View Full Version : Stock Problems/Issues
- Power Steering Fluid Leaking!
- Trip Computer and auto AC keeps switching from farenheit to
- Service Problems and my mini
- Surge/Hiccups/YoYo (SHY syndrome) …It’s the ECU???… Mmmmm???
- pressure bleeder and master cylinder cap
- Plastic strips under car.
- Weird clicking sound when closing the bonnet???
- New Transmission After only two weeks
- RECALL MINI COOPER S
- Mini Service Clueless about Software
- Body Creak
- Body Creak
- Snipe hunting! Or... what the heck IS that noise?
- BMW/MINI Parts cross reference?
- Bad plug
- It came back!
- Engine Fan
- Strange noise after running AC for more than 20 minutes...
- My power steering fan grille
- Horn blown
- Stumble
- Any problems with runflats?
- Engine ticking after pulley mod.
- help
- Speedometer rattle
- Help... Need Engine Advice Please!!!!!
- Types of Engine Oil
- Question about Auto AC
- Why are some coolant overflows pressurized?
- Catch Can
- Popping column
- Help, I mistakenly put regular gas in my Mini.
- Bosch Spark Plugs...
- Problem with kaleido cloth sport seats
- Measuring a Full Fuel Tank
- coolant low
- Evil Exhaust...need some help
- Headlight adjustment
- Weird thing happened...
- Can't get to 1st or 2nd gear ?
- Exhaust is rattling....Dealer fix or should I attempt to tig
- Wild and Crazy speedometer and tach!
- Engine Hiss
- My first Oil change!
- Break-in: Non-Synthetic Oil
- Airbag Light...again!
- Aligning the hood
- Recalls...how many are there?
- Just changed my oil -- What a mess!!!
- MagnaFlow for Cooper NAsp
- Silicone radiator hoses, has anyone actually installed them
- Magnetic Oil Plug
- lurching?
- OBC MPG readings
- idle issues
- The horn location
- Best way to get four jack stands under the Mini?
- Changing oil every 10K??!!?!
- Battery Leak Warning
- Why doesn't ASC use the brakes?
- FRIED MY HORN??
- Rear Wiper Bug?
- DSC & Tire Pressure Warning Lights = Steering Angle Sensor F
- Missing frame bolts
- Pirelli's on R90's are Runflats?
- Engine Rattle...
- paint coming off in engine bay area
- Fog Light Replacement?!?!?!?
- Red fluid leaking
- Newbie How to...Air Filter in the 'S'
- Hard shifting into reverse?
- Rattles, Squeaks, etc - comparison to other cars and build q
- Shallow 36mm Socket featured in this month's RSpeed How-tos
- Alarm System for MC
- Free Mini Maintainence
- Rear sunroof screen rattle...
- does anyone have a knocking sound when turning the steering
- Shifting techniques, In the Twisties, Heel/Toe
- worst mini day? bad "car-ma"...
- Engine Power Loss
- P/S fan screen
- I Need Cold Start problem info!
- run flats, run flat
- No more coolant bottle leaks
- 2003 model recall campaign
- perhaps an obvious/dumb question
- Power door lock problem
- Power Steering Problems
- * * Coolant Issues * *
- top speed
- Does anyone know where to pick up a shop manual for a 03 S
- Anti Freeze question?
- Scary Noise on Accelerating from a Stop
- the BIG thread of RATTLE fixes
- Anyone know how complicated a right front control arm replac
- Rust in my engine
- Tire Rod and Strut Replacement Questions HELP
- Transmission Problems?
- Airbag light on .... Why???
- Loss of power
- Rattle in Rear, Not Hatch Rattle
- Rear vents
- Radiator
- Has first gear hesitation been fixed?
- rear wheel arch light help?
- "smart" ecu
- Search function How-to
- My Cooper broke down
- Horn change?
- sagging visor
- Trunk rattle/creaking: Solved
- oil counter reset
- How does the ASC+T work?
- Oil not checkin out on dipstick
- Water leaking into interior?
- Trailer Hitch
- Intermittent Power Steering Problems?
- MAN WITH ALL THESE PROBLEMS IM GLAD MY MINI IS GONE
- Battery
- Leaking
- Front suspension upgrades?
- DSC is permanently off?!
- Black brake fluid hose from brake fluid tank
- Where does the speed signal come from?
- Breakdown!
- Do I need an extra oil change?
- a silly question
- going from 15" to 17" Cooper wheels & Tires
- 12 v air compressor?
- What kind of oil filters ya'll buy?
- Chasis flex/Sunroof Creak
- Transaxle lube
- ECU Firmware?
- Oil Leak????
- Trailer Hitch on the S
- we need a recall and service bulletin data base
- CVT Idle Drop When Engine is Cold
- VOIDED WARRANTY ISSUE MCS Oil & Boost Guage Need Help.
- clock losing time
- Gearbox
- Metal Oxide windscreen?
- New strange suspensionproblem on two swedish cars
- Boot latch won't OPEN
- Sticking Stick (cold weather issue?)
- Bleeding clutch
- CVT Limp Mode ...FIX!
- Cooper 5th vs. S 6th gear ratios
- Wiper blade replacements/refills
- thermostat issues
- 87 Octane Unleaded and the Mini Cooper
- DSC and Tire Pressure light on !!
- Limp Mode in Cold Weather...
- HIGHER 6th GEAR??
- Running Rich Issue
- mini cooper car fire...
- ignition wires
- Cooper Owners Manual oil recommendation
- Mini Shop Manual
- S Coolant tank Revisited: how big of a problem
- Clutch Height Adjustment?
- Do I really need an intake?
- Coolant Brands
- Customer Service Dept problems
- Re-coding the MINI
- Mini headlamps are awesome
- Oil Change
- Schiff CD's
- Brake bleeder valve/screw
- CARB Certification
- Fly The Copter
- EP appearing on CVT
- 7251 Mile Oil Analysis
- Car Show Jinx
- 2nd Oil Analysis
- Supersprint Header
- "S" Coolant Tank
- BMW Arrogance?
- PERFORMANCE FILTERS
- Two weeks old: First problem
- Aftermarket gear lubes in MCS Getrag Transmissions - NOTICE
- Can you purchase a factory service manual for the new minis?
- Suggestions
- Turning off ACS?
- Oil cooler for MC
- Oil pressure and Water temp Gauges
- Factory Alarm System
- engine break in time
- Cooper S Intercooler Rock Ingestion
- Link Discussion of Fly By Wire
- Brake squeal, front steering pull, gas mileage.
- Park Distance Control
- removing the hood stripes
- Why is a jack supplied with run-flat tires?
- Stupid question time
- Custom Order Boot/Bonnet at a very cool price :)
- Washer Fluid Reservoir
- MCS whislte under the bonnet
- Transmission failure - 2003 5-speed Cooper
- Sport Suspension vs. Sport Suspension Plus
- 1st gear resistance, for lack of a better way to describe it
- Transmission dip stick on a CVT
- What's that sound? something up front
- Z MAX Lubrication ???
- Direction Signal Lense Replacement
- New car smell? (is everything fine with the brakes)
- Do you DSC
- Warming the car up?
- Sunroof Rattle
- Average Speed and Speedometer difference.
- Windshield Crack
- 2002 Cooper S Oil Dipstick
- DSC and Flat tire light will not go out
- slight hesitation in 2nd gear
- do you add syn oil????????????????/
- frozen shifter
- My mom ran my brand new MCS bone dry out of gas!!
- Faulty fuel gauge
- Where to buy Service Manuals for MINI?
- on the road maintenance
- strange engine noise
- Oil Change Adventure
- Headlight Washers
- Oil Filter Purchase
- My Naked Intercooler
- Shifter change?
- Cooper cold engine stall (for me, on 5-speed)
- Strange sliding noise in right rear.
- major service intervals
- Uh-oh, funky "electrical" type smell from under hood!
- New 3.2 software
- temperature?
- My MCS Froze Last Night
- Battery Light Flickers
- Front Bumper
- First Oil Change
- Changing your own air filter Or switching to an aftermarket
- Poor Sick Mini/In Limbo?
- oil filter and wrench
- Required Fuel
- timing belt
- Best rpm fuel economy in each gear?
- FRONT LIGHT WASHERS
- clicking popping from under car
- SERVICE ALERT RESET?
- Minimum outdoor air temp for oil change?
- Sun roof rattle
- Rear-view mirror leaking water
- MINI SOFTWARE UPGRADES?
- Do MINI's have a Chrysler block?
- Quick question about the front bumper
