Headlight, Power Lock and Airbag - Fuses or repair?
Old Jul 29, 2008 | 02:31 PM
Rob C's Avatar
Rob C
I've recently had the driver's side power lock and driver's side headlight stop working on my 2003 MCS. I purchased two different replacement lights and no change - still not working.
The passenger door lock works with the remote and interior switch, but the driver's lock only operates with the key in the door's lock. No remote or interior switch response.
I also have an airbag icon showing whenever someone sits in the front passenger seat.
Could these be fuse related or something bigger? Could each door and headlight actually be on different fuses?
Rob C
Old Jul 29, 2008 | 04:30 PM
Xymox's Avatar
Xymox
Sounds like incorrect or lose wiring to me. But, in case you want to pull fuses, this may be of some use: https://www.northamericanmotoring.co...highlight=FL10
Old Jul 29, 2008 | 09:13 PM
guidmini's Avatar
guidmini
Rob C you need 2 things
1. you need to new door lock actuator
2. you need a new pass side seat cushion is has a seat mat sensor
built into it.
triple5soul
21
Jul 29, 2016 04:27 AM
one73ronin
Aug 19, 2015 12:36 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
