PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. ABS/DSC/Flat Tire Monitor warning lamps (glitch?) question
  2. P0326 Knock Sensor Questions
  3. check engine light... possibly the PVC valve?
  4. What the heck is this tube??
  5. help nam please r53 wont start
  6. The mysterious "ding"
  7. fan always turnes on after driving
  8. HELP! Need Brake Booster Repair Instructions!
  9. Bunch of lights came on...
  10. 50,000 Mile Tune Up in Orange County
  11. Reverse light burning fuses. help!
  12. Battery Replacement?
  13. busted PDC on convertible
  14. hail damage-roof
  15. Spark Plug Dilemma
  16. Did I get a lemon?
  17. Rear wiper leak
  18. Power steering acting up
  19. Help! Mini is bleeding.
  20. Dashboard top vent - wasting my cold air!
  21. Driver side door won't close !
  22. Top shock mount
  23. Belt tensioner pulley is garbage.
  24. Air conditioning Problem
  25. Is non-mini coolant safe to use?
  26. transmission problems 70K ... is this common?
  27. san diego area mini repairs... know of any?
  28. Alta driving lights and lower radiator???
  29. Issues with 1FastMini... Resolved
  30. Power Steering pump
  31. Good place to purchase Brake Booster?
  32. Noise from engine bay at high speeds?
  33. drivers door lock... problems....
  34. Dash backlighting not working
  35. Oil leaking from motor mount - easy to replace?
  36. EML light
  37. 2nd Gen Mini, but need 1st Gen advice
  38. 03 MCS Cranks but Won't Start After Sitting for a Week
  39. Warranty for $4,076.00!!??!!
  40. How to reprogram remote???
  41. fixed my 02 mini's electrical issue
  42. #1 injector not getting power. NEED HELP ASAP
  43. Removing PS pump
  44. My 2002 MCS just died
  45. what did i break? airbag light stuck on!
  46. New MCS Owner (yesterday) Tranny Blew :(
  47. Vibration in front...
  48. Light trifecta: ABS, DSC, tire pressure
  49. Weird Wiper Behaviour?
  50. HVAC panel, half illuminated
  51. Airy brake pedal?
  52. Separating P.S. fan and Radiator fan circuit
  53. replacing starter on 04 mcs... help asap please!
  54. '05 R50 CVT fluid change questions
  55. How to replace power window relay?
  56. Crankcase Vent Valve
  57. AC or Electrical Problem
  58. 3year,36k
  59. Multiple overheats
  60. clutch release: sticky - slave cylinder at risk?
  61. Tire / Rim SqueeeeeeeK
  62. head gasket blow after repair fan wont work??
  63. Boot not closing
  64. Is the break light mod safe?
  65. relay for starter?
  66. Water on Drivers Floor
  67. Used 2005 MCSC still under warranty for a few months
  68. Anyone have a "How to install an 02 Sensor" on a MC ?
  69. And just as I thought..
  70. Engine Noise A/C?
  71. P/W RELAY REPLACEMENT???
  72. Lost all power at gas station, jumped and now fine
  73. 6000RPMs, Limping, Check Engine, EML, DCS lights.
  74. R53 Power Window Problem
  75. Radiator fan wont shut off! Please HELP!!!
  76. Parking Distance Control (PDC) sensors
  77. Broke my headlight (pics inside). Need part numbers.
  78. How to remove dash or dash pad (rattle fix?)
  79. Air Conditioning Baffle problem
  80. cel
  81. Coolant gurgles at 2000 rpm Please help!
  82. Electrical help needed
  83. Matching interior paint
  84. suspension noise...please help!
  85. car will not start , clutch related problem !
  86. How long can I drive on a busted motor mount?
  87. Headlight, Power Lock and Airbag - Fuses or repair?
  88. No Fault Codes on OBDII??
  89. Overheating
  90. Voltmeter Readings - Bad Alternator?
  91. Fuel System Readiness Monitor "Incomplete" ?
  92. Check Engine Light - Solved!
  93. What is this?
  94. Passenger side window won't work.
  95. Xenons stopped leveling
  96. hood scoop melting after 5k miles...
  97. aftermarket cooling fan assembly
  98. Clutch Slave Cylinder?
  99. So I Demolished A Motor Mount
  100. How to remove rubber boot from spark plug well?
  101. Clanking Noise
  102. Fog Lamp Glass Broken
  103. Flywheel recall
  104. need to buy 05 cabrio glove compartment
  105. Discovered fuel leak when filling
  106. Engine ticking when clutch depressed
  107. Having issues with front lip spoiler/grille
  108. High RPM at cruising speeds - Clutch Problem?
  109. Irvine Mini dealership / South Orange County, CA
  110. Need some Help ID'ing a Part
  111. P1072, system running rich, 2nd time
  112. online RePaIr MaNuAl!!!
  113. Help with left hand drive shaft removal
  114. Good mechanic in Pittsburgh area?
  115. no start, wacky temeperature gage
  116. where to buy a rebuilt brake caliper?
  117. There's a noise and I want to see if anyone has had it before
  118. Power steering pump fan making noise
  119. Strange noise with engine revs
  120. Leatherette cracking already?!
  121. Steering wheel vibrations
  122. AC system blockage?
  123. In a Bind - Lost a Screw
  124. SES Code P2404
  125. E10 code? huh?
  126. Service in East Lansing, MI
  127. DSC light, SES and misfire on cyl #4...
  128. Black Drainage From Exhaust of MCS
  129. Bay area OBDII code reader? Service engine soon light on
  130. Lift-off or launch position!
  131. Positive battery post clamp issues with new Duralast
  132. AC Problem
  133. My AM radio reception stinks!!!
  134. Whistle sound after turning off car
  135. Need help and wiring diagram for pre 2003 engine cooling
  136. Odd buzzing from behind/under the engine
  137. !!-How do you remove a Wiper Relay?
  138. Low Mileage vs. Regular OBC Service
  139. Rear Seat Belt Reels Locked
  140. Driver's Seat stuck forward - 06 MCS
  141. A Starter Success Story
  142. sounds like breaks, stealer said dule-mass flywheel
  143. Help! shift indicator -tachometer -speedometer issue
  144. Shift Indicator - Tachometer - Speedometer issue
  145. help! trunk will not open!
  146. Front suspension overhaul
  147. Drivers door latch dead
  148. Dipstick Photo or diagram
  149. Car is having issues!
  150. Failed Motor Mount?
  151. extended warranty?---parts 4 sale
  152. Rear Caliper seized or is it parking break?
  153. Can Car Wash Rails Change Camber
  154. High pitched whine
  155. Excruciating screech a safety issue
  156. Shock of shocks: Midlands tranny problem
  157. AC is not getting cold and hissing sound
  158. Hi beam indicator light not working
  159. Diagnosing a bad control arm bushing?
  160. New Rotors @ 30K?
  161. Doing 30,000 maintenance myself
  162. Uneven front brake wear (HELP!)
  163. Battery Voltage
  164. noise when starting /smell while running. Help Please!!
  165. Motorized Mirror "Sticks"
  166. Warranty Question
  167. Arghh.. Another thing to worry about. Parts # needed please
  168. Optima Battery Rebate
  169. No cold air from AC
  170. Clicking Brakes!
  171. Car stalls immediately after start.
  172. Help with my brakes
  173. Running the car on dead battery
  174. Best Extended warranty for covering CVT's
  175. Handbrake Boot Tear Problem/Way to Hide and Fix
  176. Radiator, repair or replace
  177. They just towed my MINI - I actually cried
  178. glass washer water tank...
  179. 1-2mm gap between window and weather strip
  180. Another rust issue: Hatch hinges
  181. Dead Car.
  182. Seat ignited on fire
  183. amber warning light on speedo
  184. Left Side Marker Replaced SEVERAL Times!
  185. My transmission is mooing.
  186. Rust On the lower edge of the door
  187. 07 Automatic Transmission Problem
  188. DSC, ABS and BRAKE lights on
  189. Oil filter?
  190. How powersteering system works?
  191. ASC+T Indicator Light staying on
  192. Railroasd tracks-> car died!
  193. Mysterious Window Dipping
  194. 2004 MCS over heating
  195. replacing front parking light
  196. Name This Part
  197. I Love Mini Of Manhattan
  198. Heads-Up On The Carpet Floormats
  199. Door Rust in Rear Hatch
  200. replacing driver's sun visor
  201. Strange Noise from Drivers side Back
  202. Hood alignment
  203. 3 CV Joints in a Month: Larger Issues??
  204. 2003 Navigation
  205. Water coming out of hatchback?
  206. Power Steering pump fan fuse?
  207. Where is the code reader plug?
  208. AC Odor problem
  209. Silver Interior Paint
  210. CVT hesitates in stock but not Sport mode
  211. outside A pillar cover replacement
  212. Sunroof alignment - problem closing
  213. Intermittent interior hissing when A/C is on, any thoughts?
  214. Maintinance Times?
  215. Inside air won't turn off
  216. Trouble shooting A/C problem
  217. Brand New MINI with loud fan noise and Ipod problems?
  218. Tire Issues
  219. Can't Finish Oil Change
  220. Leak Detection Pump
  221. Interesting Sound, from the cooling system?
  222. Which valve to 'purge' air from the radiator?
  223. Darn, won't get Inspection 1 in time
  224. Repeated failure of Timing Chain Tensioner
  225. Starting difficulties after battery install
  226. Howling/ fan sound when shifting
  227. Newbie here!!! Paint on the down tubes
  228. Royal purple manual trans fluid?
  229. OBD Code reading failure
  230. Driver Door Lock Handle Removal Help
  231. Does anyone know how to do an emmisons smoke test?
  232. Squeaking clutch problem
  233. Wheel bearing problem. Anyone else has this?
  234. Leak in supercharger area
  235. Difficult Shifting Please Help
  236. DEAD CAR!!!!!!
  237. Smoke Test on Fuel Tank Evaporative System
  238. DME question
  239. Lifetime Alignment Option (Is It Worth the $)
  240. ordered something came broke, emergency ?
  241. Warrantee questions???
  242. Noise come from...
  243. Sprung a leak.
  244. Strut Mounts - PLEASE HELP!!!
  245. Brake lights stuck on
  246. How to remove the seat protection ?
  247. cooling fan 5 amp. fuse help
  248. scan tool reading P2301&P2304, ignition failure?
  249. Question for the Chrono Pack (non-Nav) owners
  250. Scraping noise while cornering right
