View Full Version : Stock Problems/Issues
- Belt Tensioner Bolt Broke!!!!!!
- burning oil smell when stopped
- Serpentine belt
- Windows "vibrate" when starting to go up.
- bad grounds
- Brakes not retracting
- Diagnostics Tool - Which to buy
- PCV, Seafoam, and you.
- Air Conditioning
- I think my H/K amp just died. 3 fuses to check???
- 04 Cooper engine mount question (not failed).
- SES and AutoEnginuity won't connect
- Mini Leaking Fluids by Tires and Foul/Rotten Egg Smell
- Supercharger sounds odd when AC is on.
- New to me 2005 MCS major problems
- 2006 cooper s problems....
- airbag fault passenger tensioner firing circuit
- ABS light and check engine soon
- Still having cooling problems (cont)
- Lurching Problems + ?? about Ball Joints
- Xenon Headlight Level Sensor Arm Broke
- ECU RESET
- Limp Home Mode Mania
- Electrical gremlin
- Ticking or Tapping noise in Drivers side Rear
- AC Explosion
- Not sure whats wrong.
- Exhaust sound got really loud
- Knocking Noise and Oil Consumption
- Fan running continuously
- Battery Issue Mini Cooper 2006
- Power Steering lines replacement
- rpm's slightly rising when i push on clutch
- Missing intake manifold gasket!
- Advise plz - A/C stopped @ 95k miles
- Oil Is sprinkling all over my hatch.
- Potential headgasket problem - need help!
- oil leak
- "service engine soon" light on.
- Caliper question
- bad suspension or something else?
- '05 MCS Broken Dipstick
- Have you ever seen this happen to a clutch?
- Anyone have a Power steering pump wiring schematic???
- Plastic Hood Scoop Shroud
- help.. 2 amber light just lit up...what is it?
- Leaving battery disconnected for a week?
- instrument lights
- Caked sludge in front of engine
- radiator fan and power steering fan
- Smell from Vents
- where to get a passenger side motor mount?
- Belt Tensioner Missing a bolt
- Same ol' cracked reservoir, air, overheat, bleed issue
- Hatch open light will not go out
- Worried (CVT)
- My R50 is falling apart
- Boiling Coolant but them gage is right in the middle
- Lights that have always been on...
- Quirky Temperature spike problem
- Strange Acceleration, any gear
- Fun problems with new MINI (rear seal leak and rattling clutch)
- Climate control problems
- Idler pulley
- THREE CLUTCHES IN 30,000?!
- The mechanic says... Legit?
- Strange sound: Front right wheel bearing?
- Thumping Noise Revisited Any answers
- A/C gone kaput? At 17,000 miles???
- P0171 & P0507
- R53 Rear Hatch won't open
- Warm start issues...
- SHE bought this - it BROKE -I have to deal with it...
- Help! horrible rubbing, thumping, grinding noise while driving
- Radiator Fans?
- Service Engine Light..maybe know the problem
- Has this happened to you?
- Help with missing items in engine bay
- Brakes Soft after pad replacement
- Is no low-speed radiator fan really a problem?
- car flickers on and off after key is out!?
- I'm pretty sure my alternator died on my lunch break
- Another loud fan/overheating question
- Idle Problem
- Clattering from motor near oil filter/please help
- cooling fan + alarm = dead battery?!!!!! HELP
- Is my engine mount bad?!?! (pic)
- MAP Keeps gumming up
- help; i have a Grimlin in my o3 mini S
- 2004 Mini Cooper S Tire/Alignment Problem
- P0642 Code Limp Mode
- Is this engine part cracked? 2005 MCS
- Horn problem
- Leaky Oil Pan Gasket... How Much $$??
- Leak...
- A/C catastrophe!
- Starting Issues
- Hard shifting & clutch pedal feel
- Another Air Bag/Seat Belt Light Problem
- Passenger seatbelt won't retract
- Yup, another AC problem thread
- Exhaust Leak - Running Lean
- fan keeps turning on after shut-off. help!
- Washer Fluid Leaks Under Hood
- car freeze while runnig!!!!!!
- About to replace brake pad sensors, ebrake cable. Tips?
- Yellow engine warning light
- EML Light on
- Reattaching Boot Emblem
- My mini has an early morning cough??
- so... i went to jiffy lube today and
- How to remove brake cable from caliper?
- O2 Sensor???
- Funky sunroof issue
- Need help on codes
- headlights stay on
- three-spoke airbag removal help PLEASE?
- AC goes hot on throttle
- Rear alignment question - '02 vs '06
- The Problems Never Stop!
- o2 sensor and other questions
- Bonnet Release Cable
- Loose Gas Cap Cover help
- Help Grinding/Crunching noise when starting
- what does exclaimation mark on gauage means?
- $$$ just to recharge the A/C??
- Cobalt powersteering fan shroud killed my powersteering fan/pump
- door detent not working, how to adjust?
- Bonnet alignment
- Help with Slave/Master Cylinder
- Brake and coolant flush
- DSC and Tire Pressure lights on
- Manual '06 Mini will not start
- Outside temp says -40F......I think it's a little warmer than that.
- Broken idler pully, overheat.
- Belt tensioner tool alternate?
- Which UTI MINI MADNESS OR CRAVENSPEED?
- how to change a marker light?
- traction, ABS, and tire lights on at the same time
- Rear brake rotor removal 06 Cooper
- Slipping clutch
- Headliner time
- No connection via DLC
- Low speed fan works only with A/C
- 06 Cooper S detonation? 18k miles
- Is this a busted Motor Mount?
- Concern about rotation sound from wheels
- Radiator Fan Replacement
- Persistent Brake Noise
- DIY A Pillar Cover Replacement
- Nagging P0130 OBD Code
- Pop quiz: Temperature almost in red within 1 mile!
- R53 '05 S on/off loud shudder/noise
- Should I buy a 2007 Mini Cooper S?
- Loud knocking when I let off the gas... Help!
- Repairing mushroomed strut tower
- Windshield washer hose routing
- Bad news, low compression on one cylinder
- idle overheating issue?????
- Why does my clutch feel and sound this way!?
- starting problem
- Supercharger noise?
- How to adjust/align door on R53? Cooper S
- Newbie Key Fob Issue
- Clutch hydraulics woes.
- Another "Weird smell" thread. 3,500RPM and up.
- Powersteering turning on and off with key on the accessory position
- Dodged a bullet!
- Newbie and Coolant Leak
- Grill cover for reverse light?
- Tach/Speedo dead; all fuses good???!
- Differences in 1st Gen Xenon light housings....
- Issues with exterior lights - Body Control Module?
- coolant overflow
- Major problem regarding oil.
- Difficulty getting '06 Getrag into first gear
- Arm Rest
- Rubbing sound on front drivers side - 2008 Cabrio
- Mini Cooper S 2006 Alarm problem
- Coolant change, but where is the 2nd vent screw?
- Clutch hydraulic failure: Master or Slave?
- Door screw hole plugs
- Mini Emblem missing on my steering wheel
- Need help identifying strange puttering noise
- how much to replace an 05 mcs cooling system?
- fuel gauge wrong!
- NAM member or MCS mechanic in NH
- A/C issue
- PS Leak or Coolant Leak or..
- So I Broke my tail light lens
- Black Textured Paint for Aero Bumper
- What wears on the door stops/door mechanism?
- ASC warning light - but no ASC fitted!
- Service Due..
- Blown head gasket
- Removing (or restoring?) trunk lid "wings" badge
- Noise when accelerating and decelerating
- Engine fluttering/chattering
- Strange noise
- Is this noise my water pump?
- Do you get a lot of steering wheel shake?
- Blow out on hose from water pump to flange
- Losing power, any ideas?
- Over heating and wierd noises
- tie rod adjustable? or replace only.
- Please help. It is leaking!!!
- RPM Gauge cluster not working
- flat spot , hesitation at 3000 rpm
- Steering wheel locked while driving - Help!!
- p0130 followed by p0420 (Coil mabye?)
- Possible dead battery?
- Replacing front windshield wipers
- What in the world is going on with my R53?
- 2005 Mini Won't Start
- ignition coil or coil pack problem?
- PS fluid leak?
- High Pitched Whine When Car is Off.. Won't Stop! Help!
- R53 stock Boost??
- 05 air conditioner problem
- Secondary o2 Sensor Solutions
- Help AC has no Power
- help - new car written off for water damage
- Spark Plug Seats
- Won't start after accident
- 2003 Mini Cooper S WRECKED
- No more electricty in my Mini....
- 2003 passenger seat stuck forward
- What is this leak?? (pic)
- loose door pane 2006 mini
- SOS!!! Major transmission issue. Please help!
- Cooper S Engine Code Issues
- Coil/wire problem?
- jingling tab on belt tensioner
- Midlands Transmission sounds terrible! PLEASE Help me find the problem!
- You guys are probably sick of this question, but clutch bleeding...
- OBC Temp Gauge Stuck
- Leaking sunroof and dead dash
- Rear Hatch Window water leak
- 03 Cooper, front seat stuck in folded over position
- Car cranks but doesnt start.
- Clutch pedal is hard to push
- Driver's door won't open from inside or outside
- Need help identifying (slight) oil leak
- what compression levels does a motor need a rebuild?
- airbag light but its not the seat harness
- brake fluid bleeding question
- sudden stiffness in turning steering wheel?
- Need help with Sea foam
- dead clutch?
- NO!!! OMG I see RUST on my 2005 !!!
