Inaccurate Speedometer
The speedometer in my 2006 MINI Cooper (manual trans) reads about 5 miles per hour faster than actual. Is this a common problem and is there a simple adjustment?
Thanks for your feedback.
Anything within 10% is normal, designed to over report to prevent under reporting which is against the law in Europe. Common among many cars. If do a search there was recently a thread on this very topic.
normal for european cars.
i rent a lot of cars and get bored on long drives...so i check speedo readouts against mileage markers and a stop watch and a gps unit when i remember to bring it. i find my bmws/MC are about 5-10% over estimating. surprisingly, many american cars (chevy especially) are close to dead on.
no fix. just enjoy and motor on!
Yes, I drive around with a GPS most of the time and the speedo always reads faster than the GPS.
I also suspect that it makes cars appear faster when people test drive them before buying. . . .
No fix?
Thanks, everyone, for the feedback. I also did a search, as suggested, and found lots of other discussions on this topic. It appears, though, that no one knows of an adjustment, simple or otherwise, to make the speedometer read accurately. I've asked my dealer and he's offered to check with MINI. If I get any useful information, I'll post it here.
I've always wondered about the discrepancy, I began to wonder if this was a problem for the dealer to look at or if it was a common "quirk" to the MINI.
Your ECU knows your real speed. I've got a Scangauge II, which displays data from the OBDII connection. That includes mph, which is consistantly lower than the reading on the speedo. The Scangauge also allows you to adjust for different diameter tires, which I've done.
Pretty handy. I've got mine set up to display mph, MAP, intake air temp, and coolant temp, though there are additional options. I've been using the IAT vs outside air temp from OBC to compare intercoolers recently. Being able to see the real coolant temp is nice also, since I've had to replace on thermostat when it started sticking occasionally.
Scott
90SM
Scott
90SM
triple5soul
Nov 19, 2019 07:46 AM
Interior/Exterior R53 Speedometer Replacement
maniacalmorgan
Aug 21, 2015 03:03 AM
R50/53 R53 Speedometer Replacement
maniacalmorgan
Aug 20, 2015 01:08 PM
