What about the zip-tie mod? (Zip tying the bypass valve shut.) Isn't that supposed to make a big improvement in throttle response. (At the cost of about 10% in mpg, if I remember right.)
you do that its putting a constant load on the blower. i wouldnt advise doin it? atleast thats my $.02
M7 14.5 lb flywheel
M7 AGS intake
MTH soft ware
Randy
M7 Tuning
M7 14.5 lb flywheel
M7 AGS intake
MTH soft ware
Randy
M7 Tuning
Nice plug Randy.
Dan from Rohr Autowerks should be calling you for more items soon. Im gonna be needing the big throttle body and maybe your full AGS system.
Originally Posted by 1FSTMINI
Nice plug Randy.
We have everything you need standing by. I am also a member of the " project no chrome " club but not quite to the same degreee as you. I did have great results with the " chrome surround tape mod " . That one I highly recommend.Randy
M7 Tuning
I still have to do the drip molding,door handles and gas door. I was going to do the cooper gas door swap, but people have said it doesnt fit right.Both cars are identical in that area so i dont know why anyone would have trouble doing this. Guess ill have to try myself and see how it comes out.
Read thru my thread https://www.northamericanmotoring.co...ad.php?t=33326
about my feelings of this "improved" tip-in feel to the software.
NorthWestEuro
Oct 22, 2016 07:57 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
unxpectederror
Oct 22, 2015 12:16 PM
gnhovis
Sep 28, 2015 04:07 AM
