View Full Version : Stock Problems/Issues
- Spark Plug Replacement
- Squeaky groan solved!
- putting in seafoam
- Maintenance warranty question
- need help with some codes
- Help, My oil looks like greasy mustard mucus (pictures)
- Vibration noise
- Stripped spark plug hole
- I'm a little "miffed" at the scheduled warranty service
- Right Front knocking
- Looking for leather door armrest part
- Transmission problems at 73k
- Heated seat stopped working
- Regional Techs?
- HID problem
- What if... about engine size
- Valves - a - Tappin' ?????
- air bag light@82,000
- Programmable options with late 2006 MCS
- Power steering whine?
- Passenger Door Lock Broken Again!
- Steering Wheel Vibration
- Tower Bar Vibes
- synthetic oil vs. dino oil
- repair manual on cdrom
- Please lube rear hatch hinges...
- where to get MCS parts?
- That sounds like a ___________ problem.
- Help with threaded stud!
- Frequently burning out headlamp bulbs
- Oil Change
- Dot191
- Another P1688 code question
- Coolant leak, MINI drools
- Weird chime question.
- MINI Mania code scanner question
- Dead Xenon
- Rear Hatch Struts won't work
- Mini's age? Hmm
- Shift, EML, SES then limp mode!?
- TSB out on Xenon headlights in 2004 MINI
- Help - Need Clutch Info Quickly!!!
- Yet another Power Window Failure / Questions
- oil+filter change
- Code 130
- Anyone have a Lemon MINI and get it replaced?
- Belt Replacement
- I have a VERY weird cooling problem...
- Hose replacement help
- Can hood closure be adjusted?
- MINI Cooper Midland Transmission Failures
- Recurring Code P0136
- autowipers
- Who is using a Fumoto Oil drain valve on your MINI ?
- Motor mount went boom
- Rear Brake Pad
- synthetic oils and the MINI
- (Intermittent) Loss of Power Steering
- Brake Issue
- Jack Point Gone!
- Squeaks And Rattles!!!!!
- squeaks and rattles!!!
- labor to replace MC 2003 Transmisson
- Service Engine Light Came On..Any Ideas?
- Reset Tire Sensor
- Radiator replacement..
- Bell tone at 37 degrees?
- Brakes
- Removing tranny
- newbie w/ some questions
- Leak around clutch
- Water Pump Replacement?
- STP Complete Fuel System Cleaner
- Engine Hydrolocked, what are my options? :(
- Quiet Smooth Engine now it is louder?
- 03 Cooper Clutch Shudder
- P0108 overboost, but only 12 psi max on gauge?
- Exhaust rubber hanger rattles ???? Help
- Power steering pump fan
- Will an 05 M45 Supercharger fit an 04?
- Intercooler Removal?
- Paint Problem!
- Has this happened? gas gauge stuck on empty
- Brake Job Question
- Shifting difficulty
- Can someone tell me what this tank is for?
- Clutch engagement going into first gear , noise,2003 MCS
- Strange "whirring" sound after start up.
- Rattling Tensioner Bar
- Penzoil Platinum Synthetic
- Stalling at 3500 rpm + service engin light. Help
- Something leaking under my bonnet...
- Muffler bracket
- Vibration @ certain rpm
- 05 Transmission Replacement????
- Brown Milky coolant issue again
- Popping sound after shutting off engine?
- turn signal sound
- Taking driver door apart
- Air Filter Change on '06 S with JCW Factory Kit
- Draining radiator 0n 02 S
- TSB's
- New (downgrade) Formula Mobil 1
- Front Tire: Back and Forth Movement: What's the cause
- Idle problem?
- My car has no coolant!!!
- Friggin Oil Drain Plug Stripped Pan
- 05 MCS - SES light on, DSC light on - Misfire
- Anyone been able to get rid of squeaking in arm rest?
- 2005 5 speed Trany
- Mini Cooper Transmissons
- what does this mean?
- ? about the Heater
- Noise after engine shut off
- Finally changed brands of gasoline, (Shell to Phillips 66) and now I have
- Cat back exhaust
- Strange rattle and motor mount problem
- Cleaning Alta Intake
- Control arm bushing replacement
- window down?
- Sun Roof Rattle '05 Cooper S
- warranty question
- Bonnet not openning anyone?
- How much brake life do I have left?
- paint flaking on bumper...
- Slight rattle at idle
- The worse deal
- Does ANYBODY have a Dinan CAI?
- Strange Tubing fell from below glove box
- 05 MCS winter tire ?
- How do you know if bypass valve is working?
- sale!!!
- FWD or RWD?
- Question:Need Help
- Bad gas at Sunoco
- two issues i'm having with my '04 Cooper S
- Lift-off! We Have Lift-off!!
- Attention all CVT OWNERS!
- Original Battery on 2002 MCS
- Bottom Out
- Big Problem!
- window cracked
- CV Joint Question
- When should I get belted?
- cooper s rebuild
- Heated Seats
- Oil Change Reset ???
- Nothing really works in my Mini
- Blinker/speedometer/seatbelt lights malfunction!!!
- The bonnet itself
- Catch Can ain't catchin' nothin' - why?
- rough idle related to emission controls???
- remanufactured clutch
- 02 MCS problems
- Unichip or GIAC or JCW software upgrade my findings
- Service Engine Light ?
- Crank pulley owners
- anyone?
- How long should I expect a clutch to last?
- Auto locks
- who's done a tear down?
- Under The engine/car?
- No Power! SEC and EMI light coming on while driveing
- Inaccurate Speedometer
- Ticking when stopped
- pcv?
- Dripping Oil Slowly
- breakin' up
- Bonnet Light
- battey/jump start HELP!!!!
- Anybody had a tensioner go out?
- Belt Snapping and Excessive Wear
- OBD codes C1e5c & U0050
- Stiff Clutch
- clutch slip?
- Pops and Bangs
- cold start stumble
- Oversensitive DSC ??
- torque wrench
- 2003 MCSm warranty question?
- Crap!
- Booom!
- sway bar question
- 02 Cooper trans woes/cheapest dealer
- LSD and DSC light?
- Lots of Warranty Repair on 06 JCW
- Question for 2006 CooperS owners
- Dealer ECU Flash
- A Stupid Woman Question
- Keeping DSC off as default
- My MINI died on the highway
- Water pump hoses leaking
- New 2006 Cooper jumpy at very low speed/throttle
- lift points
- Heater Problems
- lifting
- DCS, TPS, and ABS light are all on..why?
- re-run
- Just a little note.
- 2ND OIL CHANGE @ 2916 miles....
- oil path
- Drain & Fill Plugs on tranny?
- rear hatch rattle
- Mobil 1 vs Castrol Syntex. Opinions?
- Err...brake pad warning light just came on...
- Rust???
- Very Odd Noise
- Xenon Flicker
- Anyone else having this problem? ALTA CAI
- Need help with vacuum/boost leak...
- Code 1477.... who knows why? calling Dr. O and friends
- Rodents and Spark Plug Wires
- Pulley Installed - Belt looks off by a 1mm
- clutch and clutch plate
- MINI code reader
- MCSa throttle hesitation
- Flat spot?
- Question for owners of OEM LSD's
- Exhaust squeak....
- Sporadic door unlocking, relocking...
- Need Help With OEM Driving Lamps.
- Where'd the whine go?
- adjusting wastegate and bov
- Metal grinding noise @ startup
- Windshield Fluid Line
- Flapping noise while filing with gas
- 03 mini cooper transmission problems
- What's This Connector For?
- Weird noise "Beneath the Bonnet"
- leakin'
- help!!!
- Brand new supercharger from MINI
- Removal of Alternator help needed
- coolant resovoir leaking
- My MCS burped itself!
- Sloshing Sound
- Battery light on
- Engine Pinking - Help!
- Baton Rouge Service Experience??
- Stupid Airbag Light
- gauge power
- 02 MC will not start - help
- Anyone have this happen?
- Gearbox noise MAYBE?
- Level 1 service??
- Rear mushrooming or a cracked strut?
- Starting issue... I think I have electric Gremlins...
- Lazy brake light on dash.
- OBDII problems... need help please
