Stand Alone ECU
Originally Posted by Tuls
Yes the AFC works great!! ..I have replicated 30 WHP about 5 times now using afc mods...on a STOCK or Pulley car....on a mustang dyno...just with tuning
I know Alta is working on a standalone system which should be cool.
Has anyone ever thought of using a custom harness and an AEM EMS or anything like that? I know my boss uses Haltech's at the shop but the initial wiring with no "plug n play" harness would be a $^&%&^&
There are some things I worry about...
Running the motor should be relatively easy.... BUT
1) What will happen to the ABS system?
2) What will happen to the ATC/DSC system?
3) What will the immobilizer circuit do?
Cars are getting more distributed. In the traction/stability control system, the ECU gets inputs from the ABS sensors, and may cut power as a result of the interventions that are done. I honestly have no clue if the replacement ECUs support any of that stuff. If not, kiss traction control goodbye!
Matt
Matt
Matt
Matt
yes motec works great..the m4 doesn't allow for the drive by wire though you would need something like the m800 for al lthe pin outs and such I think....I forget off hand
Heres my experience with stand alones. The MOTEC is hard as hell to tune and so is the AEM they both control every bit of your car completely replacing your ECU. In my EVO i used the Turbo XS UTEC because it was a plug in and only took affect after 25% throttle was applied it was a little harder to tune my larger injectors for cold starts but not impossible. Im looking for something like that and the AFC ive seen do some incredible things. I just wish there was a piggyback system not as simple as the AFC and not as full on as the AEM (even though when tuned the AEM does give you alot of power). The MOTEC is just a pain from what ive heard but dont quote me on that its just what i heard.
Originally Posted by love2burn420
The MOTEC is hard as hell to tune and so is the AEM they both control every bit of your car completely replacing your ECU. ...
as for something else to go with or replace the AFC....Justin from Global Motor Werks suggested Emanage...havent' tried it but I know some people who said the LOVE it....
If you are looking for a cheaper alternative, take a look at Megasquirt! I'll provide the link because when you google it some not so nice things show up! http://www.megasquirt.info/
That is totally bitchen!
This looks so cool!
Matt
09-25-2015 12:32 PM
