Stiff Clutch
Stiff Clutch
Seems as though since the weather turned cooler, clutch seems stiff until MCS has 'warmed' up. I haven't really noticed this since '03. She's 'normal' after about 5 minutes. It's not a heavy stiffness...but seems different. Anyone else experience this?
Clutch noise/feel
OK...no response to previous post. Today, no stiff clutch. However, each time I pushed clutch in, it started to make a noise, approx. 3-5 inches from floorboard (hard to describe the noise...maybe like a 'springish' sound). Thoughts?
hmmm... never experienced this myself. I know when I originally bought my 2k3 MCS, the clutch was very stiff, course now it's as light as a feather with the flywheel/pressure plate/clutch upgrade I did a few months ago. Only thing I can think of is to possibly check your clutch slave cylinder and insure it's releasing and engaging properly. Not sure what could cause a "springy" sound like you describe, but hopefully someone here can offer you more incite. Is the sound originating from under the bonnet or by the clutch pedal? That info might help in pointing out the potential problem.
GotMINI
GotMINI
clutch
Volki:
After 10 or so minutes, it begins. It's a sort of subtle, grindy feel/sound. Today, seems like there's not so much of a clutch (that is, there's not much at the top of the clutch). :impatient
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
