View Full Version : Stock Problems/Issues
- PDC no longer working after new clutch
- Oddities with Aisin tranny and DSC
- Strange Occurence
- hatch/trunk lock problem
- Bad gas
- Do all MINIs have a power steering pump fan?
- Transmission Problems MCSa NOT CVT
- DSC issues
- misfire in cylinder #2
- warranty
- Windshield Washer Fluid Dipstick Broken
- Blown diff and cracked bell housing!!
- MINI service offering induction cleaning? (Needed to help fix my MINI?) Input please!
- MCS will not start when key is turned...HELP PLEASE!!
- Hazard / parking lights stuck on. Short circuit?
- driving lights and dash lights wont come on
- r53 stalling after fuel filter change
- Growl/winding noise CVT!
- coolant issues
- Cost to replace Serpentine Belt
- New owner with a random coolant leak
- HELP!! How can a squeak be related to the gas tank?
- HELP: Loud buzzing/ whine noise coming from stereo speakers
- Unrelated issues fixed by new plug wires
- Blinkers/Signal lights hesitating
- Need New Battery for My 2004 MC
- very rough idle, limp mode and a P1125 my car hates me
- Normal fuel gauge/sender issue but with lower MPG?
- speedometer doesn't work
- Do I have a complaint to the dealer
- Original clutch died after just 126k miles...
- 05 R53 Rear Wiper Parking Problem
- 06' R50 Transmission Failure.
- EML and Service Engine Soon Indicator light up at 49k
- P0304 cylinder #4 misfires...need advice
- Antifreeze & Oil Leak
- more O2 sensor questions
- OBD codes P0130 and P1237
- burning mustard colored oily matter from exhaust?
- 2005 MCS - do I own a lemon?
- '02 R50 5-speed owners please come in
- Overheating Problem
- Where is pass heated seat controller?
- 911 *** I am Freaking out
- dent in horn badge. can you order a new one?
- Get vehicle error code w/out OBDII tool?
- Wiring Diagram help! Anyone have a copy?
- location of airbag module?
- 100,000 mile service - Most bang for $$$?
- Where is the O2 sensor????
- valve spring compressor
- e-brake
- OBD2 codes
- 'Sproing!' sound at 21km/h - R53 MCS
- Coolant disapearing - no apparent leak
- Cheaper Parts
- Wing Mirror Switch
- Heavy Acceleration Causes Limp Mode
- Just replaced thermostat / housing - Rough idle?
- Problems after alternator & battery replacement
- Hard / Cold start issue RESOLVED!! *Vids*
- tach and dash lights dead
- map/baro circuit high input Check Engine Light
- Hatch release button fix
- CEL, chasing my tail
- Lock malfunction?
- little plastic rocker piece broke
- Replacement ECU
- Reversed control on window regulator fix??? Weird.
- Hard Shifting
- Overheating- no coolant VERY LOW oil!
- Brake Squeal when wheels are turning
- Windshield wipers
- Horn Problems
- Check engine light on after closing hood
- Hard to Shift, Clutch not engaging?
- Borrow airbag light reset tool?
- Fans seized up.
- Fans seized up.
- 02 MCS radiator fan problem (not what you think)
- MCS coolant fan always running.
- OEM Driving Lights - Bad "Key Button"?
- CVT Jerks when put in Drive.
- Seat heater overheating?
- Roughness when braking or starting after a stop
- Aftermarket radiator support - one small difference...
- Steering wheel vibrate on my MINI?
- Steering wheel lock problem....Ideas ?
- PF16 fault after i hit a puddle
- This car is impossible to revmatch! HELP!
- SES light and dealer BS
- whistle noise?
- window problem
- Creaking/clicking sounds from drivers side front tire
- unidentified noise
- cooper vs cooper s head
- Car won't start - battery?
- 02 coolant leak, bleed system any DIY?
- Spark Plugs
- Centering/Aligning the Steering Wheel
- Interior touch Up paint?
- OH MY GOD -- 2 new problems
- Got a Puncture with conventional tires
- What size is th torqx bolt on the rack
- Power Steering issues
- Problem
- Power Steering fluid volume
- Door Lock Issues
- Foglights mysteriously on
- overheating when car is at a sitting
- Fresh Coolant Install - Need Help
- Strange Noise & Loss of power
- New Battery, dead again!
- Help! How to replace the Core/Radiator Support!
- Rear Window Wiper Is Always On
- servicing newbie question...
- DSC/Service Engine/cylinder misfiring
- How do you open the battery?
- Car sat, now won't start, NEED HELP
- No Radio, no HVAC, and wipers going crazy
- Orange module next to Battery
- Servicing Cooper S Supercharger Oil
- Battery - how long does full charge take?
- Will 05 wheels fit on an 09 MINI!?
- exhaust smell in cabin when idling
- weird noise from Clutch on 1st gear
- ASC light Flashes
- Need a Picture or Pinout for 3-Pin CD Changer Cable
- I think i broke some thing
- How to replace tail light
- Heater/AC fan not working
- drian plug
- electrical (headlight/gauges/fan) problems
- Seafoam question
- Does my Throttle Body look right?
- Quick question about Bypass Valve Hose Clamp
- Vibration under heavy accel, especially left turns
- Wet or Dry sump?
- '06 MINI cvt transmission problems?
- faint rubbing sound
- Suspension "loose change" sound
- clutch squeel/grind into first gear
- Need advice on Power Steering Pump install
- motor mount options
- Steering Pump
- That can't be good-CV Joint failure
- Having trouble removing wheel bearing
- Missing 2.5 quarts of oil
- Oil residue on garage floor
- SES P0136 after 15% Pulley install
- trunk/boot is messing up, any ideas?
- Error codes- 2004 mini cooper
- Brushes for power steering pump
- Is my supercharger dying?
- Hatch Release
- SES Light - Coolant/Battery issue?
- Service Engine Soon Light - Misfire Cylinder 4 (R53)
- Gas strut that holds up hatch
- Bearing or CV? Ticking when turning left...
- Cam Replacment
- Is this normal?
- Oil Leak @ 50k
- Vibrating Speedometer on cold start up.
- MINI Diagonosis without Guesswork?
- Air Conditioning running hot 10-20 secs.
- Horn(s) Issue
- Transmission OR Sticky Pedal?
- The Dreaded Check Engine light.
- mini problem
- Squeaky Sound
- Weird noise going uphill
- Coolant Leak near upper radiator fan hoses
- Clicking/ticking sound when on throttle
- Squeek that i just cant get rid of :(
- WTB front seats
- Shifting Problems :(
- Brake Issues - Mushy pedal after brake job. bad caliper?
- 05 MCS just about had enough
- High idle and jerky CVT Transmission
- Vandalized steering wheel emblem
- LOUD buzzing when in drive, 03' CVT
- Antenna Snapped
- 2002 MCS A/C wont shut off, Snowflake light wont come on?
- CVT failure symptoms?
- Will an 06 seat fit on 04 tracks in the 04 ?
- Start, idle, no go
- Brake Light short?
- Airbag light and Uneven Idle
- Dealer will replace clutch but NOT flywheel, is this ok?
- Power Steering and RPM
- P1239 - 1240
- water on passenger floorboard
- Belt Squeal 2005 MCS
- Help! My car's DEAD! :(
- 2005 car key mini sticker came off...
- Door Lock Curse
- First Post-First MINI
- Front window wipers stopped working
- trunk wont open!! * HELP!!
- mechanical door lock 2003
- Lower Console Gauges and Lighter failing?
- Replacing MCS 04 Belt Tensioner
- Paint Touch Up
- Third thermostat, overheating again after 2 weeks
- ebay vendor - supercharger remanufacturer
- Interior Lights Out
- Rear Caliper Dust Boots Split
- Another Engine Noise Thread Knocking?? Sigh..(sorry)
- Clock not working.
- Engne noise when AC is on
- Ready, Fire, Aim... (2006 Cooper Auto Question)
- high rpm and service engine lamp
- Can a fried BCM cause the car to not start?
- Rolled down hill while in gear (!)
- Speedometer stuck
- Getrag 5 speed manual problems?
- Cost of New A/C Compressor
- passenger door doesn't UNLOCK **help**
- how to pull off intercooler and clean it
- help!!
- Noise while car is off in accessory
- Valve Seal Replacement? Has anyone done this?
- How do I restet sensor code for bad O2 sensor?
- Intercooler
- TSB: Change CVT ATF every 30k for longevity
- MINIUSA letter regarding failing O2 sensors in MY 04-06
- Air Conditioning help
- Dome Light? simple question.
- TSW Replacement engine mount?
- PCV valve CHANGED? When?
- 2004 MCS steering querey
- Problems keep adding up!
- Canadian parts store?
- Problem With Opening Driver's Side Door?
- Bad O2 Sensor Code
- AC Noise On Passenger Side Only W/ Fresh Air Selected
- Driver door will not unlock from interior handle
- Will this tool fit?
- i'm petrified: 03 mini cooper cvt whine
- Seat wont recline
- Heavy steering not PS Pump?
- mushroomed to point of metal failure?
- Please help! Speedo instrument cluster goes dead
- Broken headlight washer door!
- Changing Axle Seal?
- crack crack crack
- rear right wheel getting hot
- Running Issue
- brake fluid leak
- P0326 - Knock Sensor
