View Full Version : Stock Problems/Issues
- Manual transmission does not "center" in neutral
- Strange engine noise/rattling... with video
- same engines different noise...
- Serpentine Belt?
- Car wont start EML light on PLEASE HELP!!
- Fuel issues
- Closed hood uneven?!
- can I change my own R50 auto trans fluid?
- need help changing the tail light bulb
- Help! 2008 MCS Cabrio at dealer for 2 weeks!
- AC Repair, or lack thereof -- Recourse?
- sunroof switch issue
- Window off track, falls down into door!
- Wipers too slow
- r50 mini cooper traction control problems
- A/C Fan stays on with A/C off.
- Fan Stays on after you take the key out
- Windshield wiper "Jitter/Lift" at 100+ MPH
- Steering problems
- R53 drive shafts - HELP
- Droopy Headlight
- Need help, oil change gone wrong!?!
- Weird Sound-Help
- Input Clutch Cylinder Problems?
- squeeky sound on full lock
- tail gate noise
- Sun Visor mirror door
- Oil Pressure Light
- Everlast (Walmart) 47-3 battery
- What is this noise?!
- Help replacing thermostat!
- New Mini Owner - Couple of issues
- Clicking sensation/noise caused when turning the steering wheel
- B200 Scan Tool
- Frozen Tire Rod. Yes or No?
- Stuck in gear???
- Mini S 2003 Transmission issue
- wipers dont work
- SES light with coolant temp code.
- Rear license plate screws stuck
- Bowden Cable
- Stock '03 MCS - intake howling/whistle under load not idle.
- Stretched Bowden Cable
- Not another supercharger thread!
- Brake noise, opinions??
- MINI does not start! Recent window problems
- foggy windshield + antifreeze on floor
- Feds investigating 1st gen power steering complaints
- Clutch help needed please.
- Clutch Disengagement noise
- Back up sensors not working
- Must Read About time Power steering pump failure !!!
- ABS Module Failure
- Transmission failure on 2006 Cooper S automatic - any other ideas?
- Oil on spark plug
- A Tale of Mini Maintenance and Repairs
- 04 MCS Power Steering pop the sieve
- Help how to tell the difference PS fan or Pump
- Engine fun :)
- dead battery how to open trunk ?
- Metal shavings in oil, oh god, now what?
- Strut problems?
- Dropped the vent screw!
- Vaccum leak
- RPM running high at 50-65mph
- R53 Overheating
- Front Wheel Hub Rotors
- Sun Visor Problem
- need help tried to search
- Finally! Hesitation and rough cold start fixed!
- scheduled maintaince
- Oil Sender Socket Size
- The Next 70,000 Miles: Help me figure it out...
- Anyone have the Bentley repair manual?
- Mini will not start
- Driver side Turn signal Issue - With Pics
- BBA - Remanufactured PS Pump Failure
- 05 MCS fuel cutting out???
- Mini Won't Start!!!!!
- Leaky sunroof to body cut-out seal.
- ABS and "tire" lights turning on and off, intermittently
- How to enable factory alarm "beep"
- Yet another won't start issue
- How necessary would you say the power steering pump fan is?
- Brake Pad Advice
- Head gasket help
- Wheel bearing Hex Nut Size ??
- a/c compressor clutch
- stripped spark plug cylinder head
- Need help identifying a part...
- i found these parts and don't know where they belong
- Help Please
- Silly Question concerning service mode
- AC Compressor clutch assembly
- Constant Growling Noise When Running
- 2005 sport electrical problem
- P/S pump fan protector-does it really work?
- 2006 S Automatic transmission harsh downshift
- a/c cooling fan
- a/c cooling fan
- First day member! P/S Issues
- '03 Cooper Transmission Failure
- Ringing from Engine (Hello? Hello?!)
- Help guys...2months of trying but r53 wont start up
- Automatic window roll up
- SES light and Check Gas Cap lights on!
- Coolant leak...again
- hydraulic motor mount bad again less than a year will dealer cover this??
- questions on installing the top right clamp (exhaust)
- Cooling fan replaced. New problem arose.
- 02 Idle issues and a/c problem NEWBIE needs help
- Dealer suggest repairs totaling.... drum roll...
- 2003 Mini Replace Reverse bulb
- NEWB Intro Thread....Tranny Questions (not that kind)
- Fuel Filter replacement and related cold and/or hard starts
- Outer Tie Rod replacement
- Competition Edition warranty on fan and horns
- Rear Trailing Arm Maintenance?
- Super Charger Maintenance??
- Help me please asap!! Supercharger gasket
- Power steering fluid overflow?
- Not so clean shifts
- Electrical issues
- 05 Mini S, Stalls on approach to stop.
- stock #1 piston and rod
- fan question
- smart guys needed
- Electrical Problem...??
- Extra key made?
- Simple question about leads
- Mini Badge
- Problems with Aftermarket Oil filters -- Pics -- MUST SEE
- Air Conditioning Problems
- Oil drain valve?
- Keyless locking problem - Clarification.
- Need help with S/C Intake desperately!!
- Oil Leak
- My car rolled back while in gear help!!!
- Mini runs rough below a half a tank of gas.
- supercharger oil
- burn smell at high RPM
- Looking to replace struts and wheel hub assembly...feedback welcome
- R53 Battery is STUCK, anyone else have this problem?
- ABS & Flat Tire Light Both ON
- Fixing Vaccum leak
- tranny leak?
- passenger door lock stopped working
- 2003 MC with 70k km transmision problem.
- Gas Gauge Shows Empty - Tank is Full
- 2002 Mini Cooper (Auto) Fan Issue
- Lost Lash Adjuster
- headlight/tail light issue
- 04 MCS .. new sound from motor. sounds like power steering ?! but maybe supercharger?
- Blown engine
- Sunroof Won't Open and Blowing Fuse
- Brake Pad Indicator Light
- Strut replacement ?
- p0240 - do i need to replace cat or just oxygen sensor?
- Help 2 warning lights are on
- Car doesn't idle...After fast idle and subsequent valve cover gasket replacement
- How to change temp display from celsius to Fahrenheit
- OEM steering rack or aftermarket?
- Help! Cooper S engine wiring harness
- p113c code
- O2 SENSOR AND p0107 CODE
- Non Functional TPS
- Battery Draw
- Seafoam video 90K miles
- Car Died at Stop Light
- flat tire light
- "Random Misfire"?
- Emergency Brake Light Remains Lit
- ABS Failure
- Instrument Lighting Issue
- Door Lock Actuator repair on the MCS R53
- Beeping tones when I turn the engine off??
- Thank You All..Newbie
- Radiator fan & Temp Gauge questions
- Whats causing this??? (coolant boiling out)
- looking for clutch advice...
- Supercharger service bulletin?
- 04 MINI window malfunction
- Infamous intermittent power steering issue
- Mini stalled in flooded wash
- why.. 18mpg 02 justacooper
- TPS PN ?? or Vendor
- Steering wheel shake
- Negative Terminal Sparking
- power steering fan fuse
- 2003 Mini S PS fan
- 2002 Cooper S Fan underneath engine.
- supercharger? done? and ac problems?
- 06 Cooper air filter replacement
- Seatbelt Removal/replacement
- Very Low Boost PSI HELP!!!
- Car Lighter Problems. Fuse?
- Warped Rotor or worse?!?!
- Best place for part Penske www.penskeparts.com
- thought I had a dead alternator
- Clunk from hell
- Quiet HK volume
- Engin Fan keeps running after the car is turned off
- 05 MCS:: Clutch pedal sticking
- Mini fell off the MINI
- temp guage diping down below normal.
- Radiator Fan Test
- Why is it every time I change my oil...?
- Ticking Noise, Gets faster with higher RPM, what could it be?
- It's not you it's me
- So my first batch of problems has arrived
- thermostat housing/computer removal - reprogram?
- More Brake Problems...
- Rear Taillights Out
- Replacing ECU Unit with Used one
- Is this too much to pay for PS pump & fan
- just had ac worked on now the heat doesn't work :(
- Rear roof glass shattered!
- California emissions warranty coverage
- Broken exhaust above cat on '05 S.
- Many different Codes popping up...
- Throwing code that doesn't match symptoms?
- Mini leacking oil
- Clutch Blow-out?
- engine fuse box bolt help!!!
- Xenon headlights causing trouble! Help!
- Air conditioner and radiator fan issues
- help with crankshaft pulley please?
- Strut tower accident
- 2003 Mini Cooper S Brake Pads?
- Gear makes noise while driving
- HELP!! Water Pump
- Driving light
- 40k maintenance?
- No smoke after using Seafoam
- Testing the camshaft and crankshaft position sensors
- Replacement Aero Front Bumper Grille Anyone?
- Broken seat - who replaced it
- Bad clutch or master cylinder?
- '03 R50 - "whirring" noise under hood after car is shut off - HELP!
- Power Steering cooling fan issue
- 2005 Service Manual PDF Download Available?
- Clutch died in my MCS this morning :(
- CD Changer Problem
- Chronic Clutch Slave Problem
- Maintenance Advice?
- '03 MCS: Oil Blow-back on air filter
- At what mileage did you have your first problem?
- Freeing a stuck axle?
- R50 A/C & Odo display Problems
- traction control going crazy, help please
