How do you know if bypass valve is working?
Old Nov 12, 2006 | 09:07 PM
davisflyer's Avatar
davisflyer
How do you know if your bypass valve is working correctly? I was pulling away from a stock 06 S, but not very quickly:(
Old Nov 12, 2006 | 09:11 PM
not-so-rednwhitecooper
i would look at the circumstances before you look for borken parts.
what gear were you in and what speed were you going? its all dependant.
A stock Cooper could walk your JCW if you were in 5th at 2 grand doing 40 and the Cooper was in 2nd at 5 grand doing 40, and you both floor it.
Old Nov 12, 2006 | 09:15 PM
Dr Obnxs's Avatar
Dr Obnxs
If you're generating boost...
it's working, to some extent... Typically, the symptoms of a bad valve are that you don't make boost, and if severe, you get codes, maybe even limp home mode..... And that's when you floor it. At idle and light throttle, it runs fine....
If the stop limit isn't set right, then you just don't make maximum boost....
Matt
Old Nov 12, 2006 | 09:50 PM
davisflyer's Avatar
davisflyer
No codes or anything......maybe I was just expecting to pull away harder.
At least I was pulling away
wkp1219
Nov 13, 2015 07:52 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
