Third thermostat, overheating again after 2 weeks
Old Sep 9, 2009 | 02:40 PM
hoping2keepit's Avatar
hoping2keepit
2005 Convertible, 72k. In July, I had the standard bad thermo symptoms -- temp gauge swings up when stopped or idle, drops as soon as I start moving. Thermostat was replaced, everything worked fine for a couple weeks -- then the problem returned. Rad fan works, no coolant leaking as far as I can tell. Since it had worked for a while, mechanic suspected maybe a faulty part, and replaced the thermo again. Worked for a couple days, then problem came back. Suspecting an air pocket, re-bled/filled the system to ensure no air pockets, & confirmed temp gauge was working properly -- and it's worked great for about a week and a half. Today, it started overheating again.
Mechanic wondered if possibly the water pump is creating a venturi effect somehow and sucking in air (since he couldn't imagine air getting in any other way, since it's pressurized -- coolant would be coming out.) Any ideas? Obviously, I'd rather not have to replace the pump.
Other fun, presumably unrelated history: CVT transmission replaced at 57k (MINIUSA did cover that after I "informed" them of the results of my Google searches), 2nd front bumper (courtesy of a crazed raccoon), 3rd windshield, 2nd PS fan ("coincidentally" broke when the dealer replaced the tranny), right cable for soft top has broken once so far, currently on third or fourth oxygen sensor -- yes, I saved the SB I just got in the mail. Needless to say, my spouse is not overjoyed with the car's reliability -- and I'm getting nervous as the new transmission gains mileage, wondering how long it'll last...
Old Sep 9, 2009 | 03:47 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I'd check the radiator lower brace, if it's broke the weight of the radiator could pull it down and reduce flow in system.
Last edited by AutoXCooper.com; Sep 9, 2009 at 04:32 PM. Reason: update thanks to gnatster
Old Sep 9, 2009 | 04:06 PM
gnatster's Avatar
gnatster
No S/C tis a MCc, note CVT replacement.
Might want to have Water Pump checked to be sure is functioning properly. Also check hoses to be sure there is no kink or bind that may reduce flow.
Old Sep 9, 2009 | 05:16 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Checking the water pump does sound like the best thing to do. The thermostats came out whole, right? There shouldn't be anything in the system that would cause a blockage.
Old Sep 9, 2009 | 05:40 PM
hoping2keepit
Yes, the thermostats came out fine, and everything seemed to flush OK. I'm leaning towards replacing the pump too [edit: assuming the brace is OK/hoses aren't kinked/pinched], but hate repairs done as a guess(especially when they're expensive...)
Also: gnatster, yes, it's a MCc. Meant to clarify that in the initial posting...
Attached Thumbnails Third thermostat, overheating again after 2 weeks-new_commute-small.jpg
Old Sep 10, 2009 | 09:19 AM
Cadenza's Avatar
Cadenza
The mechanic is incompetent if he keeps on replacing thermostats.
I've recently replaced one on my VW New Beetle... it was stuck closed and hot coolant was not circulating to the radiator. Testing a thermostat takes 5 minutes. Remove the suspected T-stat, put in a pot of water and bring it to a boil. If it doesn't start to open, it's faulty. One should also test the new one before installing it.
I think your water pump might be on its way out... the impeller is loose on the bearing. So at lower RPM, it's spinning in fewer revolutions than it should.
Old Sep 10, 2009 | 04:16 PM
herbie hind's Avatar
herbie hind
seemed to be a bit better after the rebleed . are there 2 points to bleed the cooper as there are on the s? one bleeder at front and one up near t-stat.
Old Sep 10, 2009 | 05:01 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I'd be suspect of the water pump. I've replaced a couple on Cooper non S's
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Sep 10, 2009 | 06:51 PM
hoping2keepit
Yeah, I think the mechanic who put the third one in didn't bleed it properly, which is why things only improved for a day. Last trip in, the guy with more MINI experience re-bled. Until yesterday, I thought he'd fixed it...
Everything was fine today, though i didn't drive as far (only about 20 miles, vs. yesterday's 100.)
Old Sep 11, 2009 | 04:18 AM
herbie hind
you may wanna pressure test for a head gasket .
Old Sep 11, 2009 | 09:04 AM
MINIfixer's Avatar
MINIfixer
Did I miss it, or has anyone asked about whether or not the auxiliary engine cooling fan is working? There is a high and low speed stage...
Old Sep 11, 2009 | 01:37 PM
hoping2keepit
How do I check that?
Old Sep 11, 2009 | 07:17 PM
ajakeski's Avatar
ajakeski
Water pump is bad.
Old Sep 14, 2009 | 02:28 PM
hoping2keepit
Update, mostly to document in case someone else searches for similar symptoms (I'm guessing it's the pump): I've definitely heard the fan working at two different speeds.
It's interesting (to me, anyway) that it's been working fine most of the time -- like my 20 mi. drive home this afternoon -- but not at others. e.g. 1/2 hour later, a 4-block trip had the gauge creeping up & the fan going full-blast after I stopped the car. A quick check under the hood reveals a reservoir tank close to overflowing, and a radiator that's cool to the touch. You'd think the wp would either work, or it wouldn't.
My wife's car is in the shop, or I'd be taking this one in today. Hard to function without ANY car, though...
Old Sep 15, 2009 | 02:48 PM
hoping2keepit
Today's update: even cold, first thing this morning, the reservoir was full -- which I interpret as meaning there's either something blocking the hose, or an air lock. Since previous flushes/refills have worked for a while, I'm inclined to think air's getting into the system somehow. Since the system is pressurized, though, the only thing I can imagine is the wp's weep hole is working in reverse, acting as a venturi. Can anyone think of another way for an air lock to build up over the course of a couple weeks?
Old Sep 15, 2009 | 06:44 PM
lsh321's Avatar
lsh321
Hi!
I think I am having exactly the same problem:
https://www.northamericanmotoring.co...ml#post2873675
Old Sep 15, 2009 | 06:48 PM
go_mini_go's Avatar
go_mini_go
I'd say keep bleeding it. The up and down temp is from an air bubble passing through the system, make sure the tech turns on the heat while bleeding the two bleeders. Sometimes it takes quite a while to get it all. Or you have a bum head gasket, is yor oil milky?
Old Sep 15, 2009 | 07:19 PM
herbie hind
man i can tell you i did a full flush on mine and even after bleeding had air .coincidentally months later i was checking resevoir;pulled the cap and woosh!! air came out . not in , that's a different sound . so do a search on bleeding ; there was something on it a loooong time ago. it explains different ways to get the air out .
Old Sep 17, 2009 | 04:46 AM
hoping2keepit
It's currently getting bled again. Just looking at the hoses, though, really makes me wonder; the upper bleed valve, by the radiator, is a full inch below where the hose enters the rad. What they were thinking? Nobody thought, "Hey, air is lighter than the fluid, maybe we should put the bleed valve at the high point..." Has anyone designed a vacuum system of some sort for doing this?
Old Sep 17, 2009 | 10:14 AM
herbie hind
is up bye the thermostat. (other bleeder).
Old Sep 21, 2009 | 02:43 PM
hoping2keepit
Still fine since last bleed
Just another quick update. Picked up the car Thursday after getting the coolant bled again. Everything's been fine thus far -- naturally, I'll post if it changes again...
Old Sep 21, 2009 | 03:53 PM
gnatster's Avatar
gnatster
Yes http://buy1.snapon.com/catalog/item....re&dir=catalog
I've used one of these multiple times at DIY days at our local MINI dealer. Sure does make the process easy and no bleeding is required.
Old Sep 21, 2009 | 08:00 PM
healey67's Avatar
healey67
Im not sure if I just missed it... but there are 3 bleeding points on a cooper and 2 on a cooper S... Make sure you get all 3.
Old Sep 22, 2009 | 02:26 PM
hoping2keepit
I thought there were only two -- top left (passenger side) elbow where the hose enters the radiator, and between the engine & battery, behind the fill spout (or whatever it's called.) Where's the third?
Old Sep 26, 2009 | 04:58 PM
hoping2keepit
Bled & refilled again this afternoon, using a vacuum system. The good news: the vacuum held, which leads me to believe the "maybe the WP's weep hole turned into a venturi" theory is unlikely. Worked fine on the way home, so we'll see...
