Vibration noise
Old Dec 16, 2006 | 07:36 AM
DeniseK's Avatar
DeniseK
Vibration noise
Vibration noise coming from either the center or the passenger side front end.
I have an 02 MCS with an after-market exhaust. I can make this noise happen if I start off in second gear, which, of course I don't do. I've been reading these posts on worn out hangers, brake stuff, tire problems. I don't know what to do. I have 41,000 miles. I live on a dirt road, but I take it as softly as I can. Everytime I've taken it in and it's up on a lift, the answer is the same, "Can't see a thing." So what do you folks think? -- Thanks
Old Dec 16, 2006 | 09:16 AM
Rawhyde's Avatar
Rawhyde
I bet it's a busted motor mount. Open the bonnet and look at the can shaped object on the passenger side of the engine. If there's an oil smear on the frame rail....that's the culprit. It happens a lot, and the noise is a slight rattle or thump coming from the passenger side. Seems to be more active on semi smooth surfaces like gravel parking lots, etc. Do a search, there are lots of pics of this leakage.
Rawhyde
Old Dec 16, 2006 | 10:04 AM
DeniseK's Avatar
DeniseK
Not a busted motor mount
Thanks for your reply. I checked and it is not a busted motor mount. It's a deep-sounding vibration -- only when I start off. Can't hear it when I'm driving.
Old Dec 16, 2006 | 12:12 PM
Rawhyde's Avatar
Rawhyde
Search for some threads on problems with the dual mass flywheel. Those things have been known to cause problems in the earlier models.
Rawhyde
Old Dec 16, 2006 | 01:16 PM
DeniseK's Avatar
DeniseK
I read the dual mass flywheel info. I don't think that's what theproblem is for me. I have a deep vibrational noise. Has nothing to do with the clutch or with changing gears. I can replicate the noise by starting out slowly in second, which of course I don't do. It just a deep vibration. Goes away when I'm driving. Any other ideas.
Old Dec 22, 2006 | 07:19 AM
Zarrik's Avatar
Zarrik
I've got the same sound now in my Mini. I only getting if I bog down the engine, either by not over-revving when taking off or by letting the RPMs drop when I'm in second (usually in traffic). I get a metallic rattle sound from under the car.
I'm hoping to bring the car into the dealership sometime next week to have it addressed along with dash rattles inside the car.
Old Dec 22, 2006 | 07:35 AM
kapps's Avatar
kapps
I get the sound if I bog down launching. It comes from the back and sounds like metal on metal. I believe it's just the exhaust rattling on something
Old Dec 22, 2006 | 08:32 AM
eMINI's Avatar
eMINI
Just taking a flyer here... Maybe you guys just need to get the engine speed up a bit more when taking off. Our little cars are slightly heavy for just a 1.6L enigne. And the supercharger is no help at low rpm. I could be off base here, but just try using more rpm to see what happens.
Old Dec 30, 2006 | 12:20 PM
Zarrik's Avatar
Zarrik
It turned out that the rattle sound I was getting was a loose heat shield. The dealership tightened it up and it's not nearly as bad now. I may bring it back though, as the rattle is starting to return.
scfiveo
Sep 27, 2019 02:27 PM
minieater
Oct 28, 2015 02:15 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Miniwaukee
Sep 29, 2015 09:22 AM
