Bonnet Release Cable
Old May 5, 2010 | 06:10 AM
gear-head's Avatar
gear-head
'02 MCS with 90K miles, and the bonnet release is a mess.
The driver's side works fine, the passenger side cable seems to have stretched so that it won't unlock the latch. It's still attached to the little pull handle, but it's obviously too long to release the latch though.
I ordered a replacement bowden cable and it's all one assembly, since the cables are joined together where they enter through the firewall. However, where they enter the firewall, it looks like it's sealed in with some sort of epoxy, black rubber stuff. Also the drivers side cable disappears behind, and re-appears later.
So .... has anyone replaced these cables? Any insights to share?
Old May 5, 2010 | 05:47 PM
gear-head's Avatar
gear-head
no-one?
Old May 6, 2010 | 07:20 AM
Bajanmini's Avatar
Bajanmini
i have had this same problem,the easy fix is first get the bonnet open and install a crimp betwene the lug on the end of the cable and the latch to take up the slack,probably a new cable will also stretch and much more hassle to install.
Old May 6, 2010 | 07:51 AM
gear-head's Avatar
gear-head
What kind of crimp?
Old May 10, 2010 | 08:12 AM
Bajanmini's Avatar
Bajanmini
It can be anything,for instance use a piece of brass tubing cut length to take up cable slack and then cut it open to get it on to the cable and squeeze it back together with a pliers,it's a dead easy fix.
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
MINI Stupor
Oct 1, 2015 11:36 AM
