Front Tire: Back and Forth Movement: What's the cause
Old Nov 20, 2006 | 11:39 AM
robr3004's Avatar
robr3004
Recently when I was taking off my front tires I noticed a considerable amount of back and forth movement when torquing down on the lug bolts.
I had a few people take a look at it and some said it was the stock bushings and others said it might be the tire-rods.
I had the front bushings looked at and they were intact with no damage.
Both front tires are doing the same thing and when I really hammer the peddle, the car sometime will feel like it wants to jump to the left or right.
I haven't met any other mini owner with this issue.
Here is some video I took of me kicking the tire.
http://www.raiadesign.net/mini/Front_Tire_Movement.wmv
What do you think?
Old Nov 20, 2006 | 12:30 PM
kenchan's Avatar
kenchan
wheel bearing? looks more like a sus issue though... or is the car
just rocking back and forth?
Old Nov 20, 2006 | 01:55 PM
herbie hind's Avatar
herbie hind
isn't it just the play in the transaxle? a rear wheel drive has some front to back play also. if not then your ring and pinion's digging in no?
Old Nov 20, 2006 | 01:56 PM
chows4us's Avatar
chows4us
That would be the castor setting but do MINIs even have a castor adjustment?
Old Nov 20, 2006 | 02:21 PM
robr3004's Avatar
robr3004
Rear tires don't budge a bit. Car is not rocking when I kick it. I have kicked tires of other minis and they are rock solid.
Old Nov 21, 2006 | 12:01 AM
002's Avatar
002
That's the control arm bushings. Because of the design they do this when new and just get worse. It is standard on most bmw's. Powerflex bushings work well.
Old Nov 21, 2006 | 06:36 AM
robr3004's Avatar
robr3004
That's what I was told by a few other Mini enthusiast, but a reputable Mini Mechanic disagreed. That's why I posted this question too back up what the Mini community had to say before I dumped money into something that didn't need to be fixed.
I also heard the control arm bushing are a labor intensive install. Anyone have any input on this?
Thanks for the info.
Old Nov 21, 2006 | 06:04 PM
herbie hind
mines done it since new and handles great .
Old Nov 21, 2006 | 08:30 PM
002's Avatar
002
If he means that they all do that, then he is right. It is a matter of taste, If you can't percieve it's effects, then don't worry about.
They are labor intensive, but doable with the right motivation.
Old Nov 22, 2006 | 04:56 AM
mbcoops's Avatar
mbcoops
I witnessed Rob kick his front tires two weeks ago, and while I'm not a mechanic, it certainly did not look normal. When we compared it to my car, the difference in travel/play was significant.
Hope you get this figured out, Rob.
mb
Old Nov 22, 2006 | 06:13 AM
jaynicholson's Avatar
jaynicholson
Just a wild guess, but could a LSD impact the amount of play in the wheel? MBCOOPS, do you both have/not have a LSD tranny?
Old Nov 22, 2006 | 06:33 AM
chawness's Avatar
chawness
I would say you cant just look at the stock front bushings and tell if they are bad. Mine looked good to but came out in three pieces due to being totaly shot. Best way to check is to take the wheel off and grab the control arm and see if you can move it, if so, they're toast.
I replaced Mine twice, once with the stock units, once with Powerflex. I made my own tool to extract the OEM bushings.
Old Nov 22, 2006 | 06:54 AM
robr3004's Avatar
robr3004
I was told that the Stock Bushings are fluid filled and if they are not leaking, then they are still good......but then again I don't know how long it's been like this. The fluid may have drained out and dried up by now.
Is it technically difficult to replace the bushings, or just time consuming?
Old Nov 22, 2006 | 07:01 AM
kapps's Avatar
kapps
This might be one of the reasons for the Alta Positive Steering Response System. I've heard that on the dyno, the wheels move almost as much as the engine does when you switch from full throttle to none.
Old Nov 22, 2006 | 07:02 AM
mbcoops's Avatar
mbcoops
jaynicholson - I don't have the LSD.
mb
Old Nov 22, 2006 | 07:07 AM
jimz68's Avatar
jimz68
What he said!!
Jim
Old Nov 22, 2006 | 07:11 AM
chawness's Avatar
chawness
Technically speaking, it isn't that difficult. It does take a lot of muscle and some ingenuity. I have pics of the whole ordeal if interested.
Old Nov 22, 2006 | 07:24 AM
robr3004's Avatar
robr3004
Definately interested in the pic's.....I have to install a rear sway bar...might as well make a day of it and do the bushings on the front too
Old Nov 22, 2006 | 08:57 AM
chawness's Avatar
chawness
Go to the following link to see the pics and a brief description.
http://www.greenwayeng.com/wsmod/cooper/
surfblue
Oct 24, 2018 01:20 AM
Zettinger
Aug 25, 2015 04:04 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
